Exhaust Valve Bypass Controller
Discussion in 'Ferrari Parts & Collectibles' started by bisel, Mar 29, 2014.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. bisel
    bisel Formula Junior
    998
    Scottsdale, Arizona
    Steve Bisel
    #1 bisel, Mar 29, 2014
    Hello All,
    I am trying to start my little cottage industry and have created an Exhaust Bypass Valve Controller Kit for the Ferrari and Maserati vehicles that have factory installed exhaust bypass valves ... actually the vacuum solenoids that control the bypass valves.
    Capristo makes remote controllers ... $650 ... mine is far less $$ and actually can be configured to use either a remote control transmitter (key fob) or to use a manual on/off switch to be installed in the passenger compartment.
    I have made up a few of the units now and two people have acquired them ... I am awaiting comments. I have also installed this on my own car (a 2004 360 Modena). Everything is plug and play. No wiring mods. No splicing into any wiring. No drilling of holes.
    I am not going to get rich with this endeavor ... but I retired 6 months ago and this might keep me off the streets and out of trouble.
    Would love to hear from fellow Ferrari owners and I invite you visit my web site ... Forza Componenti
  2. voicey
    voicey Formula 3
    Jul 29, 2009
    1,119
    London, UK
    Aldous Voice
    I have looked at Steve's module in detail and it's a lot more than just a remote switch. He has taken care to isolate the kit from the car's electronics and consider the environment it will be operating in - as such I believe it to be completely safe to fit. It is also very nicely made.
    Far, far better than the other kit out there which is simply a cheap Chinese switch and a couple of junior power timer connectors.
  3. tazandjan
    tazandjan Two Time F1 World Champ
    27,472
    Albuquerque, NM
    Aldous- Not to mention it also comes with a connector for a hard wire switch that I will hook to my unused European rear fog light switch. Just got my kit this week.
  4. dogstar6
    dogstar6 Karting
    Jun 10, 2005
    72
    Detroit, MI
    Matthew
    I see on your site that you have instructions for the 360, any for the 355?
  5. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    #5 bisel, Mar 29, 2014
    I went live with this product only in the last week. So, only have people wiith the 360, F430 and 575M so far. Although have not yet written specific instructions for any other than 360. I will be making updates as I get more photos and installation experiences.
    Although I do not have specific instructions for the 355, it should be relatively easy. The 355 has only one bypass valve and solenoid. The solenoid vacuum valve is located lower right (I believe). Since only one valve, you need to use only one of the connector cables ... similar to 550 and 575. You connect to the cable with the red band on the control unit. All other instructions for installation will follow 360.
    I have attached an illustration of the 355 exhaust valve setup. I believe that if you can find room to install the control unit near the ECU ... that would be ideal place for it. Then route the connector cable from there down to the vacuum solenoid valve ... although components are heat resistant, still best to try to keep everything as far away as possible from high heat (e.g. cats and exhaust header).
    By the way, on the 355 the sound will be absolutely glorious! In bypass mode, not only is the silencer bypassed, but the larger cats are also bypassed. I have heard it said that in bypass mode, the 355 is one of the best sounding Ferrari's on the road.
    Steve
  6. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    For those of you in the Phoenix area ...
    I plan to be at the Cars and Coffee on Saturday, March 5th. I am going to be bringing several of the kits and I will be able to give you a demo of the product and show the installation process.
    Hope to see you there.
    Steve
  7. Tired of seeing this ad? Upgrade now
  8. Jamarico
    Jamarico Karting
    Nov 30, 2012
    118
    Switzerland
    Marco
    Hi Steve
    I've the Capristo controller installed in my 360 Modena.
    Although written in the manual there is no configuration to start the engine with open valves.
    In my opinion the valves should be open without applying vacuum (engine off) and start close as soon the engine starts => using a controller it should be possible to start the engine with open valves.
    What is your controllers behavior regarding this topic?
    Thanks,
    Marco
  9. galt
    galt Formula Junior
    Rossa Subscribed Owner
    Jun 19, 2005
    839
    What would be great is a clone remote control unit for the capristo unit that can just slot into a dummy switch in the f430
  10. DrDon
    DrDon F1 Rookie
    3,628
    Infractionville
    Armando Decredenza
    I thought that the 360 started with the bypass open and after a few minutes (4 perhaps?) of warmup, the valve closes and the revs drop to idle.
    That seems to be what my system does when it's cold anyway.
  11. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    You are correct.
    Regards,
    Steve
  12. RotarySwingGolf
    RotarySwingGolf Formula Junior
    Dec 24, 2011
    491
    Florida and Idaho
    Note that if you run this open on the 355 you will get a slow down light as the car will think it's overheating due to the thermocoupler getting too much heat when it detects the valve should be closed.
    The trick - remove the bulb which is what I did and don't run it open for long periods of time or it will go into limp mode. No such probs on my 360 as it doesn't have a thermocoupler.
  13. Jamarico
    Jamarico Karting
    Nov 30, 2012
    118
    Switzerland
    Marco
    Steve
    When my car hasn't been used for a certain time, the valves are open during the engine starts. They close after 1 or 2 seconds.
    But when I restart the engine on the same day, the engine starts quiet...it seems the valves are closed during restart.
    As I remember I already tried to press the remote control after ignition was on without any effect. It only works after the engine has startet.
    But need to check again....anyway thanks for your support.
    Marco
  14. Tired of seeing this ad? Upgrade now
  15. dwe8922
    dwe8922 Formula Junior
    304
    FL
    David
    I have been thinking about the Capriisto system, so I'll be curious to see how others like this set up....
  16. arizonaitalian
    arizonaitalian F1 Veteran
    Silver Subscribed Owner
    Oct 29, 2010
    6,475
    Hey Steve...I'm just seeing this...first off...AWESOME and THANKS for creating this switch. Very cool! I wish you much success with it.
    I may look into it when I get my CS down to AZ later this year.
  17. arizonaitalian
    Oct 29, 2010
    6,475
    I just read your website...and I realized I really need this on the Maser Gransport I have.
    I have to drive it in "sport" mode because the shifting on the F1 sucks (a lot) if not. But, "sport" also bring open exhaust valves all the time. And, with its cross plane crank it is very, very boomy at idle. I usually flip the sport switch on and off whenever I'm sitting still, like morning warmup and even at stop lights. *IF* this switch will allow me to leave the sport button on (better shifting) *AND* not have boomy noises, i'm all for it.
    I'll look you up in the fall for that too.
  18. mikeyr
    mikeyr Formula 3
    2,151
    Santa Barbara, CA.
    Mike Rambour
    on my 360 the valves close within seconds after starting the car, hot or cold makes no difference, I start the car and the valves are open and they close within a few seconds, not minutes as someone stated above.
    I have the Capistro remote on my car but I find it too noisy to drive around with the valves open, it makes people look at the car even more than they already do.
    Wish this kit had been around a few months ago, I would have gotten it instead of the Capistro and done the dash switch instead of remote. I do like to open the valves when I am up in the mountains away from crowds :)
  19. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    Thanks for kind words, guys.
    I am going to try to do demo at local Cars and Coffee this Saturday. We'll see how that goes.
    Regards,
    Steve
  20. MacF430
    MacF430 Rookie
    Jan 27, 2014
    9
    Sweden
    It looks very nice! Do you ship to Sweden?
  21. MacF430
    MacF430 Rookie
    Jan 27, 2014
    9
    Sweden
    Great product, do you ship to Sweden?
  22. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    6,857
    SoCal LA/OC
    Tim Dee
    Very nice
    subbed
  23. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    Hello Mac,
    Yes, I will ship to Sweden. No problem at all.
    Just go to my website and complete the contact form and tell me your shipping address. I will then send you a PayPal invoice.
    Regards,
    Steve
    http://www.forzacomponenti.com/
  24. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    Was at cars and coffe today. Nice turn out. A few people took a flyer.
    Also, came across another method for mounting the controller module...
    3M? Dual Lock? Reclosable Fasteners
    and will be including this product in my kits.
    Regards,
    Steve
  25. sortusacar
    sortusacar Rookie
    May 6, 2013
    20
    Sacramento
    laurie russell
    Hi Steve, I sent a request for the kit via your website, please let me know the next steps in completing the order
  26. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    Hi, sorry, but did not get the message thru my website. I will have check into that.
    In mean time, sent you a private message.
    Thanks,
    Steve
  27. bisel
    998
    Scottsdale, Arizona
    Steve Bisel
    #25 bisel, Apr 5, 2014
