Rust ☹️[emoji36] | FerrariChat
Rust ☹️[emoji36]
Discussion in '308/328' started by Claudia k, Oct 17, 2017.
  1. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
  2. wildcat326
    wildcat326 Formula 3
    1,777
    Chicago, IL
    Justin
    Is that the only rust area you've spotted so far? Did you open the fuel filler grills and check underneath the doors? The recommendation will vary depending on the scope of how large/many areas we're addressing.
    Claudia k likes this.
  3. wildcat326
    1,777
    Chicago, IL
    Justin
    Actually, while we're at it, maybe snap some shots of everything around the car, and we can give you some crowd sourced guidance on where you stand.
  4. Benneke
    Benneke Karting
    Feb 26, 2014
    120
    Belgium
    Benny
    Those tires look like they need to be replaced as well!
  5. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
    The tires do! They are on my list! This is the only exterior rust I’ve found so far.
    -Claudia k
  6. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
  7. wildcat326
    1,777
    Chicago, IL
    Justin
    What concerns me is that the fasteners around the wheel well liner also look shot, which means this car either was driven through a lot of splashed water, submerged, or parked in humidity. Your year is not rust-proofed, so it's bad news for sure, and - given the position of the spot on the panel lines - panel probably is shot. Looks pretty deep. So the question is going to be: 1) Do you have a body shop sand off, fill/repair/repaint all the problem areas at once as a single job, or 2) if it's isolated to one spot only, cut out and purchase a salvage panel to weld on? Need to investigate the extent of rust issues first.
  8. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
    To me it looks bad. It’s been sitting 20 plus years aside from a start up my dad would do here and there weekly to keep it active. So who really knows :( I will take a better picture of the whole sides ASAP for you to have a better idea on what you think I should do.
    -Claudia k
  9. wildcat326
    1,777
    Chicago, IL
    Justin
    #9 wildcat326, Oct 18, 2017
    Double check all around the lip of the front hood and the six inches of nose ahead of the hood, too. Your sure you checked the door bottoms & sills, and the same rear curve to the front wheel wells? Try to peek up through the front grill under the nose badge area. Look for signs of paint bubbling around the enamel hood badge and pininfarina badge on the side. Also look at the seam line between the rear wheel arch and the c-pillar "buttress." Most of these early cars have SOME superficial rust, but it's important to know the extent of the bad parts.
  10. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
    On it! :) I shall do so! Going to lift it up this Sunday and get under it. Really see what I’m working with.
    -Claudia k
  11. wildcat326
    1,777
    Chicago, IL
    Justin
    Once you have it lifted, remove the wheels and pull the fiberglass wheel well liners, which will let you see the inside of the quarter panels. The fiberglass liners take some careful twisting and maneuvering, but pop out pretty straightforward. Watch you don't scrape the wheel well paint. If it really is just that one area, you can either find a patch panel or partial rear end clip. But I fear - if you have one spot that bad - you may be in for some other surprises.
  12. wildcat326
    1,777
    Chicago, IL
    Justin
    Don't get too scared by superficial rust on the chassis undercarriage. But document everything in pics for us, and we'll reconvene then.
  13. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
    I fear this too. I will do more investigating! Thank you so much!
    -Claudia k
  14. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
    You are amazing!
    -Claudia k
  15. Patrick Dixon
    Patrick Dixon Formula 3
    Mar 27, 2012
    1,084
    I wouldn't worry about it for now. Go through brakes, fuel lines, coolant hoses/system, check the electrics and get it running. Then you can worry about the bodywork. The paint looks really flat but you can get to that once you have driven it.
    Claudia k and dflett like this.
  16. dflett
    dflett Formula 3
    Jun 24, 2005
    1,603
    NY
    David
    Also check inside the sills by pulling up the carpet between the seats and the door. The GTBs are prone to rust there.
  17. absostone
    absostone F1 Veteran
    9,233
    That will need to be cut out and a new panel section welded in. It looks pretty deep. I would bet the inner arch support will need to be adressed as well
  18. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I think this is the tip of the ice berg. Good luck
  19. HotShoe
    HotShoe F1 Veteran
    7,505
    Lake Worth, FL
    Anthony Lauro
    Cut it out and weld in a patch panel. Using filler or fiberglass is a hack fix.
    It really isn't any different than working on any other older car and quite common. I do it all week long. It could get expensive depending on how extensive it is. A spot here or there is no big deal. Considering the high cost of replacement panels I'd recommend finding a fabricator that can do it from blank sheet. Then you are basically just paying for labor.
  20. Russ Gould
    Russ Gould Formula 3
    Nov 8, 2004
    1,073
    Are you sure this is not a flood car? That's the nastiest engine compartment I have ever seen. If it is, you are wasting your time, start thinking "part it out".
  21. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    She is not going to part it out. This is from her father. But it does look like a basket case requiring a labor of love, and $20K. Best of luck Miss Khalil.
  22. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Looks like an 81 or an 82
  23. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
    It’s not a flood car. Thanks for the input I won’t be parting it out. I’ll be fixing it up step by step.
    -Claudia k
    355dryva likes this.
  24. Claudia k
    Claudia k Rookie
    Oct 14, 2017
    38
    Claudia khalil
    Thank you!! :)
    -Claudia k
  25. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,084
    SanFrancisco BayArea
    1983 US 308 GTS QV
    The presumption so far is that the rust needs to be fixed.
    My opinion is to get it back on the road again and just enjoy the darn thing as-is.
    The good news is that with a body that needs work, you can park carefree anywhere you want. Get a nice paint job and suddenly that all changes!
    Nuvolari, kerrari, detroiter and 2 others like this.
