CS rough running cold start + pic | FerrariChat
Discussion in '360/430' started by GoodWood, Dec 23, 2004.
  1. GoodWood
    GoodWood Formula Junior
    Oct 2, 2004
    351
    SE Florida/Indiana
    Steve
    #1 GoodWood, Dec 23, 2004
    Up to about 800 mi now, and I've noticed that it's beginning to run rough for the 1st couple minutes before clearing itself out. I know this was discussed before, but what do I do after it starts rough like this? Do I just let it idle for a time, or should I attempt to bring the revs up? It really seems to choke badly if I do that.
    Also, I had some "elective cosmetic seat surgery" performed Wed on my driver's seat, and I'm happy to report that the "patient" is doing better than ever. The automotive upholstery guy cut the thigh bolster in about 1/2 lengthwise, and replaced the ultra-firm foam with foam that's less dense, and more compliant. Now I finally can get comfortable in my racing seat! It gave me that extra inch I needed. Looks exactly as it did before too.
  2. xpresso
    xpresso Karting
    May 9, 2004
    110
    Paradise Valley, AZ
    The rough start maybe due to fact that not all cylinders fired up.
    It has happened to me on one occasion and the check engine light stayed on.
    I just restarted the car and it ran fine after that.
    There are many threads talking about this problem. Since it has happened only once...I have not had it looked at yet...I have about 900 miles on my CS.
    Unfortunately, I can't tell you much about cold start out here in Scottsdale, Arizona.
  3. ben, lj
    ben, lj Formula Junior
    Aug 23, 2004
    594
    Another great pic Steve. And, I'm really glad you got the seat thing handled since I feel partially responsible for getting you into the Stradale.
  4. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    mine has done the rough start thing a couple times. i just turn it off, wait a second, and it starts up fine the second time.
    GORGEOUS picture in the snow! we haven't had enough snow here yet to get any decent snow pics. we got a couple inches early this week but they melted pretty quick and it hit 60 today with a rain storm going on now - so ther'es nuthin' left. presumably in january we'll get our due.
    glad to hear you've got your seats "fixed". enjoy!
    doody.
  5. GoodWood
    Oct 2, 2004
    351
    SE Florida/Indiana
    Steve
    #5 GoodWood, Dec 23, 2004
    Honestly, I never tried that, I've always just sort'a "rode it out" until it cleared itself, which usually took a couple minutes. I will try turning it off, then restarting. These are a couple "post-op" seat shots I thought you might enjoy seeing. Man, you guys must'a missed it, we got 6 inches of theweeffing white stuff last night. Will try to get a better shot of the car, tnext time showing the all the snow in the bakckground. We had 1ft deep drifts too. Thought about taking the CS out.....that's all I did, THINK about taking the CS out! Hell, it barely made it out of the garage!
  6. SURF
    SURF Guest
    Nov 6, 2004
    47
    North Hampton,NH.
    Is That Titanium?
    Surf
  7. mrmckay
    mrmckay Formula Junior
    Jul 14, 2003
    488
    MD, USA
    Chris
    It has happened on occasion to me as well. I do what Doody suggested and it has worked every time.
    Regards,
    Chris
  8. udalmia
    udalmia Guest
    yep peter :)
  9. udalmia
    udalmia Guest
    Steve,
    I had the problem you mentioned a couple of times, took the car to the dealer and they checked the ECU, engine misfire, common thing, just shut the car down and start it up again, hold the start button down for a longer time that usually fixes it
    when the temperature is as cold as it is now, i let the car warm up for about 10 minutes, then baby it around below 4000 rpm
    I honestly wouldnt think about driving it around in Indiana if I were you with all that snow the traction on those tires on snow is terrible believe me I have experienced it first hand
  10. Doug.
    Doug. F1 Rookie
    3,295
    Las Vegas, NV
    Its probably "choking" like that because all of the cylinders havn't fired up yet. Some other owners have had the same problem as you, and the check engine light stayed on. You shouldn't have to worry though, just take it to the dealer if the problem persists. Probably just engine misfiring.
    -Doug
  11. tubeguy
    tubeguy Formula 3
    May 21, 2003
    1,041
    Upland California
    Kevin Deal
    I was told that once you turn on the key do not hit the start button until the pre-check sequence on the dashboard stops changing.
  12. Doody
    Doody F1 Veteran
    Nov 16, 2001
    6,099
    MA USA
    Mr. Doody
    i'm psycho-religious about this, and it still will do the misfire thing. imo, they're not related.
    doody.
  13. GoodWood
    Oct 2, 2004
    351
    SE Florida/Indiana
    Steve
    #13 GoodWood, Dec 26, 2004
    I'll have to wait til a while before driving it again. I'll wait an extra few secs after the checklist says OK, then I'll also hold the starter button down an extra "one thousand one" count, and see if that helps. I do know trying to feed it any gas at all only makes things worse.
  14. 720
    720 F1 Rookie
    Jul 14, 2003
    2,623
    So. Cal and No. Utah
    Rick
    skinner's pigeons :) i find that if i lower the driver's side window and wave to my wife at the same time i press the start button that it works every time. LOL.
