360 Cold Start Stumble and Rough Idle | FerrariChat
Discussion in '360/430' started by dsevo, Jun 13, 2007.
  1. dsevo
    dsevo Formula Junior
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    I just bought a 1999 360 with 9,800 miles last week, and I noticed that every time I start the car cold, it stumbles and takes 5-10 seconds to smooth out to an idle. After this it runs perfectly, but I'm just wondering if anyone else has the issue, and whether it is something I should be concerned about? Are there any campaigns for similar symptoms? I searched and found that this is common on CS's, but I didn't find anything on regular 360's. Thanks for your help.
  2. rareguitar
    rareguitar Formula Junior
    May 21, 2006
    308
    Virginia Beach, VA
    Brad King
    I have the same thing on my 360 Spyder. I thought I was the only one :). I would like to the answer as well?
    Brad
  3. sezme
    sezme Formula Junior
    Oct 23, 2006
    558
    NJ
    sezme
    Same here on my CS
  4. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    I had/have it on my CS. I am picking up my car today or tomorrow - FNA did a reflash of the ECU's. It's supposed to cure this. I'll let you know.
  5. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,824
    San Jose, California
    Brian Crall would have gladly chimed in with the answer, but is no longer on this forum because of certain people here giving him a hard time.
    Fortunately, this is one of the questions he had already answered here in the past. A well charged battery is supposedly a good defense against this phenomenon, although this part is speculation. What *is* known is that, if you start the car and it is idling rough, just immediately shut it off, then restart. The problem will disappear. This is supposed to be better for the car than just letting it sit there idling roughly.
  6. dsevo
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    Is it anything I should worry about? The car just had a major 1,800 miles ago so everything is pretty fresh. It doesn't really bother me as long as it isn't hurting anything.
  7. SoftwareDrone
    Jan 19, 2004
    7,824
    From what I understand, it's nothing to worry about. If I start my car every other day, it doesn't seem to do it. If I let my car sit for over a week, it does it. Same for some others. Hence the battery charge hypothesis.
  8. dsevo
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    Mine will do it every time I let it sit over night. I don't think it's the battery either because the battery is only 6 months old and the car is driven semi regularly.
  9. Tipo815
    Tipo815 F1 Rookie
    Nov 1, 2003
    3,565
    Newport Beach, CA
    Jeffrey
    Dustin - Normal on every 360 - Stradale included. In fact my Stradale stumbles for twice as long as both my previous 360s did. You'll soon discover all the quirks that Ferraris are known for! That is just one of them. :)
  10. dsevo
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    Thanks Jeffrey. I wasn't too worried about it because my Evo does it, but I just wanted to make sure I wasn't missing something. I love the car, thanks again.
  11. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Have a new F430, 1000 miles, and it happens to my car. Seems to occur if unstarted for a few days. Al
    popimarr likes this.
  12. leead1
    leead1 F1 Rookie
    Nov 29, 2006
    2,828
    Florida
    Lee
    My 2003 360 Modena never stumbled. It always started clean.
    My 2006 F430 does what you describe. Once in awhile it dies and I have to restart the car.
    I accept it, no big deal the car runs wonderfully in a few seconds.
    Lee
  13. RayJohns
    RayJohns F1 Veteran
    7,877
    West Coast
    Ray
    Brian left ferrarichat?
    Ray
  14. RayJohns
    RayJohns F1 Veteran
    7,877
    West Coast
    Ray
    I have put about 6K miles on my car this year (360) and it has never done what you are talking about. Try cutting the power to the ECU for a few minutes when the car is cold (before you start it up) and clear things out. Then fire it up and drive it. See if that doesn't fix the problem. Also, make sure the gas cap is on nice and tight.
    The only thing even close to this on my car is right after I get gasoline for the car. In that case, I fill up the tank and when I start the car and drive away, it will once in a while idle a hair rough for a second at the first stop light. However, it only does it for just a slight moment, then by the time I hit the next stop it's back to purring. It's so mild and brief that I doubt anyone else would even notice it.
    Ray
  15. dsevo
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    I always have the power turned off to the car when I'm not driving it.
  16. jvmax
    jvmax Formula Junior
    923
    Orlando, FL
    I have a 1999 360 with 28k miles and it does the same thing, so mileage doesnt matter. It's just a Ferrari quirk, probably a low battery as many of us dont drive these cars on a daily basis.
  17. dsevo
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    Yep, I'm over it. It would be annoying if it did it every time the car started, but I can live with it when the car is cold. Thanks for all of your replies.
  18. abz
    abz Formula 3
    Aug 27, 2006
    1,439
    PA
    Al
    Ray: Please explain. Thanks, Al
  19. marky1
    marky1 Formula 3
    1,130
    Mark
    Not a good idea apparently. hook it up to a battery tender instead.
  20. Wakebrding247
    Wakebrding247 Karting
    Apr 27, 2007
    76
    Long Island, NY
    IM gonna go with dirty Mass Airflow Sensors... Happens to Vw Bosch sensors after installing Oil Syle filter eliments, I would get some MAF cleaner and spray the eliment down, let them dry for a few hours and see if it clears up your cold start problems.
    Matt
  21. dsevo
    May 7, 2007
    708
    Flower Mound, TX
    Dustin
    Interesting. But the car runs fine after a few seconds. If this were the cause, wouldn't the car run like crap all of the time? I'll give it a try though. Can I buy MAF cleaner at any auto parts store? Thanks.
  22. RayJohns
    RayJohns F1 Veteran
    7,877
    West Coast
    Ray
    If you mean you are killing the power to the car using the switch under the hood, I would not suggest doing that. There is no reason to continually reset the ECU's. It's better to let them learn the engine and keep that data. That might be why you are having problems.
    Reset the ECU's when the car is cold. Then leave things alone unless there is some problem you are trying to resolve.
    Ray
  23. RayJohns
    RayJohns F1 Veteran
    7,877
    West Coast
    Ray
    Hi Al,
    There is a switch in the front compartment on the left (when standing looking at the car). Turn it off, wait about 5 or 10 minutes, then turn it back on. That will clear any data stored in the ECU's. Make sure you do this when the car is ice cold, so that the next time you start it, it will go through it's normal warm up stuff.
    Doing this will reset everything and sort of give the ECU's a blank slate to work from. In my experience, I have found it often helps and fixes strange little things that pop up. You might have some luck trying it. Doesn't hurt.
    Ray
  24. Wakebrding247
    Apr 27, 2007
    76
    Long Island, NY
    If the bosch eliments are the same design as in my other car, they are based off heat, what happens is the eliment heats up and as air passes over it, it gets cooled, and the computer takes the amoutn that it's cooled and figures the air them, on initial cold startup the eliment that heats up has problems getting hot if its dirty and give a false reading, leaving a rough idle.
    You can pick the cleaner up at a auto store, says "Maf Cleaner" on it, its in a spray can and comes with a small spray tip ( similar to wd40)
    I would spray them down a few times, make sure they are good and clean, let them dry for a few hours before installing them again, when you put them back in the car make sure that they are facing the correct direction.
    Hope this solves everyones problems.
  25. ILuv4Res
    ILuv4Res F1 Veteran
    Aug 8, 2002
    6,530
    Fred
    This is a known issue....... Have FNA reflash your ECU's. The air/fuel mixture isn't right when cold.
