Dumb Countach question - turn signal flasher unit location | FerrariChat
Discussion in 'LamborghiniChat.com' started by JohnMH, Aug 14, 2017.
  1. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    My turn signals stopped working and my owners manual is stored elsewhere. Anyone know where a turn signal flasher unit is on a LP400S? Turn signals are recommended on something that low in Toronto traffic.
    The 4 way hazard lights work fine, but I think that is a different relay. I think it is under the glove box somewhere but which relay is the one? Oh, the challenges of ownership.
  2. sp1der
    sp1der F1 Rookie
    Jan 10, 2009
    3,006
    Simon Ashley
    I do not know if this will help but on my 5000 the flasher relay is the slightly larger plastic cased relay normally within the fuse -relay board under the glove-box.
  3. alberto
    alberto Formula 3
    Aug 25, 2001
    2,401
    San Diego
    Alberto
    Not stupid, I just found out myself. On 1983 LP5000S, it's below the glove compartment. Drop the fuse box after undoing large knob. When you pull it down, be careful not to pull wires loose. If you do, you'll be in a world of hurt. Ask me how I now.
  4. hashiriya
    hashiriya Formula Junior
    Feb 26, 2010
    351
    Hazard lights relay is built in the button, hence it's really operable in all conditions.
  5. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,632
    Dubai / Bologna
    Thanks, I will disconnect the battery before I do any of the above.
