1. I have started the new week 1 FerrariChat Update poll, please vote... http://www.ferrarichat.com/forum/threads/ferrarichat-com-update-week-1-poll.560487/
  1. oriffx
    oriffx Rookie
    Jul 29, 2007
    25
    Chester County, PA
    Hello all,
    In preparation of installing a 4 post lift in the garage, I ran into a problem that apparently many have here - low lying garage rails/opener. I have to convert the garage door assembly into a "high lift" type so that the cars won't hit. Anyone have any experiences with this?
    Also any recommendations on who could do it in the suburban Philly (Chester county) area??
    Thanks,
    RM
  2. tiger 6
    tiger 6 Karting
    Aug 7, 2004
    95
    virginia
    Stephen C Darrah
    RM,
    Easy to do. You need to have ~ 12 feet in height inside the garage to have sufficient clearance between the top of a car on the lift and the ceiling when the lift is raised. If you have the ceiling height, all you need to do is reposition the door rails and have a longer garage door. Check with the folks who installed your current doors. Should be a sticker on the door with phone no. etc
  3. autowerks9
    autowerks9 Formula 3
    Sponsor
    Sep 1, 2009
    1,036
    North Wales, Pa.
    David
    #3 autowerks9, May 4, 2010
    The easiest way is to raise the lateral brackets/tracks and add the need lengths to the bottom that run vertical to the frame. ( called a high lift track)
    The best choice is a wall mounted motor with tortion springs. This eliminates the motor and drive track in the center for clearence.
    Here is an example.:
  4. oriffx
    oriffx Rookie
    Jul 29, 2007
    25
    Chester County, PA
    Is the wall mounted motor with torsion springs the same thing as the Liftmaster or Jacklift? It seems to be highly recommended.
    Thanks for advice.
  5. JCM
    JCM Karting
    Oct 19, 2004
    62
    Williamsburg, VA
    John McCauley
    Do 2 thigs:
    1. Side track extensions - w/std door height this will also limit the amount of door over car at top lift height
    2 - Jackshaft (I bought Liftmaster model) opener - Mounts on the jackshaft (the bar across the top with the springs) and allows for full clearance over lift based upon #1 above.. Mine is installed thusly at 12' ceiling height.
    I also have 2 ceiling fans over lift and generally keep a Mustang GT w/big wing on top lift height. Lift is Superlifts SR-7H. I could get photos this weekend if it helps.
  6. jsanocki
    jsanocki Formula Junior
    Aug 30, 2006
    762
    NJ
    Ok, let me give you some personal experience from someone who just built a house and went through this exact same situation....
    GARAGE DOOR OPENER:
    You WILL have to replace it. Get a wall mounted unit. I went with the Wayne Dalton iDrive. It isn't that much ($250?) and works great. This is assuming you have a torsion spring garage door opener, which if you don't, you might as well get one....
    GARAGE DOOR TRACKS:
    Replace your existing tracks with high lift tracks, giving you an extra 8" or so above a standard track. This gives you the little bit extra height you need. You can re-use the existing garage door, no need to replace it.
    HEIGHT REQUIREMENTS:
    Again, everyone will tell you the more height the better, but I have a garage underneath the house, and it had a gross wall height of 10'. Then you subtract for double 5/8" sheetrock on the ceiling, and losing for the concrete slab (the garage is actually in the "walk out basement" of the house, superior wall foundation walls, so slab is poured after walls are set), I have about a 9' 8" ceiling height. Using a 4 post lift I am able to have a 360 and M3 at the same time. Its tight, but it works. The depth of my garage is more than average (28') so I can successfully put a car on the lift and while the garage door will extend over the car slightly, it stops before it reaches the roof of the car, in which point it would hit. So you need to load the cars on just right, and measure out for proper positioning of the 4 post lift.
    INSTALLER:
    The guys who were able to get my iDrive's configured just right was actually a larger commercial door company, but they are great. Abstract Overhead Door in Croydon PA. (215) 781-1500. Very reasonable price, and professional fast service. They can handle the tracks, iDrive's, etc.
    GOOD LUCK WITH THE PROJECT!!!!
  7. Tired of seeing this ad? Upgrade now
  8. autowerks9
    Sponsor
    Sep 1, 2009
    1,036
    North Wales, Pa.
    David
    Liftmaster, would be my recommendation..we use them in all of our shops. Doors get used about 100 times a day.
    the wayne Dalton door and torsion spring setup I have in my home garage but not the "i-drive" motors as noted above. Although I may switch to 1 of them for my door when the lift goes in.
    +1..on having a door company do it. less agg and should take no more than a few hours.
  9. oriffx
    oriffx Rookie
    Jul 29, 2007
    25
    Chester County, PA
    I'm probably going to go with the Liftmaste 3800. Seems like a safe bet.
    Definitely going to have a garage door company do the conversion. Definitely beyond my capabilities. Plus I don't want to screw it up.
    Thanks for all the great advice from everyone.
    RM
  10. moorfan
    moorfan Formula Junior
    753
    Central Virginia
    Pete
    I had the same problem prior to my 4 post lift going in. I had to buy a new opener that sat flush to the ceiling, and the rails were also raised to the ceiling. Lastly, there were segments that had to be added to the top of the door. It was done in 2/3 of a day by a local overhead door company here, and cost me about $1200.
    I have exactly 10'6" vertical clearance...I got a lift with a 74 inch vertical rise, and can put the 360 all the way to the top without a problem.
