Anyone know what this is leaking? | FerrariChat
Discussion in '360/430' started by Speedracer800, May 15, 2017.
  1. Speedracer800
    Speedracer800 Formula Junior
    Jan 16, 2013
    502
    Chicago, IL
    #1 Speedracer800, May 15, 2017
    Looks like the ac compressor? Is it filled with a lubricant or something that's leaking?? I feel a little bit silly asking but I'm not very familiar with this system. This is the bottom side of the engine with the belly pan removed and car on the lift. Any help would be greatly appreciated.
  2. mkzhang
    mkzhang Formula Junior
    Oct 5, 2009
    535
    Philadelphia
    Does it have a belt attached to it? On the 430 that's where the AC compressor is located
  3. Speedracer800
    Jan 16, 2013
    502
    Chicago, IL
    Yes.. I'm pretty sure it's the ac compressor.. But leaking green fluid like this?
  4. spicedriver
    spicedriver F1 Rookie
    Feb 1, 2011
    3,859
    That's oil to lubricate the system. You need to add oil, as well as refrigerant when you recharge the system. The seals are gone in that compressor. Replace, and recharge.
  5. mike01606
    mike01606 Formula Junior
    Feb 21, 2012
    794
    Cheshire UK
    Mike M
    Its leaking compressor oil. It's added with the gas.
  6. RedNeck
    RedNeck F1 World Champ
    10,013
    The CSA
    Me
    You can have it rebuilt for much less than it costs to replace.
  7. cfensty
    cfensty Formula Junior
    978
    South Carolina
    Shoot mine leaks too.
  8. Rifledriver
    34,097
    Austin TX
    They are a piece of crap. They all leak or soon will. Rebuilding is cheap.
  9. RedNeck
    10,013
    The CSA
    Me
    I think mine was around 300, a lot better than 1000+ for a new one.
  10. Speedracer800
    Jan 16, 2013
    502
    Chicago, IL
    Thanks for the information. I later found this post on another forum with a link to a seemingly reputable rebuilding service in the US. Anyone ever use these guys? How long can you go before completing destroying the compressor I wonder.. I'd much rather take on this project over the winter :/
    Has anyone ever pulled one of these things out? I'm wondering if this is a job I can take on myself..
    Here's the link:
    360 air conditioning compressor
  11. CCRider66
    CCRider66 Formula Junior
    454
    Sussex, WI
    Brian
    I have a leak of clear oil under my car as I finished the timing belts. So I've been watching this. I plan to take mine out myself and ship it to a company in California that I found says they rebuild them for about $240. I found a shop local that will vac and fill it for me for about $150. That seems like a good deal to me.
    http://www.compressor-intl.com/ He said they have done many Ferrari 360's FWIW.
  12. Rifledriver
    34,097
    Austin TX
    It will quit being cold long before you hurt the compressor.
  13. Rifledriver
    34,097
    Austin TX
    That's from dye, not oil. Adding oil at the recharge will just eventually end up with too much oil and the A/C will not work as well. If there is no oil leak, do not add oil. When the compressor is replaced with a dry one put in the oil needed for the compressor only.
  14. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,372
    FL full time
    Removing the AC unit is not that hard. I think the Alternator needs to be moved too. I took both out and had both rebuilt. Having a car lift is a Big Big Help!!!!
    Had a local shop remove the Freon and then evacuate the system before recharging, adding the oil.
    Good Luck!!!
  15. Rifledriver
    34,097
    Austin TX
    No need to pull alternator. Its on the other side.
  16. Speedracer800
    Jan 16, 2013
    502
    Chicago, IL
    Thanks for the help guys!
    So you don't need to do anything regarding the oil or freon before unhooking the hoses etc to remove? I'll probably wait till "the off season" to tackle the project and I do have a lift and can get easy access so judging by the feedback I'm getting here I'm fairly certain I'll take on the job myself. Just want to gather up some information in advance. Thanks again!
  17. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    If your system is still charged (holding pressurized Freon), then have a professional evacuate it. Don't just start disconnecting the hoses. The freon is under pressure and will do bad things if suddenly released in your face (i.e. really bad things to unprotected eyes).
    If your system is already empty, then you can just start disconnecting the hoses.
    To test for pressurization, you can get a set of Manifold gauges fairly cheaply. Or possibly borrow a set from Autozone or other car parts retailer.
    Sid
  18. Speedracer800
    Jan 16, 2013
    502
    Chicago, IL
    Great information.. Thank you! I've never torn an ac system apart and it's pretty unfamiliar with me. I'm confident that I can swap out the parts but the freon aspect is totally outta my wheel house.
    Sent from my XT1650 using Tapatalk
  19. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    You don't ever vent the freon. It is against the law and REALLY bad for the environment. Have it pumped down. Honestly, that kind of work isn't too hard but you need the right equipment. I suggest that you have someone do that work who is properly set up to do it.
