348 idle speed | FerrariChat
348 idle speed
Discussion in 'Technical Q&A' started by FrankTavani, Apr 27, 2005.
What is your 348 idle speed (according to your tach)?
  1. <900
  2. 900-1000
  3. 1000-1100
  4. >1100
Multiple votes are allowed.
Results are only viewable after voting.
  1. FrankTavani
    FrankTavani Karting
    Feb 8, 2005
    62
    Philadelphia
    Hi guys. I am going to attempt starting my first poll with a discussion on idle speeds.
    I took my 1994 348 Spider in for service for a number of minor things and ever since I got it back it is running great with the exception of its idle speed. I can't prove it, but it 'sounds' to me like its idling a little faster than it was before. It is currently idling at about 1000-1100 according to the tach. I am wondering if this is normal as the service department has told me it is. Please respond to the poll or just reply to this message with your idle speed.
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    Engine idle speed should be 950 ± 50rpm - also you don't know how accurate your rev counter is.
  3. Ricambi America
    Sponsor Owner
    Frank -
    Mine idles around 950'ish.
    1990 348ts @ 36K miles
  4. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    Sounds normal to me. My 89 348 idles around 900.
    BT
  5. Steve Magnusson
    26,764
    I've noted that in the early US 348 OM (571_89) they give the warm idle speed spec as 950 +/- 100 RPM, but it's not given in later/other 348 OM (and I'd say historically for F, it's been a +/-10% thing in the OMs) -- probably was causing them too much grief with the Owners because of the tach inaccuracy ;)
    My view is the "spec" can be somewhat different depending on the conditions -- there's the range the mechanic should target when using good accurate equipment at time of warm-running adjustment (the tight spec Malcolm posted IMO) and then there's a slightly bigger range that is very acceptable for normal operation (say the +/- 10%) and then there are limits where it get obvious that something needs to be done (like if at 1500 RPM idle). If your tach is accurate, you're bouncing around the upper boundary of "acceptable", but not sure that I'd put immediate retweak as my top priorty if all else is working well -- JMO.
  6. evansp60
    evansp60 Formula Junior
    Nov 2, 2003
    384
    Ottawa, Ont. CANADA
    My '89 idles between 1000-1100. I thought it high but it's consistant.
  7. AR!
    AR! Formula Junior
    Apr 8, 2004
    981
    Berlin, Germany
    My Mondial t engine (same as in early 348s) idles round 1000 rpm.
  8. dasadrew
    dasadrew Formula Junior
    Aug 1, 2004
    683
    Germany
    Drew H.
    Identical experience with my '94 348GTS. Before major about 900 - 950; after major at main dealer 1000 - 1050.
  9. Kevallino
    Kevallino Formula 3
    Feb 10, 2004
    2,257
    Mid-Ohio
    Kevin
    Mine idles higher after the major as well. Hmmm....
    Getting used to it and now just try to keep it between 5,000 - 7,500 rpm as much as possible so as to not notice the difference in idle so much.
    Cheers
    Kevin
  10. FrankTavani
    FrankTavani Karting
    Feb 8, 2005
    62
    Philadelphia
    I've gathered from my two months on this site that F cars don't have accurate tachometers. is this true of all models or only certain ones? do they tend to read low or high? are they consistently inaccurate across the entire powerband or only like from 0-2000 rpms or something? thanks!
  11. Oengus
    Oengus F1 World Champ
    Mine idles at about 950 or so.
