308 front right clunk?
Discussion in '308/328' started by Colorado308, Oct 12, 2017 at 2:39 PM.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. Colorado308
    Colorado308 Rookie
    Sep 22, 2014
    23
    Colorado
    Brian D
    I have a "clunk" coming from the right front whenever a bump is hit at speed, say over 20 mph. It only comes from the front right and not the front left. Lifted the front end and grabbing the right front wheel at 12 & 6 found a very small amount of play and then 9 & 3 found more play. Hoping it was just bearings I did a full remove and replace of everything (races and bearings) and then reassembled. This eliminated play along the vertical axis (12 & 6) but not along the horizontal axis (3 & 6).
    On further inspection I can now see play in the tie rod end. This will be replaced next. My question is: are there other items which potentially could be causing this play? I will inspect ball joints while in there but anything other than that? The car has 61K on it and the left front is solid as a rock. would like to hear if anyone else has similar experience in fixing this a similar issue. As always, thanks in advance for reading and any <ahem> constructive suggestions...
  2. waymar
    waymar Formula Junior
    Sep 2, 2008
    660
    Northeast, PA - USA
    Wayne
    Any associated suspension part. Sway bar, sway bar link,etc
  3. dflett
    dflett Formula 3
    1,248
    NY
    David
    If it's the right hand side, that is the side with the bushing in the steering rack. Could be the bushing has disintegrated
  4. cmt6891
    cmt6891 Formula 3
    1,157
    Encino, Ca
    Carl T
    Since you will be doing the tie rod and ball joint, while you're in there might as well do all the bushings(control arms and shock). Do both sides, since you will need to do a full suspension alignment afterwards. Inspect the steering rack bushing as mentioned and replace if needed. You don't want to take it apart again just for that. On the outside chance it could be the shock needing rebuilding.
  5. wildcat326
    wildcat326 Formula 3
    1,390
    Chicago, IL
    Justin
    First thing first, are your wheel nuts properly torqued? I assume you'd know if the wheel was loose on the hub, as opposed to the hub getting free play, but worth an easy check.
    I'd try to pin down the problematic issue first before taking more things apart for restoration, like a full control arm bushing job; just adds more variables to confuse the problem point. That said, ball joints can start to go, drop link connections and bushings, remove and inspect your steering rack, also the rack mount bushings, and also see if you've lost any control arm shims through the frame slots below the control arm attachments.
  6. Colorado308
    Colorado308 Rookie
    Sep 22, 2014
    23
    Colorado
    Brian D
    Dflett- when you say "bushing in the steering rack" do you mean the rack support bushing (part #103287) or some other bushing?
  7. Tired of seeing this ad? Upgrade now
  8. dflett
    dflett Formula 3
    1,248
    NY
    David
    No, I mean the plastic bushing inside the steering rack casing that supports and centers the end of the rack on that side. It's under engineered and often breaks leading to play in the right hand side tie rod connection. The solution is to rebuild the rack with either a brass or delrin replacement bushing.
    If you disconnect the tie rod from the steering knuckle, you'll feel the tie rod loose inside the rack if the bushing has deteriorated.
    Regards
    David
  9. Colorado308
    Colorado308 Rookie
    Sep 22, 2014
    23
    Colorado
    Brian D
    Got it - thanks. Appreciate the clarification.
