ZE Horror ! French puts a diesel in His Ferrari ! | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by amenasce, Apr 5, 2005.
  1. amenasce
    34,477
    Joe Mansion
  2. Etcetera
    Etcetera Two Time F1 World Champ
    24,042
    C6H14O5
    This was a high performance option from the factory.
    True nuff!
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,186
    E ' ' '/ F
    Snike Fingersmith
    All the style of the 400 series, and all the performance of a John Deere.
    Best of both worlds.....and for only 49,000 USD
  4. Sophia
    Sophia Formula Junior
    Aug 17, 2003
    298
    Dash Point/Federal W
    Peter Barbin
    As soon as Diesel goes F-1, we'll be there too! The technology is getting to the point where bang for the buck of Diesel will definately rival gas motors. By volume, Diesel fuel contains much more "heat" than gasoline...
    I wonder what type of Diesel engine is stuffed in that car? Could you imagine 400+ hp and 500+ ftlbs to go play with...and 25+mpg to boot? I don't think its far off that sports cars will go Diesel.
    Made our first trip to Europe last October, virtually everything was running Rudolf's powerplants...and they were VERY clean and quiet. Standing at a street corner waiting for a light to turn green I expected a haze of black soot and stench...light turns green, wow, all I could smell was cigarette smoke from the nearby cafe's.
  5. amenasce
    34,477
    Joe Mansion
    Bah, i hate diesels and dont want them in my fav cars. Redline at 5000rpm sucks. And they sound weak too..
  6. AJS328
    AJS328 F1 Veteran
    Apr 23, 2003
    7,520
    New Jersey
    Augustine Staino
    On that car it doesn't bother me that much. At least it's a manual. It must be much less expensive to maintain than the original motor.
  7. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,876
    Switzerland
    Simon
    Not true. They are both very similar, but gasoline is actually slightly higher.
    The diesel engine is more efficient because they run higher compression ratios.
    Modern diesels are fantastic, but they are not sportcar engines. The power and torque are great on autobahns and freeways, but go into a slow tight corner and that power is still missing for the first second or two when you exit, until the turbos spin up.
  8. vince308
    vince308 Formula 3
    May 23, 2003
    1,305
    belgium
    vincent
    #8 vince308, Apr 5, 2005
  9. amenasce
    34,477
    Joe Mansion
    Bah , i guess i will be the only one disappointed if Ferrari introduces a F430 Tdi ?
  10. tritone
    tritone F1 Veteran
    7,204
    On the Rock
    James
    Amenasce -
    I'm shocked at how little (relatively) outrage this has sparked on FChat! Look what happens to the thread when some poor fool transplants a 350/350 into a Ferrari!
    I think you should cross-post this to the 'Classic/Vintage' forum, and then we'll see some sparks fly.......
    or not; it is just a (lowly) 400 after all.....
    james
  11. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,876
    Switzerland
    Simon
    A diesel BMW won the Nürburgring 24hours aswell, 2001 I think. But it was a Tortoise and Hare scenario. On long distance races the better gas mileage helps, but you won't be setting any fastest laps.
    I also think for these races the diesel engined cars are classified seperately. At Le Mans they would not be, and so a diesel would struggle to qualify as it must be within a certain percentage of the fastest qualifying car in its group.
  12. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    FYI, it's listed as a 175 CH inline 6 made by VM Motori, an Italian diesel manufacturer, last I knew they were owned by Detroit Diesel which is owned by DaimlerChrysler. So it's got a varied pedigree! 175 CH = 172 HP.
    And Diesel fuel DOES contain more energy than gasoline. From www.exxon.com:
    (Gasoline is about 114,000 BTU/Gal.)
  13. marco246
    marco246 Formula Junior
    Mar 25, 2004
    288
    Hawaii
    Mark
    Probably MORE performance than a John Deere. Mine has only a 4-banger. . . . Would like to see the owner of this car paint it bright green with yellow wheels.
  14. Horsefly
    Horsefly F1 Veteran
    May 14, 2002
    6,929
    That's nothing. About 25 years ago, I saw an Opel GT that had a tractor engine and transmission under the hood. Half the floorboard had been cut out to make room for the monstrosity. The owner loved diesel cars and owned several old diesel Mercedes. The poor Opel had giant tractor levers sticking up between the seats from the transmission. I never saw it run. Wonder if the top speed was above 30MPH.
  15. amenasce
    34,477
    Joe Mansion
    James,
    Finally someone who's with me !
    I was excpecting a riot here..I mean people on another Forum where i found this are more schocked than here and most are teenagers or youngers like me..
    Where is the love ? :)
  16. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    There is a diesel race car series in Europe. A car journalist entered a race in one of the cars but he didn't rate it. The problem was that with so much torque in a light car, it was too easy to break traction coming out of corners, yet didn't have the outright power to reach high top speeds down the straights.
  17. 400iGuy
    400iGuy Formula 3
    Aug 26, 2004
    1,080
    Central Florida
    Al
    Re: tritione's comment about the small block chevy, it also won Nürburgring powering the Chaparral 2D driven by Phil Hill and Jo Bonnier. So with that logic the sb chevy in a Ferrari should be OK too :)
    I could see if you had enough cars to satisfy your need for speed and excitement, having a high tech diesel powered 400 could give you a really nice long haul cruiser. Personally, the point of the 400 is the V-12.
  18. Sophia
    Aug 17, 2003
    298
    Peter Barbin
    Hmmm...Simon, I think a little more research is necessary here:
    Interesting stuff! True, the V-12 is the mystique of the 400 series...and I do hate to see such cars modified like this. But I think with the advances in technology in the last decade, an alternative fuel to Gasoline in sports cars is on the horizon. Ya just gotta capture the sound, provide eye-opening performance...and win some races. The gap is closing! PeterB.
  19. tritone
    tritone F1 Veteran
    7,204
    On the Rock
    James
    Al -
    We're splitting hairs here, but I believe the 2D was propelled by a 472" Reynolds aluminum big block, pretty shocking for the day....another benefit of GM's "backdoor" racing program.
    And I agree with you, the V12 is the 400 series reason (plus the 2 extra seats for guests).
    james
  20. Simon
    Simon Moderator
    Moderator Owner
    Aug 29, 2003
    6,876
    Switzerland
    Simon
    Link doesn't work
    Pump gasoline is about 43.5MJ/kg, diesel is about 42.5MJ/kg.
    The density of diesel is a little higher, so I'll give you that ;)
  21. T0nyGTSt
    T0nyGTSt Karting
    Jul 31, 2004
    196
    Do you have a link to the Chevy 350 powered Ferrari?
    T.
  22. vince308
    vince308 Formula 3
    May 23, 2003
    1,305
    belgium
    vincent
    VOLKSWAGEN (VW) has the PHAETON, that is a V10-5liter TDi with 313HP
    AND IT'S a diesel......ntobad at all.
  23. Z0RR0
    Z0RR0 F1 Rookie
    Apr 11, 2004
    3,470
    Montreal, Canada
    Julien
    WTF?!?!?! It actually is a diesel engine!!! I thought it was just a typo, or some dude who mistakenly filled it with diesel instead of regular gas.
    Andrew, meet the guy, and punch him for me. Straight on the nose. :D. Yeah, I guess I've been playing GTA a bit too much lately :D
    But I just can't believe this crap ... that's worse than a replica ... I'm just speechless.
    And I don't care how many races diesels win, they do not belong on sports cars.
  24. judge4re
    judge4re F1 World Champ
    Apr 26, 2003
    13,477
    Never home
    Dr. Dumb Ass
    What a waste of a 400.
    AND IT WAS A 5 SPEED TOO!!!
    Andrew, call the guy up and tell him to menge le merde for me.
  25. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    Sorry, I wasn't intending to provide a reference link, just citing where it came from. Anyhoo, where I buy fuel at they sell (and price!) by the gallon, not the slug/lbm/kg, so that's what I care about! BTU/$! :)
    And as for the outrage level... I think if it was a 348 there would be more. As for me, I'm a big fan of Diesels and not a big fan of the 400-ish vehicles, so I think this is a nice improvement for a sedan!
