456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 5 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. tazandjan
    37,985
    George- Several 456 owners have made that swap with no problems. They are only accumulators to store power steering fluid for pumping into the bottom of the rear shock absorber to increase or reduce volume when the auto leveling function of the shock is working. The regulator valve is not on the accumulator, so the swap is not a problem. There is a good description of the auto-leveling function in the 456 workshop manual starting on page F41. The WSM can be downloaded for free at ferraridatabase.com.
  2. 456GD
    456GD Karting
    Nov 14, 2010
    143
    London, UK
    George
    Thank you Taz
  3. philfrench
    philfrench Karting
    Jan 3, 2012
    104
    France
    I ve put these accumulators one mine .(about 200 euros both)
    Only the mounting hole is larger ,put a large washer and it s ok.
    You will prevent from rear shock leakage because the accumulator will absorb a part of excessive oil pressure when working.
    ,You ll feel a better shock absorption at the wheel.
    Easy diy ,no bleeding ,only jack the rear .
  4. 456GD
    456GD Karting
    Nov 14, 2010
    143
    London, UK
    George
    Thanks Phil. I am not able to do it myself as I haven't got enough space or talent but surely will be done on the next service. Cheers!
  5. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    554
    Houston, TX
    Ron Furzeland
    Anyone have the Tyco-Waytek cross reference number for the Bosch relay 0332014140 used for the 550's ECUs and fuel pumps?
    Thanks,
    Ron
  6. bay
    bay Formula 3
    Mar 13, 2011
    1,224
    Belgium
    Bernard
    Same
    SAAB 9000 3.0 CD B 308 I 155 09.1995 - 08.1996 reference 46 61 070
    SAAB 9000 3.0 CS B 308 I 155 09.1995 - 08.1996
  7. rmfurzeland
    Jan 7, 2005
    554
    Houston, TX
    Ron Furzeland
    What about MAFs for the 575 any alternatives?
    Thanks,
    Ron
  8. bay
    bay Formula 3
    Mar 13, 2011
    1,224
    Belgium
    Bernard
    bosch 0 280 218 085
  9. Cribbj
    Cribbj Formula 3
    #109 Cribbj, Feb 7, 2014
    Just to confirm Ron's findings, here's a couple of pics of one of my IACV's:
    Same part is apparently used on 348's, 512TR's, 512M's and Mondials also.
  10. Cribbj
    Cribbj Formula 3
    The 0332014140, (aka the "4140" relay) apparently was superceded by the 0332014113 relay (aka "4113"), which was then apparently superceded by the 0332019151 relay.
    All are SPST relays, which normally are 4 pin relays, but these had 5 pins, because they were equipped with dual "87" output contacts. So they could drive 2 x 15a or 2 x 20a loads from a common source.
    Now that Tyco have taken over the Bosch business, their P/N for it is: V23234-C1001-X006
    So, Ferrari P/N: 175318, which was Bosch 0 332 014 140, and all its succeeding P/N's, is now Tyco V23234-C1001-X006
    Available at Waytek, Electrical Depot, etc.
  11. Cribbj
    Cribbj Formula 3
    #111 Cribbj, Feb 16, 2014
  12. Mr Mezzanotte
    Mr Mezzanotte Formula Junior
    Aug 22, 2006
    632
    Any ideas where the 456GT seat control (switches on seat) unit came from ?
    plastic has broken on mine, and Ferrari claim no longer available!
    can't see it being a Ferrari part
  13. DZ-96
    DZ-96 Formula 3
    1,775
    South Germany
    Daniel
  14. papou
    papou Formula 3
    1,567
    plantation Fla
    daniel ross
    Trying to find driver side motor online used if possible.
  15. rmfurzeland
    Jan 7, 2005
    554
    Houston, TX
    Ron Furzeland
    Thanks, Ordered the Tyco -X006 from Electrical Depot $8 each and received Bosch 0332019151 relay so should be good.
    Ron
  16. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    Can anyone confirm that brake pads for the 456 are interchangable with the Jaguar XK-R ?
  17. rmfurzeland
    Jan 7, 2005
    554
    Houston, TX
    Ron Furzeland
    The wiring diagrams may seem reversed but dont forget the right sensor drives the left bank and vice versa since the air intakes cross over right to left. Also there are 2 sensors on the right side, one is a TPS and the other is an acceleration sensor (US only).
  18. Mr. V
    Mr. V Formula 3
    Oct 23, 2004
    1,247
    Portland, Oregon
    #118 Mr. V, May 3, 2014
    Ricambi cannot ship a pulse speedometer sensor for my 456GT, as they are on indefinite backorder; I suspect none will be made available.
    It is number 20 in Ricambi schematic.
    Any idea if it can be sourced from another mfr.?
    I have glitches with both the speedometer and suspension idiot light, which would seem to point to this as the problem.
  19. tazandjan
    37,985
  20. bay
    bay Formula 3
    Mar 13, 2011
    1,224
    Belgium
    Bernard
  21. 15765
    15765 Formula Junior
    May 14, 2012
    302
    Las Vegas NV
    Chuck King
    #121 15765, May 6, 2014
    The Electromagnet clutch coil used on the 550 Maranello can be replaced with one from a Cadillac Catera from 1997 to 2001. You will need to rework the power and ground wires and add the Diode from the existing power wire. Cost about $125.00. Oil leaking down from the Rh cam cover gasket or the cam pulley O'ring seals will get into the electromagnet coil and damage the insulation without creating a direct short so the a/c clutch will stay engaged and work until the coil gets hot and blows the 20 Amp fuse at the passenger floor. Be sure the A/C shop you are buying the new coil from confirms that the new one matches your old one except for the wiring and you reuse your power wire with the Diode plus you add a ground wire. Saves about $4000.00 from buying a new one from Ferrari.
    Chuck King
    702-243-6557
  22. rmfurzeland
    Jan 7, 2005
    554
    Houston, TX
    Ron Furzeland
    #123 rmfurzeland, May 27, 2014
    550 Mass Air Flow sensors : Sorry - Saab alternative no good, tried the Saab/Bosch parts suppliers, this part is discontinued so unless you get lucky and find an old one on the shelf, you will need pay big bucks. Any other suggestions?
    Amazon lists the Bosch 0280217521 but says shipping 1-2months, wierd!
    Ron
  23. tazandjan
    37,985
    Owner sourced all five F1 hoses, steel braided covers, for $140 from this source.
    Goodridge
    John Crnich
    (704) 662-9095
    174 Gasoline Alley
    Mooresville‎ NC‎ 28117
    United States
  24. Cribbj
    Cribbj Formula 3
    #125 Cribbj, Jun 21, 2014
    Here are all the relays for the 550 Maranello main relay panel, by location, type, Ferrari P/N, Bosch P/N, and Tyco P/N and the quantities required.
    "Type" is simply the reference used in the Ferrari parts diagram.
    All can be sourced from Onlinecomponents.com | Distributor of Electronic Components by using the Tyco P/N's. (N.B. Online Components isn't necessarily a preferred vendor, but they carry all 3 types, whereas other suppliers may carry only 1 or 2 of the types)
    Links to vendor's parts pages for each type:
    (39): V23234C0001X006-EV-100 TE Connectivity / P&B Brand | Buy
    (40): 5-1393304-6 TE Connectivity / AMP Brand | Buy
    (41): V23234B0001X001-EV-144 TE Connectivity / P&B Brand | Buy
