348 Engine Out!! | FerrariChat
348 Engine Out!!
Discussion in '348/355' started by FandLcars, Apr 4, 2008.
  1. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #1 FandLcars, Apr 4, 2008
    Finally have my subframe and engine out to do a major service! I decided to use my 4post lift for a couple reasons. I only have a 2-car garage, and not really enough room to roll the subframe out and keep it anywhere in the garage to work on. I also liked the idea of being able to raise and lower the subframe whenever it would help.
    Advantages of doing it this way: Easier to roll around on a sit-on creeper to disconnect stuff, saves garage space, and I can easily raise and lower the subframe if needed.
    Disadvantages: Less space available for working around the engine, my garage has only an 8 1/2 ft. ceiling, so once the car is up, you can't access stuff from the top (I should have removed the lid), I have to watch my head when working under there. I also think this method took a lot more time to get done, but I'm happy I did it. Not looking forward to getting things hooked back up, when the subframe is reinstalled, though!
    I'm moving pretty slowly, and don't have a real schedule... just taking my time. The removal was some fun, but also a pain sometimes. Now the real fun begins!! Major, plus I'll be evaluating what needs to be done on the transaxle to (hopefully) eliminate future problems! As Larry the Cable Guy says..... Git 'er Done!!
    Rick
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Well, that's a new approach!
    (please be careful of the sub-frame tilting, and cover those cat holes!)
  3. Night life
    Night life F1 Veteran
    7,307
    The city that rhymes with fun in Canada
    Roberto
    Are you saying the car is being held up by those 4 posts close together?
    You are a braver man than I..:eek:
    Hope all goes well :)
  4. Husker
    Husker F1 World Champ
    Dec 31, 2003
    11,792
    western hemisphere
    What happens if the hydraulic juice leaks out of one of those posts?
  5. Oengus
    Oengus F1 World Champ
  6. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,764
    US of A
    Michael
    Ha, those are "pole jacks" and I can assure you that they wont leak any fluids.
  7. copterjon
    copterjon Formula 3
    1,545
    Mesa, Az.
    Way to go Rick! Show 'em how us Az boys do it.
  8. nopassn
    nopassn Formula 3
    Nov 19, 2003
    1,959
    Kansas City
    Roy
    I'm guessing you use the other garage space for your HUGE marbles! Seriously, I wouldn't have the sack to work on my engine like that. Power to you! (and good luck)
  9. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    Excellent job! That's what I call making do with the room you have, you may get an award for smallest area used for a major. Seriously be careful, don't back up into one of those posts. Did you leave it in neutral so you can turn the crank with the tires on the ground?
  10. potxoli
    potxoli Formula 3
    Mar 22, 2007
    1,716
    Washington DC
    Eric B.
    man, don't knock into one of those posts by mistake! Seriously, center of gravity is important... be safe.
  11. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Thanks ND - I do need to cover the cat holes. No worries on tilting.. subframe is solid.. front of it is on heavy wooden blocks which are on the Directlift jack stand crossmember meant for lifting an axle while on the lift. Lots of weight there, so I can't even roll the unit on the tires, due to friction! ;)
  12. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Thanks Roberto... Each of the stands is rated at 2 tons/4000lbs. The car is rock solid up there... I had to get behind the seats to fish the ECU cables through... no problems. First time I did a test, it did rock a bit, so I decided to shim the gaps on the stands, and all is well!! I got these from Greg Smith Eqpt., which is where I also bought the lift. List is $69 each, but they do often also sell them on Ebay cheaper, and since I bought 4, I got them for $44 each (+shipping). Hope all goes well on getting your car inspected!! ;)
  13. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    They're just tall jack stands I purchased from Greg Smith Eqpt. Each is rated at 4000lbs, so that's 16000 lbs for the 4.
  14. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #14 FandLcars, Apr 4, 2008
    LOL - Thanks John! Some may not want to do it, because it did take a lot of time to get set up, and get things completely disconnected while lowering, due to lack of space on top. But I wanted to do it because of my limited space. It will be easier on my next major service in 2009 (ok, maybe I"ll extend it to 2009 1/2) ;)
  15. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    Yes, it's in neutral, but the transaxle is coming off also, so I can check for the possible loose ring nuts, and possibly have it overhauled if necessary. Didn't see any problems when I drained the axle oil, but you never know. Also going to repack the flywheel, and anything else... now's the time! :) Also, thanks for the caution... Car is rock solid on the stands... I didn't start removing the subframe until I was sure it was.
  16. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #16 FandLcars, Apr 4, 2008
    Thanks! I didn't mention, and it may be hard to see in the pics, but there are actually two schedule 80 pipes (1 front stands, 1 back stands) that support the car at the normal outer frame jacking points. I fabbed up some channels that I welded to the ends of the pipes, and welded some bar runners on the bottom of the pipes to keep them in place. The pipes are really strong.. and deflect very little. I used pipe 'cause that's what I had on hand. This was a lot of time to set up, but I'm set now, if I need to do it again :)
  17. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #17 FandLcars, Apr 4, 2008
    Actually, the other side of the garage has my Lamborghini 400GT 2+2 on solid pipe stands, about at the same height, plus Lambo parts underneath! My next project, after this gets done :)
  18. PAP 348
    Dec 10, 2005
    100,228
    Mount Isa, Australia
    Pap
    Nice work Rick. :):)
    Looking forward to more pics. :):)
    Please be very careful when working underneath your car mate. :):)
  19. Night life
    7,307
    Roberto
    Ditto..:)
  20. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    You can say that again.
    Nice job!
  21. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Yup, except that Husker is going to get the bright idea to use the engine sub-frame on wheels to finally make his 348 trailer!
  22. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    LOL!
  23. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I wouldn't put it past him! :)
  24. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #24 FandLcars, Apr 18, 2008
    Hi again Brothers - I posted a separate thread when I checked my transaxle (all looked good!), but plan to just update this thread as needed.
    I rec'd some seals and my flywheel ringnut socket today from Ricambi (thanks Daniel). So I'm ready to start on my throwout bearing rebuild and clutch repack, etc. I do plan to use an impact gun as needed for removal of anything tight, I also decided to make a ring gear "stop" to help with reassembly and torquing (see attached pic).
    I have a dual-disk clutch. Question: Throwout bearing seems OK, but since these may be unobtanium, should I try to regrease the bearing? I'm thinking of using a zerk needle adapter that I purchased long ago. Has a needle for insertion into a sealed bearing, and then a zerk fitting on the other end, for use with a lube gun. Never used one, so any advice or experience with these? If I use it, what grease should I use?
    Also, in view of expense of Kluber grease, I've spent a lot of time searching the Kluber website. Unfortunately, the website is very cumbersome to use, but many greases have spec sheets on the website. Some, however, are not there, and require contacting Kluber for info. I did manage to find several white greases called Noxlub, and one that says it has "Good Damping" properties (spec. sheet attached). They do make a lot of white or whitish greases, and I won't use this unless I'm sure it matches what can be purchased directly. Any comments? Anyone have a can of Kluber that has any Kluber numbers on it that match up with this?
    I'm sure Daniel and others are just passing along the high costs they pay for Kluber grease, but it's tough to swallow that price for just a pint of grease (since that's about all I will use anytime soon).
    Thanks.
  25. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    #25 FandLcars, Apr 24, 2008
    I ended up not having to remove my transaxle, so just need to finish the clutch, flywheel, and halfshafts at the rear of my 348. My clutch ended up being toast, and I got a smokin' quote on a new one (AP dual disk) from FERRPARTS .... (you were right 285 - they seem like good folks! :) I'll post pics when I get the clutch.
    I have the flywheel disassembled and almost cleaned up, and am waiting for the Kluber grease from Daniel at Ricambi. I made punch marks to keep relative positions on exterior covers, but didn't on the spring carrier plates (or whatever they're called) inside. It seemed that they were pretty free to move around, but now I'm wondering if they also were supposed to have a specific position on reassembly. The steel hub has a punch mark on it, but I can't find any other marks on the interior aluminum cases anywhere to match up. Any brothers have experience with position of this interior assembly?
    Also, as you can see in pics, the hub has permanent marker writing inside, and there is also the same writing on the opposite case on the outside. The WSM mentions to position the clutch mark of maximum imbalance (blue color marked on outside) opposite the flywheel "point of maximum imbalance" . Anybody know where this flywheel point is marked? What have others found?
    Thanks for the help.
