SPEEDOMETER ISSUES | FerrariChat
SPEEDOMETER ISSUES
Discussion in '308/328' started by 89 FERRI, Nov 20, 2010.
  1. 89 FERRI
    89 FERRI Guest
    Jul 31, 2010
    86
    Cold Spring Harbor ,
    Elliot Siegel
    I have a 1989 328 GTS , my speedo only travels between 10 mph and 40 mph !!! It never comes to rest below 10 mph . I have replaced the sending unit and no change !!! I need suggestions . Thanks Elliot
  2. Dino Milano
    Dino Milano Rookie
    Oct 30, 2008
    49
    Italy,Belgium
    Dino M.
    It could be the needle that doesn't hold correctly on the axle!
    Dino
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,703
    South East
    Jimmie
    Have you tried driving faster ?
    Seriously have you noticed if there's a pin in your speedo face which prevents it going under 10 mph ?
  4. 89 FERRI
    89 FERRI Guest
    Jul 31, 2010
    86
    Elliot Siegel
    There is no pin ! When I drive approx 80 mph the speedo creeps up to about 50 mph , if this wasn't a electric sensor I would say it was a old lack of lube in the cable , wishfull thinking , any more ideas ?? Thanks Elliot
  5. mwr4440
    58,047
    Bavaria, The 'Other' Germany
    Mark W.R.
    Elliot,
    First, the pin that prevents needle travel below 10 mph is VERY SMALL AND THIN. I cannot see the pin on my gauges. It is Just too small.
    Second, these gauges are NOT KNOWN for their accuracy. In fact, just the opposite. They are known for how bad they are, but reading 50 for 80 is just too low, agreed.
    If the low reading is not due to the sending unit, have you checked the wire to ensure there is no exposed metal along its length (short to frame or near open)? If that proves OK, then it is likely one of the circuts in the speedo is going bad. Not good.
    Run a few forum searches here. There is a guy or two that fixes speedos but I do not remember his real or F-Chat name. Sorry.
    The other thing you could do is pull it and send it to Palo Alto Speedo in CA. They can likely rebuild it. They rebuilt my 1981 speedo and did a superb job. Be prepared for a little bit of "sticker shock" though.
    Good Luck !!!!
  6. 89 FERRI
    89 FERRI Guest
    Jul 31, 2010
    86
    Elliot Siegel
    Hi Mark , Thankyou for your help , I will keep you posted , I hope I don't have to go the Palo Alto or Hollywood route , Thanks Elliot
  7. BAturb
    BAturb Formula Junior
    Nov 14, 2007
    550
    Australia
    Allan
    the needle in my car, 85 mondial QV was the same, no pin stopping it and it would not go below 10km, at 60 and 80kph it was always 10kph out, I replaced the sensor and still the same, in the end I removed the speedo and then removed the face of the speedo and gently removed the needle and reset it to zero, then I reinstalled the speedo and test drove the car checking the speed using 2 tom tom gps units, I got it to within 1 1/2kph
  8. greyboxer
    Dec 8, 2004
    12,703
    South East
    Jimmie
    Can anyone explain why so many people here spend so much time and/or money trying to get their speedo to read zero ?
    There are dozens and dozens of these threads yet not one that I can recall explains this weird obsession !
  9. Steve Magnusson
    26,931
    #9 Steve Magnusson, Nov 20, 2010
    The mistake that Ferrari made was having a true linear scale on the gauge face. If you look at most modern speedometers, the needle is at 5~10 mph when the car is not moving, but the manufacturers cleverly just put the "0" label there -- and people seem much happier with that ;) Note on this Subaru Speedometer that the needle is not really at "0" (i.e., it has a non-linear scale) even though that position is labeled "0":
