Countach Technical Thread & Questions | Page 3 | FerrariChat
Discussion in 'LamborghiniChat.com' started by jollygood, Mar 18, 2013.
  1. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Was that caster heim joint in the kit as an OEM item, supplied by Lamborghini?
  2. El Wayne
    El Wayne F1 World Champ
    Staff Member Lifetime Rossa Owner
    Aug 1, 2002
    18,043
    San Marino, CA
    L. Wayne Ausbrooks
    Personal attacks and profanity? Take a vacation and cool it.
  3. joe sackey
    Sponsor
    May 23, 2006
    57,329
    Southern California
    Joe Sackey
    Your cranks look beautifully restored!
    But the most prevalent issue with window cranks is the stripping of the teeth at the mounting point that occurs with time & use.
  4. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Wonder if you could have removed the original leather and used it on the new crank?
    Did you consider that option maybe?
    By the way, your new cranks look good.
  5. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    They were in pretty bad shape. The way they were glued onto the crank, it was a chore getting it off. One was really scratched up. The new leather was such a close match I felt it was worth it just to go with the new leather. And the plus side, I have an extra in case one ever breaks again! :)
  6. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    I'm not sure if it was or not.... that was an image Kurt sent to everyone showing how that one heim had a bend to it.
    Thanks Joe! And yes, so true! My drivers side was stripped out and broke! The P.O. had used a glue (sort of reminded me of auto glass sealant) that at least allowed you to crank the window up and down a bit. There were enough teeth left to make minor contact so I could get it up and down, but the silly thing wobbled around on the spline something terrible! :)
  7. ralfabco
    ralfabco Two Time F1 World Champ
    Mar 1, 2002
    28,029
    Dixie
    Itamar Ben-Gvir
    Let's play in the sandbox :)
  8. joe sackey
    Sponsor
    May 23, 2006
    57,329
    Southern California
    Joe Sackey
    You are lucky you were able to find new cranks!
    I can't imagine how you would repair one with stripped teeth, other than to insert some kind of metal toothed sleeve glued in place. Significant work indeed.
    This is why the 25th is great. OK I saw an opening and had to take the shot :)
  9. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Well, a lot more that can go wrong on the 25th with all the electric stuff...
    Windows, seats, mirrors...what else is there?
    I prefer it simple and manual.
    What I like very much about the Countach is the extreme direct steering which gets better and better as speed increases.
    No electric power steering for me ;-)
  10. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Where is the best place to get a new distributor cap and rotor for a Countach Quattrovalvole without being ripped off?
  11. Redlambo
    Redlambo Formula 3
    2,285
    Pendergrass GA
    Vic Woloschinow
    You can go to any auto parts store and buy the cap for a Jaguar v-12 and it will work.
    Last time I purchased one it ran about $85.00 for the cap.
    I can search for the part number later if you need.
  12. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Thanks for info. Yes, a part number is appreciated indeed.
    I have read about the Jag cap replacement.
    Is it a direct fit?
    Do you need to drill a hole in it? Why?
    If so, where to drill?
    My cap does not have a hole in it, why not?
    Are there different manufacturers of that Jaguar cap?
    What about the rotor?
    Where can that be sourced?
    Many questions here but I would like to know and I am pretty sure this is valid for other owners as well.
  13. Redlambo
    Redlambo Formula 3
    2,285
    Pendergrass GA
    Vic Woloschinow
    I am pretty sure the NAPA part number is # EP897.
    You only use the center coil terminal and reuse your old rotor button.
    The rotor buttons are almost impossible to find and you cannot use the Jag rotor as it is designed for two coils.
    As far as the holes, my original cap does not have any holes. However I have heard people complaining that the cap can accumulate moisture or condensate hence the holes. In my opinion the only way moisture can get in the cap is by washing the car and allowing water to drain onto the distributor.
  14. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Thanks for info!
    So where to get the rotor, if needed?
    Is it still available OEM?
    Or from a Magneti Marelli sales agent/distributor?
  15. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,967
    Jakarta
    TS
    Hmmmm..
    Crap.
    I ordered the part from the same guy for a week after I Paypal him I have not receive any mail.
    Let's see if he e-mailed me back today.
    Lucky I use Paypal
  16. BlueBiturbo
    May 19, 2004
    3,967
    Jakarta
    TS
    He just replied to my e-mail.
    Now he is saying that my part was ordered from the factory but he has not receive it yet.
    hmmmm...
    IIRC in his first e-mail he said he had the parts.
    Gotta re-check my e-mail archive.
    I paid him, July 9th... Paypal max refund is 30 days ??
    If he still has not send the parts in 21 days I will put a dispute with paypal.
  17. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,012
    Switzerland
    Raymond S.
    Why would someone buy a part from him you can get directly from the factory...
    In that case lambostuff.com is much more reliable.
  18. BlueBiturbo
    May 19, 2004
    3,967
    Jakarta
    TS
    I checked lambostuff they did not have pressure plate for LM002.
    I bought many times from lambostuff already.
    This guy said he has one in stock... NOT
  19. jollygood
    jollygood Formula 3
    Oct 24, 2005
    1,096
    jollygood
    Have you tried Glen at AMH Exotic Parts?
  20. BlueBiturbo
    May 19, 2004
    3,967
    Jakarta
    TS
    Not Yet.
    Thanks for the info.
    I will try them when this Clown did not deliver the item.
  21. Albert-LP
    Albert-LP F1 Veteran
    7,784
    around Modena, Italy
    Alberto Mantovani
    #71 Albert-LP, Jul 23, 2013
    i want to fix in a definitve way a problem i have with the wiper: i need a new wiper shaft. Someone in the US drilled and modified it so now it's no more reliabe. I tried many times, but after some days the wiper does not work anymore. The motor works, the shaft turns but the wiper arm does not move. So i would try to change the motor or just the shaft, but i think if you want a new wiper shaft you have to change the motor too.
    Does anyone here know what car used that wiper motor and/or where to find a new one?
    The only other way is to weld the wiper arm on the wiper shaft, but i do not like it.
    Maybe there is a different way to fix it?
    Thank you very much
    ciao
  22. ilconservatore
    ilconservatore F1 Veteran
    May 18, 2009
    8,369
    Cincinnati Ohio
    #72 ilconservatore, Jul 24, 2013
    I snapped some shots of an early Countach wiper arm and motor assembly. There are no splines in the wiper arm itself, but the wiper mounting stud has a tapered splined shaft that makes a press fit when tightened.
    If you grasp the wiper arm, does it move freely while the stud and locknut remain stationary? If so I'd suspect the splines have stripped.
    If the stud and wiper move together, its likely the linkage has failed or the drive stud on the wiper motor is damaged. In the worst case, the worm gear in the motor itself could have failed, but it would make a lot of noise when running.
    (sorry for quick iphone shots)
  23. Albert-LP
    7,784
    Alberto Mantovani
    Thank you very much, Conservatore (are you italian?).
    "If you grasp the wiper arm, does it move freely while the stud and locknut remain stationary? "
    Yes, it does.
    "If so I'd suspect the splines have stripped".
    Yes, they did.
    We tried in may times to fix it: my pictures show the wiper before some attempts, now there is no more that horrible nut.
    The problem is in the conection point between the wiper arm and the motor shaft. The motor works very well. Maybe i have to take out the motor and i think i need a new motor assembly. I would like to weld it...
    thanks
    ciao
  24. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    Ferrari Boxer parts possibly could be adapted. The alternative would be to try and machine in some new grooves with a new sleeve in the wiper arm.
  25. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    BB viper is same, (but don't tell those F-people, that their car is good source for spare parts to Lamborghini)
