Gauges Restoration - 58 Ellena | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by enio45, Jul 5, 2017.
  1. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    Getting ready to send out my 58 Ellena gauges for restoration.
    Looking for some recommendations / thoughts
    tach and speedo - water temp, oil pressure and oil temp, clock and fuel.
    Appreciate the thoughts / recommendations?
  2. StephenB
    StephenB Formula Junior
    304
    S Florida
    Stephen Bruno
    I have used them on many cars including vintage Ferrari's always do a good job. Not cheap and they take a long time.
    Palo Alto Speedometer, Inc.
    718 Emerson Street
    Palo Alto, CA 94301-2410
    Phone: (650) 323-0243
    Fax: (650) 323-4632
  3. 4redude
    4redude Formula Junior
    Jan 13, 2005
    726
    Fungus Corner
    Brian Keegan
    Home
    Used these guys for decades. IMHO, better than Palo Alto,
    usually less expensive depending on what gauges need and quicker.
  4. prance
    prance Formula Junior
    May 4, 2005
    513
    Agoura Hills
    morris
    Palo Alto speedo is the only place I would use. They are the best. Hartmut will do whatever it takes to make you happy. They have all of the parts and do an excellent job. I say this after sending many gauges to him. Highly recommended. I've tried everyone else and he is the only one I trust.
    Morris
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,239
    Frederick, Maryland
    Brian Brown
    Both Palo Alto Speedometer and MoMa do excellent work. I have used both and have been
    very pleased with their services.
    MoMa literally made a missing gauge for a 166 Barchetta out of next to nothing, and it was so good that no-one ever knew that it was not original. They would take a little longer than Palo Alto Speedometer, but the results were spectacular. The owner of MoMa, Margret died a few years ago and I think that one of her employees (Jose?) took over the business. He is very knowledgeable regarding all type of vintage gauges, just look at the photos on their website.
    Hartmut at Palo Alto Speedometer is a gauge wizard/guru. His work is also exceptional.
    I don't think that you can go wrong with either shop.
  6. TTR
    TTR F1 Veteran
    5,198
    Riverside, CA
    Timo
    +1 on both, MoMa & P.A.S.
  7. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    Ok thank you guys.....this is what i expected as the usual competent restorers.
    Ill contact both to discuss what i need......
  8. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    #8 enio45, Jul 6, 2017
    Here are my gauges currently:
    I had the fuel sending unit already done last yr as i had the fuel sending unit repaired and they synchronized the gauge to the unit and restored it as well.
    I also had an Ellena Clock made for me - thru Patrick Ottis (thanks to his help) - Franco in Italy made an exact duplicate of the clock that i had missing.
    The rest of the gauges will need to be redone.......will report back on my experience
    I had this little stand made to mount the gauges and hook up all the wiring outside of the car. When i got the car all the harness was disconnected including the fuse box and NOT labeled...I was able to get everything reconnected and now I'm ready to have a new harness made. Very long process for figuring out what went where.....now i know every color, connection point and can do it in my sleep!!
  9. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,046
    San Francisco Area
    John Vardanian
    A little off topic, but does anyone know when Ferrari started caring about the non-Italian speaking customers? I am referring to the English gauges. My '59 has English gauges, now I see a yet earlier car with them. Thanks in advance.
    john
  10. enio45
    enio45 Formula 3
    1,538
    Gilbert, AZ
    Ed
    Good question John, assume your referring to my gauges that i posted?
    These are the same gauges that are used in the TDF cars as well.
    Ill have to look to see if the BOANO gauges were in English and Italian as well. That would push the date back to 56 if they were.
  11. coryh
    coryh Karting
    Nov 26, 2011
    104
    #11 coryh, Jul 7, 2017
