Thinking of getting a Scuderia. Any recommendation which year to get?
Although, with carbon fiber package the car are identical, it seems that the market and resale values are higher on 2009. This is for no apparent reason especially if all picked options are the same. If you are looking for a better buy go with 2008 but remember that if you sell it you may get hit a little for 2008 vs 2009
The 2009 was delivered with a different TCU and instrument cluster. The TCU software was eventually applied to the earlier cars at service time so in theory every Scuderia should have it, but some slipped through (I have a couple of units that were never updated).The software on the ion sensing module was revised too. The impact of the elrctronic changes however is small - not worth getting hung up over. The big difference was the improvement in quality of the carbon fibre.
You want to get a 2009. As mentioned before, the resin on the carbon fiber was corrected so that it doesn't get "milky". This alone can cost you thousands of dollars to rectify. In addition, I believe the late model 2009 also had improved front headlights which are less likely to develop "spiders". This can be a very annoying cosmetic problem. It also costs thousands to replace these. I had a march production 2009 and it had zero carbon fiber "milking" and zero spiders in the headlights. Almost every 2008 I have seen have both of these problems.
Many 08 cars have already had the carbon panels replaced under warranty. I believe there was also some additional heat shielding added in the engine bay as part of a service campaign. My 08 had this done and there hasn't been any issue with milky CF. There was never a fix for the headlights. I've seen plenty of 09s with webbing. Even if you buy new replacement headlights today, they can still develop it. I had mine opened up and cleaned out. This was done almost 2 years ago and they still look perfect.
I have a 2009 which was delivered in March 2009 - I can't get to car to see what the build date is on plate but I have experienced both milky CF over headers and coolant cover, yellowing air boxes and spider lines on headlights. I not sure if they ever fixed an of these issues unless it was late in 2009. I know the refinished one ( covered under warranty) were better. If i remember correctly, it was a collision shop in Georgia that did them for Ferrari. So maybe having a car that the CF pieces were covered under warranty may be the way to go.
Do you have any actual proof that the resin was bad on 2008s or that the headlights are more susceptible to spidering, or is this speculation based on anecdotal evidence? This sounds like forum "knowledge."
When I refinished the carbon panels (side) in the engine compartment they put heat shields on the bottom side - that was several years ago and no problems - mine is a 2008 and never had headlight problems Image Unavailable, Please Login
There were larger heat shields fitted to the rear two panels in 2009, to protect the panels from the tailpipe/valve assembly.
