Thank you for the explanation.
All our 355 exhaust systems are of the two chamber version. We recognized this problem already in 2002. I would use a remote control only in case that an exhaust is equipped with this two chamber system. We have not new remote control kits which are quickly installed. Maxium duration of installation is 2 minutes and this can be carried out by everyone. The remote control kits are designed in a way that the installation is really to be made by everyone. This remote control is very favourable (approx. 250,00 Euro ex works). The company Taurino Racing , the USA distributor of Capristo exhausts, makes currently a special sales offer. If someones buys a valve-controlled exhaust system, the remote control is added free of charge. The special of this newly designed remote kit is that there is no additional current required for its operation. Furthermore it is not necessary to connect any tubes. You just have to disconnect the plug from the original electro-magnetic valve and this plug is connected with our receiver. Our receiver is connected to the original electro-magnetic valve. Consequently our receiver serves as a bridge in between. It is not necessary to make any further connections. There are car models equipped with 1 exhaust gas valve like the 355, 550 Maranello or 599 while the models 360 and 430 and other vehicles as well are equipped with two valves, our remote control provides the option to connect it either to 1 valve or to 2 valves. As the exhaust gas valves do not work in the same way, e.g. the 355 valve works different compared with the 360, the remote control is equipped with a sliding putton providing the option to chose between two versions. This remote control can be used for every exhaust system coming with valves. So you can use our remote control kit also for original exhaust systems. Ciao, Antonio Image Unavailable, Please Login
What is the part number for the 355 version of the remote control unit and what is the cost? Thanks, Geno
I have been selling the Capristo bypass valves as a replacement part for $ 995.00 USD. The wireless remotes $795.00 USD.
