Where Do I Get A New O2 Sensor? | FerrariChat
Discussion in '308/328' started by Dr Tommy Cosgrove, Jul 23, 2007.
  1. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
    Time for a new one.
    84 308 single cat. Who has the best price for Bosch?
  2. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,164
    Dumpster Fire #31
    SMG
    have you bench tested or cleaned it?
    Use a high impedance DC voltmeter as above. Clamp the sensor in a vice, or use a plier or vice-grip to hold it. Clamp your negative voltmeter lead to the case, and the positive to the output wire. Use a propane torch set to high and the inner blue flame tip to heat the fluted or perforated area of the sensor. You should see a DC voltage of at least 0.6 within 20 seconds. If not, most likely cause is open circuit internally or lead fouling. If OK so far, remove from flame. You should see a drop to under 0.1 volt within 4 seconds. If not likely silicone fouled. If still OK, heat for two full minutes and watch for drops in voltage. Sometimes, the internal connections will open up under heat. This is the same a loose wire and is a failure. If the sensor is OK at this point, and will switch from high to low quickly as you move the flame, the sensor is good. Bear in mind that good or bad is relative, with port fuel injection needing faster information than carbureted systems.
    ANY O2 sensor that will generate 0.9 volts or more when heated, show 0.1 volts or less within one second of flame removal, AND pass the two minute heat test is good regardless of age. When replacing a sensor, don't miss the opportunity to use the test above on the replacement. This will calibrate your evaluation skills and save you money in the future. There is almost always *no* benefit in replacing an oxygen sensor that will pass the test in the first line of this paragraph.
    to clean, Everyone seems to use CRC brand "QD electronic cleaner" for both O2 sensors and airflow sensors. it is a special cleaner that has NO RESIDUE in it so when it dries it dries 100% clean with no oils or etc as if it were brand new. For the airflow sensors they sprayed it from a safe distance (as far away as possible) in order to be careful b/c of the sensitive electronics (you don't want to powerblast the sensor close range). The O2 sensor they sprayed the outsides and insides with the same cleaner and saw great results: better gas mileage, better running car, all check engine / warning lights went away.
  3. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
    It has never been hooked up in the 10 years that I have owned it. Who knows before that. I am not even going to try to make what is dangling back there work.
    Just need a part # and a source for the best Bosch price and I'll be good to go.
  4. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
  5. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,654
    E ' ' '/ F
    Merritt Tockkrazy
    I bought the one for my 328 at NAPA. They're in the parts book. You might check there for your 308.
    The Ferrari specific piece is expensive, the generic splice-it-in is cheap.
  6. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    16,164
    Dumpster Fire #31
    SMG
    I'm not a fan of the splice it in option due to the connection increasing the resistance of the signal, that in turn can mess the signal up to the ECU. you'd need a good soldered connection that was light enough to hold the splice but not to heavy on the silver.
  7. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  8. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
    Thanks, Mike
    I just crawled out from under my car. The number on my three wire sensor is Bosch 0 258003009. It also has a 352 15 on it and a 020 in a little circle.
  9. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
    By the way, I appreciate the plugs. They're in. Now I am just dealing with my way too rich settings.
  10. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
    Just out of curiosity, how much was the sensor for our cars with the correct connectors?
  11. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    $130 from AutoPartsWarehouse -- the one I quoted that I got *IS* the correct Bosch sensor for our cars with the correct connectors and wire length! You'll get the exact same part in the exact same box from Rutlands, FoA or Ricambi. I just made a point of finding out what OTHER cars (like the SAAB) use the same exact Bosch O2 sensor that our cars do.
  12. fero
    fero Rookie
    Aug 7, 2007
    1
    NY
    heiley
    Hi Tommy,
    If you are still looking for it ....my friend got cat converter http://www.ecatalyticconverter.com/ferrari-converter.html and just arrived last week. He got pretty nice reinstallation with the help of the mechanic. He found out that reinstalling cat is so easy to do. And I think there's a features also regarding the sensors. Try it there and hope it helps . Goodluck!
  13. Andrew Bolton
    Andrew Bolton Karting
    Aug 20, 2004
    155
    Spring, Texas
    Andrew Bolton
    I know that I'm talking to a moderator here, but I cannot stand when you guys (in a generic sense) do this. (I'm saying this with love an affection mind you) You give a part number and a website. Going to the website, the part number 35496 is blower motors. The part number C5010 does not exist, and the part number C5010-35496 also does not exist. When I go to the Saab page and put in the car's information, I get about 9 or 10 choices. Ugh. Where did you get your number and why doesn't the website you refer us to have it?
    Andrew
  14. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
    #14 Dr Tommy Cosgrove, May 19, 2008
    It worked for me. I bought the O2 sensor and it was thru Mike's info posted here...
    Maybe they changed their website around since last summer when this thread was active
  15. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,160
    SB,CA & Park City UT
    Jeff
    Just FYI after you drive yours another 100K, NAPA has the same part, about the same price-at least for my 328(same part I think). I did a lot of searching for one and that seems like the best price you could get for a direct plug in part.
    Jeff
  16. 50693
    50693 Karting
    Sep 12, 2006
    148
    columbus, ohio
    AS far as splice in sensors go, you probably have a lot of latitude, mid 80's cars had alot simpler ECU's than todays OBD II cars
  17. Dr Tommy Cosgrove
    36,285
    Birmingham, AL
    Tommy
    I appreciate it but I am out of the O2 sensor business for the rest of my life. I bought my car in 97 with it disconnected and it wasn't until last year that I bothered to replace it. I hated it, Now I know why these things get unplugged... WAY too much surging and no amount of adjusting the CO would help either. I just unplugged it and everything was back to normal...
