308 Gtsi restoration+EFI.... | Page 2 | FerrariChat
Discussion in '308/328' started by MickyB, Feb 24, 2017.
  1. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    The brake pulliies look great. Won't make the handbrake work but still..:)
    Crowndog likes this.
  2. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    #27 MickyB, Mar 13, 2017
    Just finished the setup of the engine speed trigger wheel.(60-2)
    It looks good and i calculated well as no need to modify the oil pump housing,
    there is enough space so the wheel turns freely :)
    Of course all parts been plated(black,silver ,yellow) ,and the full assy has been dynamic balanced too!
    Next i will make the bracket design for the hall sensor but will need some time as i'm focusing to the disassemby of the body work now so it can go to the metal worker and painter asap.....
  3. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    Nice set up on the trigger wheel. Is that custom or modified off the shelf?
  4. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    Basicly it is custom for the 308. We design many engine parts so i have a huge selection of engine conversions made before like audi 5cyl alfa bmw M3 S14B23 through toyota 4age to vw 1.8L ......So it was not a big issue for me to make it :).
    We made a cad drawing and then laser cut the wheel, after made a small lead to the ferrari wheel , so both are on the same center.
    Then the sensor wheel grind to the final dia and balanced......
  5. warrenz
    warrenz Karting
    Aug 11, 2014
    95
    Sweet S Ranch
    Regis Bragg Stevenson
    really nice stuff,think you can ditch the accumulator w/efi,can we order these nice parts for our cars?
  6. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    The plan is to keep the accumlator, some of the older efi cars had those too if i remember
    well from early 90' and late 80'. I think bmw e30 M3 for example. It takes out the vibration
    from the fuel system so you have a more constant fuel pressure....
    If something needed just contact me...
  7. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Looks great! Is it yellow cad or colored Zinc?
  8. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    i think in english :), they are black/yellow/silver Zinc.....
    the yellow cad is not allowed here anymore as i know....
  9. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    #34 MickyB, Mar 19, 2017
  10. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Certainly classier then the rubber bands found on most other cars.
  11. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    Of course, but It needed several parts to make ,design and assemble! It took me many hours to get back them to life again too :)!!
  12. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    #37 MickyB, Mar 23, 2017
  13. scudF1
    scudF1 F1 Rookie
    2,866
    Long Island, NY
    Billy
    I assume this time it wasn't intentional. Lol
  14. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    Wow, did you take the motor mounts apart? There's a lot of spring pressure in there I thought. How did you take them apart?
  15. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    it is not a really big task, just put it in a big vise safely and drill out the spot welding,
    from the bottom with a spec drill. And only remove material from the upper sheet,
    so you can weld it back when it is put back together again. you may see the holes on the pics..
  16. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    #41 MickyB, Mar 29, 2017
    I think the burned resistors are not uncommon in the blowers, as it was the case
    in mine too. So i took them apart and repaired them.
    The hardest part was to take the 2 spring style fixers to remove and put back holding the
    wheels.
    I kept all parts they just cleaned and plated only the resistors and the cables are new
    I even glued the spal lebels back :) ....
  17. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,181
    Gold Coast, Aust.
    Patrick
    Awesome job!
  18. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    Great job. My issue was worn motor brushes. Easy fix.
  19. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    yes "easy" :)
    All parts i took apart looks like the car had very low kms but stood for a long time
    without moving , having only surface rust etc...
  20. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Looks great!
    So, how did you determine the actual resistor specification to replace it? Or are the cables available complete with the resistor?
    Also are you aware of hydrogen embrittlement? Comes when you electroplate, likely a problem with springs more than anything.
  21. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    We make our wiring in house. My company makes race car engines,wiring looms,ecu programing etc ...it is a very simple task for us!
    We could measur the resistor as 1 of it was almost ok. (also the spes was visible)
    Regarding the hidro problem i don't care!!!
    It is better to remove the rust and plate it then leave it like that and wait the rust eat it+ looks much better! In 100 bolts,washers maybe 1 fails at the recommend torque when tightening so my experiences are not too bad.....
    Brackets small bolts, fixtures, small springs that like in the blower does not suffer too much
    as they has little force to handle....
    Also the guys use the latest german tech so i'm not worried too much .....:)
    Mechanical Dad likes this.
  22. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    Just asked the Engineer @ the plater company about hyrogen embrittlement, to be sure.
    He told me that they use some inhibitor or additive etc, so it is not an issue any more.
    They make heat treated bolts etc for huge car manufacturers too! They use this tech long time ago without problem.
  23. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    Always good to hear! Worst effect would be on the springs. Only way to handle it in the old days was a heat treatment with some critical temps and times.
  24. MickyB
    MickyB Karting
    Aug 21, 2016
    90
    Hungary
    #49 MickyB, Apr 14, 2017
  25. mwr4440
    55,931
    Bavaria, The 'Other' Germany
    Mark W.R.
    Question on the belt drive pulleys.
    On my '81 the part of the pulley that goes around the shaft, extends back much further than other model years. The pic above on Page 1, Post 12 seems to show this.
    My car did not have a washer between the drive gear and the outer bearing.
    Question is: "Should there be a washer there?"
