Cooling system overhaul | FerrariChat
Discussion in '308/328' started by GeoMetry, Apr 24, 2008.
  1. GeoMetry
    GeoMetry Formula Junior
    Apr 14, 2008
    471
    Virginia
    Richard
    I am about to start the rejuvenation of the cooling system on my 1985 308. The hoses are old and the radiator has a small leak. So I figure the first thing to do is put it up on jack stands. Then I wonder if I should drain it first. I read in another thread (about burping the cooling system) that when refilling the cooling system it helps to keep the rear end elevated (or was it the front end) until the coolant comes out the little air hole on the radiator. Is there a similar procedure when draining the system? Is there anything I should do before draining the system? Are there any tricks to draining the cooling system? I have replaced a 308 water pump before but it was several years ago. What is missing from my parts list for this job?
    • Water Pump (I read something about an upgraded water pump)
    • Water Pump gasket
    • Thermostat (test it before installation)
    • Hoses (This is my biggest question mark. Does someone just sell a complete set?)
    • Hose clamps (any recommendations here?)
    • Coolant
    • Distilled water
    • Water Wetter?
    • radiator cap
    • Water temperature sending unit (do you think this is necessary?)
    I will need to remove the radiator in order to have it repaired. Any advice on that task? What about flushing the system, when do I do that?
    I have found the following threads with useful information.
    Found my Overheating Problem
    308 Overheating?
    Another 308 Coolant Leak Question
    Redline Water Wetter - nice difference
  2. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Easiest way to drain is via the twin pipes under the battery - there is a steel panel bolted to the car you can just unbolt, and there are the pipes.
    I would replace every hose section with either Silicone sections or Gates Green-Stripe with strong ABA (or better) hose clamps. A radiator cap you just toss and replace with a Stant or OEM unit rated for the correct BAR pressure.
    To remove the radiator, you'll probably want to remove the bumper, hood, grille, and front valence. It 'might' be done without valence removal, but since you're also doing new hoses you'll want easy access to the bottom of the radiator and the pipes that go to/from it. Radiator removal is fairly simple with the valence out of the way - there are bolts on the BOTTOM of the unit that connect the radiator to the A/C condenser unit and the car frame. I'm assuming the temp sending unit you're referring to is the fan switch threaded into the bottom of the radiator? You'll want to replace that as well with a new Bosch unit for an Audi/VW rated for 185 Deg. F.....
    Your cooling system is mostly aluminum, so I would definitely NOT just pour 100% pure water in it - you'll have internal oxidation that could be VERY bad for the car.
  3. spirot
    spirot F1 World Champ
    Dec 12, 2005
    14,532
    Atlanta
    Tom Spiro
    If you were just working on the radiator I would not remove the front valence... but I think you will find it much easier if you remove the inner fender well, and the lower valence... it is removed by undoing the bolts that hold it on from the inside ... not a fun thing to do. the last one is right by the wheel arch... and is a bastard to get at.
    Once you have the valence off, its simple to remove the ac condenser, then un bolt the two hoses, bottom first then take the top off. then jack the car up from the back... voila you'll have coolant all over. I flushed the system at the same time and ran the hoses unto a large bucket to catch it all.
    You can take the radiator out with out taking the valence off, but putting it back in is more difficult... very tight. make sure you keep the rubber grommits as they keep the radiator from moving around in its mounts....
    pretty easy to do really, just takes time. getting the hoses under the plenum is difficult with out taking the plenum off, but again that is pretty easy... you generally dont loose any gas from the injectors...
    I always use watter wetter... better to be safe than sorry.
  4. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    Front Valence? Is that basically the entire bodywork below the bumper and forward of the front wheels?
    I have the car up on jack stands and I have removed the front wheels. I also removed the small panels that provide access to the heater blowers. I am putting the small parts in zip lock bags and labeling the bags.
    I could use a bit more guidance getting the valence off. Do I remove the spare tire well?
    What about those upgraded water pumps from www.nicksforzaferrari.com are they worth $650?
  5. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,553
    NY/SC
    David
    You may already be well aware of this, but just to be sure, be very careful w.the rad and working around it, esp turning a wrench! Those fins are fragile!
  6. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    Hi Richard,
    I just did my 77 cooling system. Gates gren stripe hose is available from Napa as are "constant torque clamps, at $5 each).
    a fellow chatter, (luckydynes???) has a hose kit for sale in the adds section and his marine clamps look even better than the constant torque ones from napa.
    FWIF, 3/4 coolant hose is a serious major *****, (read-too small) to get on the recovery tank and engine nipple, i think 7/8ths would be a much better choice, it sure does the trick for the crankcase vent system.
    Others have suggested installing a "flush T" in the coolant hose to-from the heater that is sprouting from the pipe under the front access panel - this sounds like a less messy way to dump the coolant, next time.
    Look verrry closely at the aluminum coolant pipes as you clean them up for re-use. I had a very fine pinhole rubbed through at the crank pulley and a near disaster, rub through at the pipe by the filter mount bolt, next to the front intake manifold bolt. Allow time to get them welded up by a pro.
    When refitting the pipes and hoses, mark the pipes where you want the hose to end. In particular, you need at least one and one half "hose clamp widths" past the bead on the pipe. It is easy to loose track of how far the pipe is into the hose while you are trying to arrainge pipe clearance from bolts, nuts and other, potentially damaging things. YOU GOTTA HAVE CLEARANCE. Sometimes you can attach the hose coupler piece onto the pipe and use the pipe with the hose attached to force the hose onto the radiator or another hard to reach piece.
    PRESSURE CHECK THE SYSTEM WHILE IT IS UP IN THE AIR AND EVERYTHING IS ACESSIBLE, WHEN TIGHT, WARM IT UP AND retighten the clamps, and CHECK AGAIN. Sorry, i usually don't shout. (ask me why i shout :)
    In addition to the water pump gasket, you might want to get the o ring that goes between the lower thermostat housing and the block, because as you loosen the water pump, the housing will get loose and this o ring will be loose, too.
    Don't be tempted to skip the thermostat, o ring and gasket, particularly if you are curently enduring slow warm ups. I changed mine and was plesantly pleased at the rapid warm up of the coolant and the proper running temperature of about 190 F. Previously it took a lot of miles to bring the temp up and it stabilized at about 165-170 F. The oil took for ever untill i installed an oil thermostat - but that is another story.
    Definitely do the distilled water. I think the water wetter is worth the few bucks, as is phosphate free coolant.
    If you are going to yank the rad, check the fans. if in doubt, either overhaul them, replace them if you are a purist; or skip the marginal stock stuff and install a couple of 12 inch spalls.
    I have no experience with Nick's killer pump and have no doubt that it is a superior pump, but unless you live in a hot climate or track the car, the stock stuff will likely suffice, particularly since you will be inthere doing belt changes every 30k or 5 years anyway. If you are flush, it would be a nice upgrade, but i would go with heater hoses and radiator preventative maintenance first.
    This is sure a lot of verbiage generated by my first major, hope this helps,
    chris
  7. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    There are threads somewhere regarding removing the valence (front spoiler) - there are a row of bolts along the inner seam that attach the valence to the front quarter-panels, seven per side if I recall correctly. Once you find, and then remove these bolts, the valence slides out toward the front of the car like a desk drawer - well, sorta. You WILL need help to coax the spoiler off, as well as help with the bolts and whatnot.
  8. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    M.James -
    I will probably spend most of the available time today trying to get the valence off so I appreciate that info.
    chrismorse -
    I found a fuel line kit but not the Coolant Hose Kit. I'll try a few more searches. Maybe I'll do the fuel lines too.
    Does everyone pretty much agree on the Gates Green Line Hose? What about buying the hoses from the Ferrari dealer?
  9. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    silicone is a good alternative if you want to add some color or you could get black silicone but some people may not care for the shine (not as flat black looking as rubber)
    only if you have too much money
  10. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    Hi Richard,
    I guess the stuff in the adds is just fuel hose, but i would still ask him for the hose clamp source so you could get those spiffy marine clamps, or you could go with the constant torque clamps from napa.
    Almost every thread i've seen on cooling system work recommends the green stripe hose, also from napa in 3 foot lengths. Buying from ferrari will probably cost 5-10 times as much as the napa stuff.
    Doing the fuel filler, cross over, evaporative and supply hoses is very cheap insurance. I think a lot of ferrari fires are caused by leaking hoses.
    hth,
    chris
  11. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,930
    CA and OR
    pit bull
    Excellent advice and watch ALL these areas (plus alternator and water pump pulley) for inteference during reinstallation .. think I wrapped a piece of hose around the outside of one of the pipes just to make sure it didn't rub thru where the pipe goes down over the bell housing.
    Also it's not me that has the silicone hose kits.
    Plenty of excellent advice here . .. good luck.
    Sean
  12. spirot
    Dec 12, 2005
    14,532
    Atlanta
    Tom Spiro
    Sorry, have not checked in... yes the valence is the spoiler etc... the wheel wells fiberglass cover has to come out... if they do? I cant remember, they may be riveted in, if so dont sweat it... but it makes a huge help with more room to work. after that its very strait forward ...
  13. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    I have removed the metal plate under the car just behind the valence, the front bumper, grill, battery, spare tire well, and the access panels in the front wheel wells. I am now working on the valence. I have removed the 7 screws from each side of the valence (where the valence attaches to the fenders) and 6 screws under the car in the large flat area of the valence. The only thing I see holding it is what appears to be something like caulk. I am sure that it is not this caulk holding it on. So what else do I need to do to get the valence off? How do I separate the valence from the fender? Is there something holding it along that seam other than the screws I removed. I will attach some pictures soon.
  14. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    #14 GeoMetry, Apr 25, 2008
    M.James - A little nudge and a wiggle and the valence slides out like a drawer just like you said. Thanks
    I can see how removing the hood (is that what we call it?) would make getting at the radiator quite a bit easier. Are there any tricks to taking the hood off? I am concerned about getting it properly aligned when I put it back on. Is that difficult?
    The brackets for the heater fans are broken of course. I remember fixing those on my previous 308. Is there a generally accepted solution for that problem?
  15. 350HPMondial
    350HPMondial F1 Veteran
    5,194
    Edwardo
    #15 350HPMondial, Apr 26, 2008
  16. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,553
    NY/SC
    David
    I've no idea what these silicone hoses from the usual sources used here cost but you may try a company called Nashville Rubber. They do silicone hoses and I've used them for my jetskiis. The folks there are very knowledgeable and helpful.
  17. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    #17 GeoMetry, Apr 26, 2008
    I drained the system and removed the radiator. I also removed the two aluminum pipes that the radiator connects to. The Ferrari dealer recommended a particular radiator shop. (Not the closest one unfortunately) I suppose I should probably listen to their advice. What about all the hoses associated with the heating system, should I replace those too? They look ok. How difficult is it to replace all those hoses?
    Is the elbow coming off the top of the radiator the only molded hose section? I am guessing that the molded hoses will probably be hard to find in silicone. Do they make silicone hose in the right sizes for the heating system? What are the advantages of silicone hoses?
    Now I am going to start removing hoses in the back of the car. Do you see any issues to address in this picture? I see the A/C belt looks a bit twisted. (The A/C doesn't work so I will probably pull it anyway)
    What is the sequence of removal here? Since I am going to do all the fuel lines too, I think I will drain the fuel tanks and remove them first that should give me lots of room to work.
  18. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    Fuel Tanks drained.
  19. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    I could really use some encouraging words.
    This is perhaps a bit harder than I expected. I now have the passenger side fuel tank out and the coolant pipe (#35) that runs up to the thermostat. I also removed the A/C compressor and the timing belt covers.
    I have not yet attempted to get at the coolant pipe on the other end of the engine (#34). Is that difficult? I also see in the diagram another coupling (#26 & #27) in each of the long pipes that run to the front of the car. How do I get to those?
    This week I will order a new water pump. Buy a length of Gates Green line silicon hose and drop the radiator at a repair shop.
    I keep finding more problems which is both good and bad. I discovered that the pipe running up to the thermostat (#35) has a spot where something, I think the gas tank strap, has rubbed almost all the way through. One of the timing belts is noticeably looser that the other. The engine is pretty dirty too so I guess I'll spend a few minutes cleaning up the worst parts of that mess.
  20. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    If it's the horizontal fuel tank strap causing problems and you think it may continue to do so in the future you might consider removing it and leaving it off. The Euro cars only have a vertical strap for both tanks. The second horizontal strap may be some overkill due to a U.S. regulation of some kind. Certainly two straps must be a safer more secure way to hold the tanks in but it may, in reality, be a non-issue.
  21. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    I'll tell you what I like that idea, because it was probably the part I had the most trouble with and I was a bit worried about how I was going to get it back on.
  22. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,687
    North shore, MA
    THE Birdman
    That is common. If it has not worn through, make sure it doesn't touch anything when you re-install it. Some people even put a piece of hose over the part that likes to rub "just in case" to proect it in the future.
    If it looks dangerously thin, it can be repaired by a welding shop. No biggie. Needs to be someone that can weld aluminum. Probably cost you $10. One of mine was repaired by a previous owner.
    Now is an excellent time to slap in a new set of timing belts/tensioners. Keep in mind that the tension on the timing belts will appear different at different times in the rotation of the engine due to the varying load of the cams. Put a socket on the big bolt on the balancer and turn the engine over and watch what they do. There are some good timing belt threads. Yes, many people will say that you are better off to do a full major rather than just timing belts, but if the timing belts are old and you are in there anyway, it is about $150 to do the timing belts and tensioners. Money well spent for peace of mind.
    As for the hoses, I prefer the NAPA rubber hose. First of all, it looks OEM. Second, it is stiffer and easier to wiggle onto the pipes than silicone because it doesn't collapse. (Silicone is so soft that when you try to push it onto a tube, it collapses. You need a lot of lube.) The original hose lasted 20+ years and so will this NAPA hose. I had to use some LONG silicone on the Mondial because I couldn't get rubber hose that long (the Mondial has flexible hose from front to back unlike the 308 which has hard tube) and it was a pain to work with.
    As for the short little hoses under the plenum which really suck, they are actually easy as cake once the water pump is out and you can do them from the end of the engine. You DO NOT need to remove the plenum if you are taking out the water pump.
    I did all the hoses on both of my cars last year (Mondial QV and carb 308) and it was pretty straightforward. Just be patient, don't get frustrated....take a break when the thing pisses you off (it will!) and don't skip one because it's too hard. Do them all and you will know that the car is good for another 20 years.
    I will admit...I have a lift and it makes all the difference. Some of those hoses would really suck doing it on jackstands. I have said this a hundred times and I'll say it again: lifts are not that expensive and if you work on your car, it will be the best tool you ever owned and you will never ever ever regret buying one.
    Birdman
  23. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Where did you get long silicone hose? Was it special order? All the places I've seen seem to limit length to one meter.
  24. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    #24 doug328, Apr 28, 2008
    I just got thru doing this job on my 328. Looks like you are at least half way thru the job with the radiator and some of the pipes out of the car. For me to get the radiator out I removed the front aluminum grill, lower spoiler and the front hood, making it real easy to access the radiator. The fans came out and then the brackets for the radiator were removed making it easy to lift the rad out. I also had a wear mark on the aluminum pipe on the right/pax side of the engine. A friend that does aluminum fixed it and pressure tested it for a 12 pack of beer. Sent the radiator to a shop where they boiled it then ran rods down all the cooling tubes to make sure they were all clear then reassembled it and pressure tested it. Cost for the service $90.00. I went to the local hardware store (ACE) and got some self-adhesive foam tape to fit around the radiator to close the air gaps. I believe offical Ferrari foam costs over $100.00 the stuff I got was $15.00 and looks OEM.I used Gates hoses (1 5/8" I.D. x36") for the pipes/radiator connections and 3/4" x 15" for the smaller hose from the expansion tank to the aluminum pipe by the oil filter. And "while I was there" I replaced the thermostat/gasket, expansion tank cap (0.9 bar) and the termoswitch for the fans, all these parts were purschased from Dennis McCann, which seemed to have the best prices. All my clamps were in good shape so I cleaned then on a wire wheel and resued them. To refill, I had the front of the car slighty higher than the rear and had the vent screws on the thermostat housing and for the radiator open when filling (heater valves all the way open as well) used distilled water and coolant rated for aluminum radiators plus added a bottle of that "water wetter". slowly filled the system until coolant started to come out of the vent screw on the radiator, then closed that screw and continued filling thinking that coolant would come out of the thermostat vent, it never did, the expansion tank filled up before any coolant came out, so I closed that one then started the car and let it warm up until the thermostat opened and the fans came on, at which point I opened the radiator vent screw and bled more air while the car was running. Shut the car off, checked for any leaks at the hose connections ect. and then started the car up again and did a second bleed. After putting over 400 miles on the car since this job not sure if the "water wetter" works or not. Bottle says it makes systems run up to 20 degrees cooler but giving the "accuracy" of the Ferrai gagues its had to tell. I do notice the needle reads a little more to the left than before, so who knows. There were no problems with my cooling system, but after 20 years I felt it could'nt hurt to overhaul the system, for piece of mind if nothing else. Good luck with the rest of your project and enjoy the ride.
  25. GeoMetry
    Apr 14, 2008
    471
    Virginia
    Richard
    Thank for the encouraging words that really is just what I need now.
    I ordered the Water pump from nicksforzaferrari.com. (Ouch)
    I was looking around for the timing belts and tensioner bearings. The dealer wants $290 each for the tensioner bearings. At allferrariparts.com they quoted me $85 each for SKF brand tensioner bearings. Looks like I will go with allferrariparts.com unless someone here has an objection to SKF brand tensioner bearings.
    I see that there are a couple of options when it comes to the radiator cooling fan thermoswitch, either 160 degrees or 180 degrees. What is the standard temperature and why would I go with a different temperature from the standard? I assume that in addition to this thermoswitch there is a water temperature sensor somewhere, is that right?
    Does anyone have an opinion on the fuel hose kit that our fellow FerrariChat member Desire308 is selling?
    I'll probably get the thermostat, gasket and Expansion Tank Cap (0.9 bar) from allferrariparts.com as well.
