Ferrari 0855 Ellena
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Sep 23, 2014.
  1. I have started the new week 1 FerrariChat Update poll, please vote... http://www.ferrarichat.com/forum/threads/ferrarichat-com-update-week-1-poll.560487/
  1. donv
    donv F1 World Champ
    Rossa Subscribed Owner
    Jan 5, 2002
    16,071
    Portland, Oregon
    Don
    1957 picture looks a bit precarious!
  2. enio45
    enio45 Formula Junior
    436
    Gilbert, AZ
    Ed
    #252 enio45, Jul 7, 2017
    It has been a while since i updated my restoration progress - pics below
    We tore the transmission apart to check everything over, installation of new seals and new bushings on the throwout bearing shaft. Full detail, black oxide washers and nuts and reassembled. Good news - there were previous indications that this was rebuilt - and the insides looked very very nice.
    SO for once....limited expense involved on this aspect....thats a win.
  3. enio45
    436
    Gilbert, AZ
    Ed
    #253 enio45, Jul 7, 2017
    With the body setting waiting sufficiently for the 2nd coat of epoxy primer to dry before another block sanding - i went ahead and fit the front suspension bushings, shafts and associated parts to the frame so that when the time comes after painting the underneath of the car - all we have to do is install. All the end play specs are done and ready to go.
  4. enio45
    436
    Gilbert, AZ
    Ed
    #254 enio45, Jul 7, 2017
    Much work has been going into the wiring harness - when i got the car everything was disconnected, including the fuse board. So with a lot of patience, i figured out where everything went, what was short because of a cut wire and was able to effectively recreate the operation of the car by applying power circuit. I built this stand to house my gauges and switches to help the process.
    With all this finally done, I'm having a new harness made for the car and will deliver my old harness next week to "YandZ Yesterday Parts". I visited them in CA to see what and how they do this and look forward to the finished product. They had previously made an Ellena and had that original harness in their stock of harnesses. In fact there were about 20 different early ferrari original harnesses there as reference for them.
  5. enio45
    436
    Gilbert, AZ
    Ed
    #255 enio45, Jul 7, 2017
    One item i could use help with is locating any of these original dash lights.
    I wanted all the same color - but not sure what was original when the cars were made.
    i have a few different colors - but maybe someone has a few in there stash they can help me out.
    Here are a few pics....these little lights are tied to the toggle switches to let you know they are on...there are 3 of them and one for the ignition switch.
    Let me know if you know where i can find some nice originals!!
  6. enio45
    436
    Gilbert, AZ
    Ed
    #256 enio45, Jul 7, 2017
    ON the Ellena and as well for the Boano, there are six pieces of the body side moldings.
    My pieces were beat up pretty good, some short due to others filing and refinishing them. SO i decided to make engineering drawings of all 6 pieces. After a few test runs and adjustments we have perfected the production of these again. We use the CNC with the engineering drawings and can make all 6 pieces. They are slightly longer which will require fitting the pieces to the car, as every car is a little different in length etc. The backs are exactly like the originals and are held on with a slotted bolt and nut. Once i fitted them to the car and massaged the ends to fit perfectly - i sent them out for polishing.
  7. Tired of seeing this ad? Upgrade now
  8. John Vardanian
    John Vardanian Formula 3
    2,489
    San Francisco Area
    John Vardanian
    Thanks for sharing Ed, you're doing great by this Ellena.
    john
  9. enio45
    436
    Gilbert, AZ
    Ed
    Thank you john and also for your advise......paint is getting real close and then suspension assembly is next.
  10. scuderia328
    scuderia328 Formula Junior
    349
    BIARRITZ, FRANCE
    Congratulations ! Good project !
    All the Best,
    Cyrille
  11. fiatosca
    fiatosca Karting
    64
    Bloomfield Hills, MI
    Bob Boniface
    These appear to be identical to the units fitted to Alfa Giuliettas. Reoriginals in Texas has new ones in all colors Light for dash, green, brass barrel behind dash, small... - L0266X
  12. enio45
    436
    Gilbert, AZ
    Ed
    Thanks Bob, i emailed Matt and did not seem to get much help....ill try to call him - I'm not sure that web site is al that accurate anymore - i have not seen anything ferrari updated in yrs - IMO.
    A call is in order....
  13. fiatosca
    fiatosca Karting
    64
    Bob Boniface
    The good news is that the lights appear to be a common Giulietta part which may make finding them a bit easier.
  14. Tired of seeing this ad? Upgrade now
  15. enio45
    436
    Gilbert, AZ
    Ed
    Yes, Ill expand my search!!
  16. enio45
    436
    Gilbert, AZ
    Ed
    Anyone have any thoughts/ recommendations about polishing glass.
    On my 58 Ellena resto, I'm going to use the orig front and rear glass from the car.
    I'd like to clean it up and try to remove some minor defects.
    IS there a recommended process or procedure or product to use?
    Heck, the last thing i need is to crack the glass....already been there on the side glass - so i now have 2 new side glass pieces for the project.
    Appreciate the thoughts
  17. TTR
    TTR Formula 3
    1,253
    Riverside, CA
    Timo
    #265 TTR, Aug 5, 2017
    I've offered my thoughts and experiences on this subject several times over the years, most recently in "Old glass - New thread" in Detailing & Showroom section of this forum.
    You might want to read there.
    I have over 20 years of experience producing curved glass for all kinds of custom and obsolete applications with hundreds(?) of satisfied clients around the globe. There's been more than one occasion my glass has been on a cars displayed at Pebble Beach and other prestigious Concourses around world. There'll be at least one again at Pebble in couple of weeks.
  18. readplays
    readplays Formula 3
    Aug 22, 2008
    1,402
    New York City
    Dave Powers
  19. TTR
    TTR Formula 3
    1,253
    Riverside, CA
    Timo
  20. readplays
    readplays Formula 3
    Aug 22, 2008
    1,402
    New York City
    Dave Powers
    Hi Timo,
    I went to the thread you cited and saw your posts on the first page. I copied the URL from the top of my screen and pasted it into a reply.
    If I wanted to link a specific reply in the thread (in this example, your first reply) I would open the thread page, go to the reply I wanted, and click on the post number.
    It's on the top right corner "#10" and it's clickable.
    Clicking that post number would open a window containing that post reply. I would copy the url of that page and post it in my reply to the original thread and the result would be this-
    http://www.ferrarichat.com/forum/145384379-post10.html
    Dave
  21. TTR
    TTR Formula 3
    1,253
    Riverside, CA
    Timo
    #269 TTR, Aug 5, 2017
    Hi Dave,
    Thanks for this too.
    Always happy to learn something new. :)
    I just photocopied this post to my iPad and desktop so I can reference it next time a need arises to offer a link.
    And now I can return to my regularly scheduled program, restoration of old cars, which today includes finalizing the installation of a yet another ill-fitting new/reproduction Daytona replacement exhaust system which required fair amount of corrections and tweaking.
    Even the NOS U.S. headers proved anything but straightforward installation, although this system appear to require much less work than the previous one (Euro spec) I installed couple of years ago.
    Timo
  22. ShadowLAP
    ShadowLAP Rookie
    6
    Illinois
    Larry
    Looking forward to seeing update on the restoration.
    ShadowLAP
  23. ShadowLAP
    ShadowLAP Rookie
    6
    Illinois
    Larry
    Looking forward to seeing progress updates on this exciting car.
