The Restoration of -1963 Ferrari 250 GTE #4879
Discussion in 'Vintage (thru 365 GTC4)' started by Martin M, Apr 6, 2013.
  1. I have started the new week 1 FerrariChat Update poll, please vote... http://www.ferrarichat.com/forum/threads/ferrarichat-com-update-week-1-poll.560487/
  1. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #1 Martin M, Apr 6, 2013
    Hello,
    Here is the story how 1963 GTE series III s/n 4879 will have full restoration.
    The car is bought from Sweden - Lomma in 2011 via ferraris-online (Michael Sheehan).
    Previous owner was Leif Nillson who started with the restoration over 10 years ago but did not finish it.
    Some pictures of Classified Ad
  2. PAUL BABER
    PAUL BABER Formula 3
    Nov 1, 2006
    1,041
    London. UK.
    Paul Baber
    That has the making of a great car. Good luck with the restoration. However the steering wheel is strange. Its obviously missing one of the three arms but appears to be correct otherwise. The condition of the wood rim suggests it might be a new replica but if you think its original are there signs of someone having previously sawn off the third arm ?
  3. Julius H.
    Julius H. Formula Junior
    698
    Europe
    Julius
    Good luck Martin with restoration and share here some pictures,info during the process.
    Julius
  4. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #4 Martin M, Apr 7, 2013
    s/n number
  5. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    Paul, yes the steering wheel one arm was probably broken, I closely looked and I can see the old traces there.
  6. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #6 Martin M, Apr 7, 2013
    And here we go!...
  7. Tired of seeing this ad? Upgrade now
  8. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #7 Martin M, Apr 7, 2013
    Finally back home and work with the car can start in our workshop.
    As we pulled out the engine we we understand that there is no good signs of the 10 years past engine rebuild what Mr Nillson told us. We tested the cylinders compression and got the results very poor. We thought that the compression rings are stuck by the years. So we checked the timing what needed adjusting and we started the engine on the bench.
    At first the oil filter blowed when the engine fired. New adjustings with the oil pressure relief valve and new test start.
    The engine runned very rought and exhaust gas color was as rainbow, we tried to adjust carburettors but it did not make any sense.
    Now what?....disassemble!!?
  9. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #8 Martin M, Apr 7, 2013
    dissamble
  10. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #9 Martin M, Apr 7, 2013
    engine shop and new pistons
  11. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #10 Martin M, Apr 7, 2013
    assamble
  12. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #11 Martin M, Apr 7, 2013
    cylinder heads and studs
  13. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #12 Martin M, Apr 7, 2013
    Some of the original head studs had damages on the threads and other 5 or more
    draw out. So we planned to fabricate new studs from 42CrNiMo4 steel (if I remember it correct). After tempering the Rockwell hardness results was 40 HRC.
  14. Tired of seeing this ad? Upgrade now
  15. Enigma Racing
    Enigma Racing Formula 3
    1,109
    London
    Kim
    Great pictures thank you
  16. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #14 Martin M, Apr 7, 2013
    carburettors.
  17. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #15 Martin M, Apr 7, 2013
    plating and gear
  18. wizzells
    wizzells Karting
    Jul 16, 2005
    229
    Milwaukee, WI
    Fantastic pictures! Thanks for sharing.
  19. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #17 Martin M, Apr 7, 2013
    starter and alternator
  20. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #18 Martin M, Apr 7, 2013
    Getting ready for first start up. Checking the spark plugs in pressure cabin and the color of combustion in every cylinder.
  21. Jamie H
    Jamie H Formula 3
    1,666
    Puslinch,ON
    Jamie
    Martin,
    Great pictures !!
    Thank you for sharing
  22. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #20 Martin M, Apr 7, 2013
    When running the engine first couple of hours we find out that brand new Elring head gasket have failed. So I ordered new custom made gaskets from "ferraricraft". The core was softer and unnecessary water passages was blinded. At the moment they work well.
  23. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    Gentlemans, how can I "turn the page" here?
    I want to upload next process pictures here but otherwise becomes too cluttered in one page.
  24. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,586
    Santa Fe, NM
    you get someone like me to say "bravo" and "keep them coming" for another post or two . .
  25. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,586
    Santa Fe, NM
    . . . and then your next post (21) will be at the top of the next page.
  26. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #24 Martin M, Apr 7, 2013
    Thanks guys! I have bunch of pictures more to upload I hope that you do not get tired.
    So the engine is ready and under the blanket.
    Next step - matching the nose and chopping the firewall !
    Left front has been involved in a little crash, I think the metalwork has been done without the grill because it do not match even it has nr 616 stamped in like as other interrior panels.
    greetings from my nephew there :)
  27. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #25 Martin M, Apr 7, 2013
    Original paint codes and measuring the putty under the paint.
  28. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #26 Martin M, Apr 7, 2013
    Aluminium firewall chop and new fabrication.
    It was lucky to ask at the last minute "do you have the original firewall panels left" ?
    "Yes, I have but some wall edges are throw away"
    Thank god!
  29. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #27 Martin M, Apr 7, 2013
    a lot of measuring
  30. donv
    donv F1 World Champ
    Rossa Subscribed Owner
    Jan 5, 2002
    16,065
    Portland, Oregon
    Don
    Bravo! This is great, thank you for sharing.
  31. 330 4HL
    330 4HL Formula Junior
    674
    Vancouver
    Rick Bradner
    massively impressive project and documentation.
    how much oversize were new pistons?
  32. Jamarico
    Jamarico Karting
    Nov 30, 2012
    117
    Switzerland
    Marco
    Thanks for the amazing pictures!
    Is the the car blu pozzi painted?
  33. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    Thanks!
    Rick, 73,5mm are the new pistons.
    Marco, I will check the paint card tomorrow. The car will have new paint coat you will see from upcoming pictures.
  34. tritone
    tritone F1 Rookie
    3,683
    On the Rock
    James
    BRAVO MARTIN!!!
    Super impressive, the amount of work and your precision! As so often the case, the car looked "pretty good" in the early pix; hiding a lot needs....
    And your photo-documenting skills are just as good!
    Thanks so much for the posts; this thread is a real contribution to FChat.
    Good luck,
    Tritone
  35. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #33 Martin M, Apr 7, 2013
    wall 2
  36. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #34 Martin M, Apr 7, 2013
    wall 3
  37. Julius H.
    698
    Europe
    Julius
    highly detailed documentation.thumbs up
    Seems that GTE will be like new.
    Next year will start full restoration of my 4295 also
  38. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #36 Martin M, Apr 7, 2013
    These panels were probably rotted, cut out and throw also away. I looked and zoomed chunk of images what I found on the internet of different cars.
    The pattern is made with revolver CNC punch.
  39. grngts
    grngts Karting
    99
    Bothell, WA
    Bob
    Martin - Very impressive and informative photos for anyone with a 250. The one photo with the starter on the engine reminds me of when I removed, rebuilt, and re-installed the starter on my 250 GTE while lying under the car. That nut between the starter and engine was a bugger.
  40. tongascrew
    tongascrew F1 Rookie
    Jan 3, 2006
    2,989
    tewksbury
    george burgess
    After considerable time spent on this thread and recording much of it for my files, certain things come to mind. This car is fifty years old, was basicly hand built and is not that much different from the extraudinary competition cars by the same maker of only a few years before. So lets consider what it takes to do what these pictures show. The skills to do an engine rebuild,to rebuild the interior body work never mind the other projects not yet delt with. Just the engine alone is remarcable. Conside the difference between a 1963 Ford engine and the Ferrari engine of the same year.Two basics immediately come to mind.The difference in the RPM redlines and the BHP per cibic inch of the two. So let's give credit to those who skills it takes to return that 1963 Ferrari V12 and those who hand build and install those previously hand built body pannels to what might be considerd even better than original.And now it starts to come clear why undertaking such a project consumes the time and money that it does. This thread is invaluable. There should be more like it. tongascrew
  41. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #39 Martin M, Apr 7, 2013
    mudguards, gearbox tunnel
  42. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #40 Martin M, Apr 7, 2013
    somebody has cut the flange of gearbox tunnel, dont know why
  43. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #41 Martin M, Apr 7, 2013
    under fender heaters, rusty
  44. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #42 Martin M, Apr 7, 2013
    pedals, brake cable
  45. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #43 Martin M, Apr 7, 2013
    front suspension
  46. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #44 Martin M, Apr 7, 2013
    Original Dunlop calipers - overbored 0.20mm, lathed new brass pistons.
  47. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #45 Martin M, Apr 7, 2013
    front brake disc aluminium guards
  48. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #46 Martin M, Apr 7, 2013
    Rear axle and leaf springs
  49. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #47 Martin M, Apr 7, 2013
    Chrome details before plating
  50. JeremyJon
    JeremyJon F1 Veteran
    Jul 28, 2010
    7,265
    Calgary, Canada
    wonderful thread, delight to see the normally hidden areas of the car! :)
  51. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #49 Martin M, Apr 7, 2013
    details taken care of
  52. Martin M
    Martin M Karting
    Nov 30, 2011
    117
    Estonia
    #50 Martin M, Apr 7, 2013
    After plating
