Ferrari f430 wheels on 360? | FerrariChat
Discussion in '360/430' started by AlamGil, Sep 20, 2017.
  1. AlamGil
    AlamGil Rookie
    Mar 19, 2013
    24
    Someone out here that can give me some advise? im looking at a set of wheels online right now are on a 430 spider, (22" rear ,20" front) would this fit on my 360 spider without any issues? Fender and caliper Clearance ? Thank you.
  2. FlyingHaggisRacing
    FlyingHaggisRacing Formula 3
    Jul 2, 2013
    1,368
    In terms of std wheel offsets, the 430 and 360 are the same.
    I don't know if tyres on 20"/22" wheels would rub or not - but I think they might.
  3. AlamGil
    AlamGil Rookie
    Mar 19, 2013
    24
    Thank you for your advise...
    And the tires are 285/25/22 rear and 235/30/20 front. Is anyone out there runing on this set on a 360?
  4. F1Spider
    F1Spider Karting
    Jan 8, 2013
    199
    Austin
    Stuart
    I have a set of F430 rims on my 360. The bolt pattern is the same. The difference is the rim size. 360 OEM rims are 18". The 430 standard rims are 19" and they clear just fine in the wheel wells.
    20" front and 22" rears will rub on a 360. You would need spacers and you would also have to adjust ride height or upon that first dip in the road you will get serious road rash on the top of your wheel wells and possibly damage your tires.
  5. Mikael-F360
    Mikael-F360 Formula Junior
    Apr 3, 2017
    751
    Finland
    Mikael E.
    Start from calculating the wheel total diameter with https://tiresize.com/calculator/
    Your stock wheel diameters are:
    Front 25.6"
    Rear 26.7"
    The wheels you suggested:
    Front 25.6"
    Rear 27.6"
    Now it's common knowledge that you should not change the wheel total diameter in a 360 more than +/- 5% or you will get ASR and ABS system problems.
    Your rear tires are bigger than stock, so the car will be at a different stance.
    Also note that with those 20" and 22" wheels, most likely you will rub and destroy your fender lips. I don't recommend using more than 19" wheels on the car.
    And to be honest, anything over 19" on a 360 just makes it look silly. Like it's on cartwheels or something.
  6. AlamGil
    AlamGil Rookie
    Mar 19, 2013
    24
    Thank you guys! And yes I just browse some pictures online of a car with 22" rear wheels and besides the clearance issues it does not look good. I think f430 factory wheels looks nice on a 360 maybe 19/20 setup would be the tops , I really appreciated your input guys! Take care!
  7. blackbolt22
    blackbolt22 F1 Veteran
    Sep 25, 2007
    5,752
    Boca Raton, FL
    Mr. Anderson
    Standard 430 wheels do fit a 360 and IMO they look great. I agree that anything larger will not look good for many reasons. The larger wheels will make the small rotors look even smaller.
  8. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    I'd like to get 19"s.... but I wouldn't get bigger than that for performance and esthetic reasons. 22's are more appropriate as dubs on an NBA players Bentley.
    Mikael-F360 likes this.
  9. Mikael-F360
    Apr 3, 2017
    751
    Finland
    Mikael E.
    ...And you can always put 19" 430 Scuderia wheels on. They have curvy spokes, so IMHO they look best in a curvy car like the 360 is. There are sets of Scuderia wheels available at the fleabay regularly.
