002C | Page 5 | FerrariChat
002C
Discussion in 'Vintage (thru 365 GTC4)' started by Napolis, Jan 8, 2005.
  1. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,043
    San Marino, CA
    L. Wayne Ausbrooks
    Exactly.:D How're you doing, Stu?
  2. dretceterini
    dretceterini F1 Veteran
    Apr 28, 2004
    7,289
    Etceterini Land
    Dr.Stuart Schaller
    Fine, thanks!
    As beautiful as the P3/4 is, I still rather have the 166. I LOVE old Ferraris (and Alfas, and "etceterinis", and....)
  3. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,388
    The Cold North
    Tom
    Very cool..again thanks so much for the pictures
  4. Boudewijn
    Boudewijn F1 Rookie
    May 15, 2003
    4,133
    The Netherlands
    Boudewijn Berkhoff
    Beautiful rare pics.
  5. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,800
    Santa Fe, NM
    love the guts! is that the engine stand you found? did you ever tell us the story about it, or did I miss it?
    Bryan
  6. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Sal came up with that one but his lips are sealed as to where he found it. The part that attaches to the engine is even stamped with a serial #!
    Note the very rare original factory original yellow indexing paint he used to mark the position of the timing chain gear.
    In the background of the P4 wheels you can see J6 at Leguna.
    The SF Shield is a hand painted test that Greg made to show me what it will look like when he paints it onto the car. (He's going to practice his lines for a while)
    Note the period correct but non original switch we mounted to turn on the non correct electric rad fan.
    The purists will really hurl when we mount the increadible, period correct Jeager rally clock Sal found. (It did come off a one of a kind Ferrari but his lips are sealed about how that happened as well)
    Next week John is coming in and we're going to build a buck for the MM Nose.
  7. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    Awesome.
    -Chris
  8. Boudewijn
    Boudewijn F1 Rookie
    May 15, 2003
    4,133
    The Netherlands
    Boudewijn Berkhoff
    #109 Boudewijn, Jan 23, 2005
  9. tritone
    tritone F1 Veteran
    6,883
    On the Rock
    James
    in the photo showing the crankcase interior: what is the purpose of the bolted-on plates on the side and covering a portion of the interior? some sort of oil control?
  10. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I have to take a closer look but I imagine you're correct.
  11. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    That is the sump, not really the crankcase (IMO ;)) and yes I assume those plates are all about controlling oil surge.
    Pete :)
  12. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    In looking at the MM nose, I noticed that the hood scoop was slightly lower, a bit more squared off, and farther back than it is now. Not to make more work for anyone or anything...
    -Chris
  13. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    That is true but I like the Turin GP duct better so I'm keeping that.
  14. vintageautomobilia
    Jan 28, 2005
    3
    CAMBRIA, CALIFORNIA
    PETER ZOBIAN
    I think the Motto body is still in Briarcliff Manor, NY, owned by Edmond Williman.
    Here is a picture of a Motto bodied car I have. It also has a large diameter oval tube frame by Gilco. Years ago I talked with Stan Nowak about it.
    It was built in 1949 and it's a Motto-Cisitalia spider corsa. I'm looking for its history in Italy prior to 1954. Any help would be greatly appreciated.
  15. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Very Cool!
  16. Gilles
    Gilles Karting
    Aug 10, 2003
    236
    South of France
    Boudewijn,
    I have reading somewhere that this body was put on a Jaguar (Still exist with Ferrari shields !) when 002C get the motto's body. It's true or false ?
    If it is true the rear is very different that 002C actual...
    If it is wrong from where come the body of this Jaguar ?
    Thanks again for your maginficent pics...
    Gilles
  17. Boudewijn
    Boudewijn F1 Rookie
    May 15, 2003
    4,133
    The Netherlands
    Boudewijn Berkhoff
    #118 Boudewijn, Jan 29, 2005
    Gilles, I think you are referring to the Ferrari-Jaguar Biondetti Special of Clemente Biondetti of 1951. It was based on a 166 chassis and had a 166 SC coach but I don't know the S/N of the chassis nor do I know where the 166 SC lookalike body came from. The engine type was Jaguar XKC, the company he drove for at that time.
    Best
    Boudewijn
  18. vintageautomobilia
    Jan 28, 2005
    3
    CAMBRIA, CALIFORNIA
    PETER ZOBIAN
    Somewhere in my memory bank, I recall that Biondetti's Jaguar Special body was also done by Motto. Sort of a larger Cisitalia D46 (also by Motto).
  19. Boudewijn
    Boudewijn F1 Rookie
    May 15, 2003
    4,133
    The Netherlands
    Boudewijn Berkhoff
    I think you have the Gilco "Cisitalia 204" Spider Motto ex Paul Farago, Max Goldman? Could you give the S/N (just for the books)?
  20. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    #121 Napolis, Jan 29, 2005
    That would make sense esp. if he used a bit of 002C's SC body to do it as he would have it laying around after removing it to do his re body.
    We're moving right along building the MM nose for 002C. We noted two interesting things. The MM nose will provide much more cooling as its grill inlet is bigger and the size of the "egg crate" looks best/right when you make it the same size as the badge/Cavallino.
    We're giving J6 and 0846 a good clean for the Canadian International Auto Show.
  21. Boudewijn
    Boudewijn F1 Rookie
    May 15, 2003
    4,133
    The Netherlands
    Boudewijn Berkhoff
    You are moving fast Jim! Nice artistic work.
  22. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Thanks! Your photo was the inspiration. We're going to make up the nose, fit it on the car and then cut the grill opening so that it looks straight. We also sent Borani the final measurements they needed to make us a spare set of wheels. My wheels match the original Ferrari shop drawings which is nice to know.
    Best
  23. vintageautomobilia
    Jan 28, 2005
    3
    CAMBRIA, CALIFORNIA
    PETER ZOBIAN
    Yes, it is the ex Paul Farago, Max Goldman Gilco Spider Motto-Cisitalia, however I've never found a s/n on the chassis frame. This car has had two non-original motors over the years, and attendant changes to the frame, so maybe the s/n was erased.
    I bought it in Pontiac, Michigan in 1973, and have spent the last 30+ years finding all the proper parts for it. About all I'm missing now is the Jaeger tachometer (rev counter). This has "zero" at 1 o'clock and "70" at 11 o'clock, and is a plain unit similar to that used in the Bugatti supercharged type 57, Talbot-Lago, and the early Abarth 207A by Boano.
    I have an early Ferrari tach I'd trade for the one I need.
    You appear to know this car. What can you tell me about it?
    Any information would be greatly appreciated!
    Thank you!
  24. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    What a great story and photos. Every time I view this thread I sense the passion of the restoration.
    Many thanks
    rt
