Dino DIY - Exterior Mirror, Tightening a loose swivel | FerrariChat
Discussion in '206/246' started by synchro, Jan 28, 2008.
  1. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #1 synchro, Jan 28, 2008
    Years ago, my exterior mirror was very tight and I couldn't seem to easily swivel it into position as it resisted movement in any direction. I imagined there must be a friction plate inside and figured it was bound up, so I applied a few drops of my favorite lubricant, TriFlow, to the shaft and let it soak until the weekend. That weekend I discovered a disaster when I went to drive it - the darn mirror was so loose and floppy that it wouldn't hold any position when driving above 15 MPH. Well, this escalated things from a mere inconvenience to being nearly dangerous, so I had to fix it.
    Once the mirror was removed from its mounting, I disassembled it and found the rotator ball housed in a friction cup with a pressure plate backing it. I removed the parts and cleaned off the Tri-Flow lubricant with brake cleaner and reinstalled the parts. The final friction of movement is set by the two phillip's head screws on the underside and I tightened them until I had the correct amount of resistance to easily move the mirror.
    First photo is of an original Dino mirror and the Repro, second is the disassembled parts.
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Nice one.
    Tony
