456 / 550 / 575 Cross Reference, Interchangeable Parts Source Thread | Page 6 | FerrariChat
Discussion in '456/550/575' started by Cribbj, Jan 9, 2013.
  1. tazandjan
    38,077
    John- Very handy, thanks. Will have to look and see if they carry the Tyco V23134-B57-X266 that we use as a 30 amp F1 pump relay replacement.
  2. Cribbj
    Cribbj Formula 3
    Thanks Taz, I thought the info needed to be in a single post to make it easier for those who are buying a complete set of replacement relays.
    Those high amp F1 relays don't seem to be available in the aftermarket under the Tyco reference. Perhaps BMW and other OEM's have cut a deal with Tyco to protect their marketing rights. It would be interesting to see if some of the other high amp relays like the Cole Hersey's would have the same pinout and would work.
  3. AKINSB
    AKINSB Formula Junior
    Feb 15, 2013
    502
    Santa Barbara
    Alex K
    Taz or Cribbj
    Do either of you have similar information for the 1995 456 GT fuse panel?
    Alex
  4. tazandjan
    38,077
    Alex- You mean a diagram or a sheet of actual relay numbers?
  5. Cribbj
    Cribbj Formula 3
    Alex, this post: http://www.ferrarichat.com/forum/143195894-post16.html has the Bosch references for the relays and their location within the 456 GT relay panel.
    There appear to be 4 different types in the 456 relay board, and 2 of those 4 are the same or nearly the same as the 550's relays; for example the fuel pump relays (Bosch 0 332 014 140) and the 2x15a relays (Bosch 0 332 015 013 for the 550, and the 456 uses the "K" version: 0 332 015 006, but it's essentially the same type)
    So it wouldn't take an enterprising owner very long to construct a similar table for the 456, as you'd only have to cross two more Bosch numbers (0 332 014 113 and 0 332 204 101), and someone here on FChat has probably already done it.
  6. tazandjan
    38,077
    Serkan is the expert on rebuilding and testing F1 actuators.
    Serkan Ozsacasci
    GTE Engineering LLC
    561 NE 26th Ct
    Pompano Beach, 33064 FL
    Home
    E-Mail [email protected]
    TEL 1 (754) 205 0812 M-F 9am|5pm
  7. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Indeed those sensors will only work with Motronic 2.7 so not on the 550.
    On the 456 they might work though.
  8. 360modena2003
    360modena2003 Formula 3
    Jul 11, 2009
    2,398
    The post 96 456 have the 5.2 Motronic
  9. bay
    bay Formula 3
    Mar 13, 2011
    1,224
    Belgium
    Bernard
    Is a 30 A or a 50 A ?
    Mini-Relay N.O.
  10. Cribbj
    Cribbj Formula 3
    The Bosch & Tyco technical data refer to these as 50a relays.
    I wouldn't trust a 30a relay for this circuit, but neither would I have put this circuit on the main fuse/relay board. It really ought to be moved off the board.
  11. bay
    bay Formula 3
    Mar 13, 2011
    1,224
    Belgium
    Bernard
    #136 bay, Jul 15, 2014
  12. DZ-96
    DZ-96 Formula 3
    1,781
    South Germany
    Daniel
    Indikator relay (relais) is the same from the Alfa Romeo 166
    Daniel
  13. mcypert
    mcypert Formula Junior
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    #138 mcypert, Aug 13, 2014
    John Cribb did some research on an alternative thermostat; Stant 13648 (sometimes marketed as a 180F stat, it’s stamped 174F, but check for the 174F stamp as the boxes may vary). Thanks John....
    First pic is John’s measurements of the Stant 13648 vs the Ferrari 183758. (I added the black line under his blue to show where I measure the bypass 100% closed.)
    Second Pic is the Ferrari 226484 (a European 87C variety), Stant 13648 in a 456 housing and the original 183758 (79C), in that order.
    Anyway, as John’s data shows and I can confirm from use, the $18 Stant works fine, in fact, I’d say better than the originals, especially in warmer climes.
    Regards....Mark
  14. mcypert
    Jun 7, 2012
    369
    Houston, Texas
    Mark Cypert
    That's it.... just check that it's stamped 174F when it arrives... John got one from Amazon that was stamped 190F, which is basically the European spec...
  15. tazandjan
    38,077
    79 C is 174 F.
  16. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    554
    Houston, TX
    Ron Furzeland
    Finally managed to find European source for replacement sensor elements, Saab-Bosch number works fine. I bought 4 so I have 2 spare , new ones if anyone needs them , PM me.
    Ron
  17. Cribbj
    Cribbj Formula 3
    #143 Cribbj, Nov 6, 2014
  18. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    The 550/575 luggage compartment weather seal is over $500 from the dealer. A great substitute is from a 2014 Nissan Altima trunk weather seal. The installation type and the installed height as well as the appearance is identical to the 550/575. It is too long, but you can cut the length to fit, butting the two ends together at the latch. The Nissan Part # is 84830-3TA0C and it lists for $53. It can be found online for around $37.
    chuvips likes this.
  19. Laurie738
    Laurie738 Rookie
    Oct 24, 2013
    1
    Hi,
    I have had a blue manual 456 with tan interior for about a year. I am considering changing the spark plug leads but can only find them at about £850 a set. I believe they are Bosch and wonder if anyone has the Bosch parts number? The Ferrari part numbers are 155788 and 155789.
  20. mjh366
    mjh366 Karting
    Jul 26, 2007
    172
    Kerrville Texas
    Mike hoskins
    Car Guy did a Thread years ago on building your own plug leads. Using his thread I was able to build a set, not to hard of a job. The thread was in the Testarossa section. Around 2007 to 2010 ?
    Good luck
  21. henri66
    henri66 Karting
    Oct 10, 2006
    109
    Previously Maranello
    This is my thread on my French forum when I rebuilt my 456 heads.
    The spark plugs ref are valid for my MGT
    456M - Changement Des Guides De Soupape - Page 14 - Ferrari 456 - 550 Maranello - 575 M - Ferrarista - Ferrari Owners Only
  22. Cribbj
    Cribbj Formula 3
    #148 Cribbj, Dec 31, 2014
    Ferrari P/N: 103877
    SKF P/N: 62202-2RS1/C3
    Generically it's a single row, deep groove ball bearing, double sealed, with shaft size of 15mm x OD of 35mm x thickness of 14mm. It's mounted into the rear of the crank and serves as the front support pilot for the main clutch shaft.
  23. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    Good info John...especially since I am winding up to do my clutch...
  24. Cribbj
    Cribbj Formula 3
    GS thanks, however there's not much money to be saved by sourcing these from an SKF distributor. Ricambi has decent prices on them.
    Daniel does show the flywheel screws to be on "call" status currently, which is always a bit scary....
