Welding the intercooler system together. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Final hone, block cleaned, fitting ARP hardware. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
I'm disappointed I haven't seen these updated on L talk. For a minute there I thought you guys were being flaky...now I KNOW you're not! Nice work guys! You will have a PM shortly.
The fuel system was redesigned to support the demands of the forced induction setup. Fuel rails, filters, and pumps will remain confidential. All fuel lines were replaced with Goodridge stainless steel braided lines and fittings. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Might I suggest the newer kevlar lines, such as the Aeroquip Starlite brand? Lighter, less abrasive to parts around them and as robust as braided lines. I never use braided lines except for brakes any more.
All engine gaskets, bearings, and seals replaced. Image Unavailable, Please Login Image Unavailable, Please Login
Upgraded fuel injectors in comparison to OEM. Image Unavailable, Please Login Image Unavailable, Please Login
Fabricating a bolt in roll bar. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Roll bar before being powder coated and installed. Image Unavailable, Please Login Image Unavailable, Please Login
Steering wheel grip diameter increased, wrapped in Alcanatara, and white leather strip added at 12 o'clock position. Image Unavailable, Please Login
It does fit the stock seats but cannot be installed with the engine in the car. The bolts for the engine cradle through the firewall support the mounts.
Rear diffuser painted body color. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Assembling the bottom end of the engine. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Short block assembled. Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
Modified fuel rails and injectors fitted. Image Unavailable, Please Login Image Unavailable, Please Login
