350/400GT thread
Discussion in 'LamborghiniChat.com' started by FredParoutaud, Sep 5, 2007.
  1. I have started the new week 1 FerrariChat Update poll, please vote... http://www.ferrarichat.com/forum/threads/ferrarichat-com-update-week-1-poll.560487/
  1. Olivier NAMECHE
    Olivier NAMECHE F1 Rookie
    4,126
    Belgium
    Olivier
    mistake
  2. rmolke85
    rmolke85 Formula Junior
    Mar 11, 2013
    402
    I meant the 2+2 cars. Still same chassis there too?
  3. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    yes still..., the same as Islero 2+2
  4. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Mistake, Olivier
  5. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    please develop...
  6. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Polo Storico will do that, I think. They are doing a great job. But you can ask the framebuilder, he is still on duty.
    The 400GT frame is more heavy than the 350GT. Same advance as the Miura.
  7. Tired of seeing this ad? Upgrade now
  8. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    #1957 Olivier NAMECHE, May 4, 2017
    Ok that's all you have
    I have interviewed Marchesi he has confirmed me that exception of the body supports the structure frame is identical
    You have also to read the brochure specs and homologation specs... for instance width is identical at 1,73 m... lenght 4,46 m... for 350 GT, 400 GT, 400 GT 2+2
    I have interviewed Marazzi in Varese who also confirmed to have used the 400 GT 2+2 frame with a new body he has created...
  9. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Only the last 11 cars have the new 400GT frame.
  10. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    please developp...
  11. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    Not my job. But 23 Interim is a fairy tale.
  12. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    #1961 Olivier NAMECHE, May 4, 2017
    not my job too... but if you want to argue, you need to feed us too...
    I have identified the 23x Interim...
    Among them, Gary Bobileff has restored 5x of them, frame is same, as I wrote there are slight différences in the structure to support body, as well as small differences in some other areas... but globally frame is identical, it is the 1st design conserve for the developpment of the range and in terms of sizes too !
    to illustrate here is a 400 GT frame...
  13. Barnrolf
    Barnrolf Rookie
    Apr 17, 2013
    13
    If you did identify 23 cars, please let us know the VINs
  14. Tired of seeing this ad? Upgrade now
  15. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    you will discover these in my encyclopedia when it will be released...
  16. joe sackey
    joe sackey Four Time F1 World Champ
    Sponsor
    May 23, 2006
    43,673
    Southern California
    Joe Sackey
    :rolleyes:
  17. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    hé yes... that's how it is, and how it is progressing...
  18. Lel
    Lel Karting
    Oct 11, 2007
    174
    #1966 Lel, May 5, 2017
    Those tubes have nothing to do with any Lamborghini built GT at all!
    L-E
  19. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    the front square sections yes, it was a 400 GT 2+2 modified to receive a Bizzarini body...
    but you can look in De La Rive box book they are pictures of the frame too.
  20. staatsof
    staatsof Four Time F1 World Champ
    45,633
    Hiddin' in da garden
    Boo
    It's kind of early over here yet for popcorn but I'll go warm up a batch with some butter, salt and if this goes long enough we can even break out the bourbon too! :D
    I have to admit that I'm sort of fascinated about all of this murky early 350/400GT stuff and have never quite followed all of it. The very idea that Lamborghini had any hard standards on this stuff back then and kept meticulous records about it is hysterical enough all by itself! I can well beleive that Olivier has worked very hard trying to figure it all out. Too bad that the thread's starter is no longer with us because Fred was veritable fountain of information on this stuff. But we've got some other good folks here. Someone should drag Gary into this thread. Probably kicking and screaming ... :D
    Carry on ... :)
  21. Andrew R.
    Andrew R. Formula Junior
    514
    Michigan
    Andrew
    This looks like the chopped up 400GT frame that was in California for sale a few years ago.
  22. Andrew R.
    514
    Michigan
    Andrew
    Will Marchesi share the drawings? That would settle this discussion!
    I know that between the 350GT and 400GT, the mounting for the rear differential is not the same. (ZF versus Lamborghini rear-end) And yes, I know the switch over point is another topic.
  23. Lel
    Lel Karting
    Oct 11, 2007
    174
    The mounting support for the transmission is different on cars with ZF-gearbox or Lamborghini-gearbox.
    And the trailing arms for the rear uprights are mounted forwards on two-seaters (big rear window) and backwards on the four-seaters (small rear window) and Isleros.
    But the chassis never had any round tubes!
    L-E
  24. staatsof
    45,633
    Boo
    Isn't Olivier saying that the round tubes modification were for a custom Bizzarrini body that was placed on that specific chassis? That's how I read it.
    And here's the link, Bogus Bizzarrini,
    Bogus Bizzarrini: 1967 Lamborghini 400GT
  25. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    I shared with Polo Storico, so ask them if you want a quicker answer...
  26. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    Thanks...
  27. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    Or you can just check my 350 GT Register: 350 GT / 400 GT Internazionale | Ferrari - Lamborghini Register Nederland
    The cars that left factory as 400 GT are listed, and otherwise the cars are listed as 350 GT 4 litri, as in fitted with a 4 liter engine afterwards. I will not use the term Interim on either of them ;-)
    Ciao!
    Marcel
  28. Spyder-Man
    Spyder-Man Formula 3
    1,149
    Rob
    Hi Marcel, can you clear down your PM box, I'd like to send you a PM. Thanks
  29. a57robert
    a57robert Karting
    125
    Buena Park, CA
    Robert Huber
    #1977 a57robert, May 6, 2017
    Hi All,
    I feel from a drawing that I have that they were planning on the Lamborghini transmission and differential early on. The date of the drawing is April 9th 1965 the copy date that I have is March 30th 1966.
    Again this is just a blueprint drawing, this does not mean these things were manufacture and put into production.
    I feel that it is necessary to find out when the transmission and the differential went into actual production and on the line being installed in cars. The drawing is talking about 350GT.
    My feeling basically is there were 3 production frames.
    Salisbury with forward rear lower control arm suspension, Lamborghini rear diff with forward lower control arm suspension and Lamborghini rear diff with rearward lower suspension arm.
    Bob Huber
  30. em42
    em42 Formula 3
    1,153
    Wow! Beautiful drawing!
    If I may ask, where did you get it? Do you have some more to share? This is really invaluable information.
  31. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    2,807
    Switzerland
    Raymond S.
  32. kc023515
    kc023515 Formula Junior
    554
    Belgium
    Kevin Crauwels
  33. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    I appreciate and agree on your description, but globally these frames are identical on 80% of the lenght, only the evolution of the diff choices leaded to évolutions... but still remained in the same philosophy...
    the real change of frame appeared with the Espada/Jarama vs the generation of 350/400/Islero, in fact this was my point some posts ago !
  34. Jota 5084
    Jota 5084 Formula 3
    1,892
    Sweden
    Eric Andersson
    #1982 Jota 5084, May 8, 2017
    Regarding the 400GT chassis, here are some scans from a Swedish period Magazine.
  35. a57robert
    a57robert Karting
    125
    Buena Park, CA
    Robert Huber
    Hello Eric,
    Great to see these photos showing the 350 display chassis being put together. Looks like they're figuring out the routing of the exhaust system.
    Early 350s used a two piece driveshaft. The later 350s had the ZF transmission with a longer (plus sliding) output shaft. This allowed a one piece driveshaft. The Lamborghini transmission cars used a one piece driveshaft.
    Bob Huber
  36. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    Done! ready to receive a PM, Thanks.
  37. Spyder-Man
    1,149
    Rob
    Thank you. PM sent!
    Rob
  38. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    #1986 Olivier NAMECHE, May 15, 2017
    In order to appreciate the similarities, here are 2x pics, one 350 GT from a book and one from the parts book of 400 GT 2+2.
    it seems clear that the front and middle section are strictly identical, the rear section is identical on the lower end, just the top end is slightly modified, which means it is not a complete different frame as it was claimed erroneously in a previous post !
    Again, the frame will differ when the Espada & Jarama frame will be produced...
  39. Christian.Fr
    Christian.Fr F1 World Champ
    16,841
    Christian.Fr
  40. Christian.Fr
    16,841
    Christian.Fr
    #1988 Christian.Fr, May 16, 2017
    Only 2 like this one.
  41. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    yes, of course only 2 original 350 Spyder... #0325 the gold one you show belonging to Swiss collector and the black one #0328 belonging to Quatari collector !
  42. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    #1990 Marcello, May 17, 2017
    If it's 0465 it is the same car that was offered by Lutziger some time ago. It looks like the car has been resprayed from silver to very light grey. Mirrors are gone. changed from Quad to Single headlights now also. Strange front license plate? Has anyone perhaps saved more of the pictures from Modena Motorsport of this car?
  43. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    Hi Olivier, Have you checked the Touring body number of this car #0409 as well perhaps? Think it could be #18918, but not sure..
  44. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    #1992 Olivier NAMECHE, May 17, 2017
    yes Marcello, here are some more from Modena Motorsport...
  45. Olivier NAMECHE
    4,126
    Belgium
    Olivier
    Yes, #0409, I did an error typing, there is no Touring plate riveted, was lost during its existence...
    But from my factory period records it is listed as #18918...
  46. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    Ahh, mercie! This car was owned by Dutchman Han Pomp long time ago. 0465 does not fit exactly between 0463 and 0469, strange number, and with an early body......
    What does the record say about 0465?
  47. Christian.Fr
    16,841
    Christian.Fr
    #1995 Christian.Fr, May 17, 2017
    Find this one some years ago, very nice model, totally original. No SN, was impossible to see the engine.
  48. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    #1996 Marcello, May 17, 2017
    Very nice pictures! Still a mystery car for me. 400 GT 2+2 Marazzi in Amaranto/Nero. Here's another picture of the same car I think...
  49. Christian.Fr
    16,841
    Christian.Fr
    Hello Marcello,
    Thanks, I just remembered my celular stay with no battery when I did the pics..
    So it s à mystery car..:) yes I imagine when you know the owner. The real mystery is : how big is his collection!?
    The man doesn't want to show all his cars.
    For me the mystery is who makes this picture?
  50. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    #1998 Marcello, May 18, 2017
    0220 is updated:
    Dear Gary,
    I have just updated #0220 in my 350 GT Register, and have used your pictures with your name as well, to get a nice overview of the history of this car. Hope that's ok and that you like it.
    Thanks a lot for sharing, and great that another barnfind car is back on the road again,
    looking fantastic! Grazie Mille!
    I'm still looking for any period pictures of the car when it was owned by Jim Kaminsky,
    who was president of the Lamborghini Club America for many years. There has to be more pictures then the only one I have? Anybody?
    Here is the 350 GT Register, you can click on the little pictures for more:
    http://www.lamborghini-register.nl/lamborghini/home/v12-classici/350-400/350-gt-400-gt-internazionale
    Kindest regards,
    Marcel Wallenburg
  51. joe sackey
    Sponsor
    May 23, 2006
    43,673
    Southern California
    Joe Sackey
    Marcello, please bear in mind that he is currently listed as a banned user here so you may wish to contact him directly.
    Meanwhile I hope the images of 0223 taken by my son which I sent last night worked for you as requested.
    Hope you are well.
  52. Marcello
    Marcello Formula 3
    Sep 6, 2004
    1,966
    The Netherlands
    Marcel Wallenburg
    Hi Joe, thank for letting me know, I will contact him privately.
    And yes, perfect pictures of 0223, thanks a lot!
    Ciao!
    Marcel
