Valve shim clearance on 89 Countach Anniversario Carb? | FerrariChat
Discussion in 'LamborghiniChat.com' started by BlueBiturbo, Sep 3, 2017.
  1. BlueBiturbo
    BlueBiturbo F1 Rookie
    May 19, 2004
    3,967
    Jakarta
    TS
    Helping my friend's car set his valves.
    Anyone has the numbers?
    Thanks.
  2. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,009
    Switzerland
    Raymond S.
    As far as I remember all Versions are same, inlet 0,25 outlet 0,50
  3. BlueBiturbo
    May 19, 2004
    3,967
    Jakarta
    TS
    Same as my LM002.
    Thanks Raymond
  4. I think it's 0.35 and 0.50. Probably better if you double-check with a specialized shop.
  5. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,009
    Switzerland
    Raymond S.
    Jalps owners Manual says:
    Valve clearance (with cold engine)
    -inlet
    -exhaust
    0,45 mm
    0,5 mm
    Check the same on the QV Manual, it's in there.
  6. BlueBiturbo
    May 19, 2004
    3,967
    Jakarta
    TS
    The car didn't have a manual.
    Only a Diablo 6.0 manual.
  7. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,009
    Switzerland
    Raymond S.
    I'll check at home, I have all owners Manual as well the 25th maintenance.
  8. BlueBiturbo
    May 19, 2004
    3,967
    Jakarta
    TS
    Thanks Raymond
  9. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    820
    Leesville, SC USA
    Chadbourn Bolles
    They are .35 mm on the intake cold
    .50 mm on the exhaust cold
    Chadbourn Bolles
    803 532 6257
    803 798 3044 cell
    [email protected]
  10. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    #10 Jalpa_Mike, Sep 4, 2017
  11. BlueBiturbo
    May 19, 2004
    3,967
    Jakarta
    TS
  12. MiuraP400
    MiuraP400 Formula Junior
    Feb 3, 2008
    939
    Arizona
    Jim
    Valve lash is determined by the cam design. The DD and the FI cars use different cams. Do both cams have the same valve lash?
    Cheers Jim
  13. Chadbourn Bolles
    820
    Leesville, SC USA
    Chadbourn Bolles
    Cheers Jim
    Jim, according to the QV carb and FI manuals, yes they do.
    Chadbourn Bolles
    803 532 6257
    803 798 3044 cell
    [email protected]
