Hard Start when Hot | FerrariChat
Hard Start when Hot
Discussion in '348/355' started by troppoveloce, Aug 7, 2010.
  1. troppoveloce
    troppoveloce Formula Junior
    Jan 25, 2006
    268
    New Hampshire
    Tom
    My 348 protests a bit when I start it hot. It cranks for the first second, then slows to a near stop and turns really slowly. It coughs a bit and then eventually fires and runs perfectly. Is this normal? (The battery is new.)
    Is there a trick to starting it hot? I've considered giving it gas during the start but haven't tried it yet. Any advice?
  2. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    There is a Bosch relay some of the guys have installed that helps (I think PAP 348 has some pics of his install on here) and I had great success with Dave's connector kit. No Doubt details some tests on his 348 Primer (http://www.my348.com/348.html#Starter) to help isolate the cause(s) which can vary - low voltage, fuel pressure regulators or crank sensors getting marginal, flywheel needing the grease repacked, etc.
    My advice would be to do a search, there have been quite a few threads on the subject (example: http://www.ferrarichat.com/forum/showthread.php?p=135922487#post135922487). You need to determine the cause of your hot start problem as it isn't always as simple as a voltage drop issue.
  3. Chupacabra
    Chupacabra F1 Rookie
    3,583
    Behind a drum kit
    Mr. Chupacabra
    May be obvious, but are you turning all accessories (a/c, radio, etc.) off before cranking?
  4. troppoveloce
    Jan 25, 2006
    268
    New Hampshire
    Tom
    Yes, everything is off. Battery voltage is excellent. It behaves like a 60's v8 with it's timing too far advanced. Meaning, it cranks really slow (actually stopping briefly at times) and then "vroom" it springs to life.
  5. PAP 348
    Dec 10, 2005
    100,234
    Mount Isa, Australia
    Pap
    Dont pump the gas pedal, the car is EFI and its a waste of effort. :p:p
    Mmmmmmmmmmm, could be as simple as a voltage drop from the ignition to the starter. :):)
    Can you have someone crank the engine while you check how many volts you have at the starter? :):)
    That will soon tell you whats going on. :):)
    Have you got a multimeter? :):)
    Maybe the timing IS too far advanced? :eek::eek:
    Nah, sounds strange though. Perhaps a starter solenoid is drawing too much current. If you CAN check the voltage at the starter.................................see if you can borrow an amp meter to check how many amps the starter motor is drawing while you crank the engine. :):)
    Could be a faulty starter motor solenoid or starter motor windings. :):)
    Should be an easy fix either way, just need to do some diagnosing mate. :):)
    Cheers mate, here are some pics/thread of my Bosch starter relay install. :):)
    http://www.ferrarichat.com/forum/showpost.php?p=136967618&postcount=12
    http://www.ferrarichat.com/forum/showpost.php?p=136974798&postcount=22
    http://www.ferrarichat.com/forum/showpost.php?p=136989918&postcount=27
  6. troppoveloce
    Jan 25, 2006
    268
    New Hampshire
    Tom
    #6 troppoveloce, Sep 17, 2010
    AMAZING...... I just had the crank sensors replaced (they didn't help) and then had the flywheel repacked (that did it). The starting issue is GONE!!!! Thanks!!!
    Why would repacking the flywheel make any difference at all, it doesn't make sense to me?
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Because the flywheel acts as a harmonic balancer for the crank. So when it is low on grease it doesn't do a good job of balancing things. At the front of the engine there are 2 crank sensors that are sensitive to the gaping between the teeth of the crank pulley and the tip of the crank sensor. If those aren't the proper distance, or the distance is flucuating, it can cause the ecu/s to have a hard time figuring out were in the crank rotation things are so that it knows when to fire the injectors and the spark plugs.
    I could be wrong, but that's my understanding of it, and welcome any correction/education on the matter.
  8. PAP 348
    Dec 10, 2005
    100,234
    Pap
    Good to hear its sorted now mate. :D:D
  9. PaulK
    PaulK F1 Rookie
    4,801
    Michigan
    Paul
    ****ing FChat is awesome.
  10. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    Maybe I'm like a lot of people on here, I follow everyone's problems as if they're my own. I'm glad to hear you got it fixed. I'll keep this one stored in the back of my mind in case it happens to me someday.
    Enjoy the ride, Lou
  11. lightning
    lightning Formula Junior
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    How do you "repack the flywheel" ? Do you have to remove the gearbox or can it be done from under the car?
  12. modena2904
    modena2904 Formula Junior
    Jul 6, 2007
    917
    Ellicott City, MD
    Eric
    This site will tell you everything you need to know:
    http://myferrari.page.tl/Home.htm
    Start with the links for clutch replacement, and follow it through to repacking the flywheel.
    - Eric
  13. troppoveloce
    Jan 25, 2006
    268
    New Hampshire
    Tom
    They just put the car on a lift and pulled the assembly out from underneath. They tell me the tricky part was reassembling the plates and the springs; it's a long slow process. There were some large and some small springs in there that had actually been installed in the wrong spots. As a driver, I could never tell, but he says it was not done right before and now it's correct. FYI, the grease was $175 and labor was $715.
  14. PAP 348
    Dec 10, 2005
    100,234
    Pap
    Cool man. :):)
  15. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I've done this, and as an amateur, I'd say it's a fast, fairly easy process. Sorry, but $700+ labor sounds like highway robbery. Where did you have this done? :eek:
  16. PAP 348
    Dec 10, 2005
    100,234
    Pap
    I was thinking the same thing. $700 is a lot of money. :D:D
    But say its an hour to remove pumpkin, a few hours to pull apart flywheel, clean, inspect and grease then another hour to put it all back together again. A days labour will soon pass and you will get a $700 bill at the end of it. :D:D
  17. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I just would think if it's a production shop that knows the job, $350 labor would sound about right. This was just a flywheel pack, right? Or did I miss something? :)
  18. PAP 348
    Dec 10, 2005
    100,234
    Pap
    Yeah, you're probably right. :D:D
    I assume they have done the job many times before, but I cant confirm that. :D:D
    Maybe they charge $250 and hr labour? :eek::eek:
  19. troppoveloce
    Jan 25, 2006
    268
    New Hampshire
    Tom
    Next time I wont post the price. I'm happy with the job.
  20. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    The important part is that your car is fixed......
  21. PAP 348
    Dec 10, 2005
    100,234
    Pap
    As long as you're happy, thats the main thing. :):)
  22. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I'm also glad you're happy. There have been other threads that discussed high prices for work. I wasn't trying to be critical, but thought a comparison of prices for this job might help other owners. Sorry if it came across as otherwise.
  23. troppoveloce
    Jan 25, 2006
    268
    New Hampshire
    Tom
    Guys, no problem really. I snapped a bit because I saw people zeroing in on the high price instead of the Symptom-and-Solution that I was trying to share. I guess I didn't want to have a debate about how stupid I am for paying too much. ;) That's a tough one to really enjoy (LOL).
    For the record, there was a lot of diagnostic work thrown in there too. It's not as though I delivered the car to him with instructions to put it on the lift and repack the flywheel. He had to get in there and find out why the car had such a problem with hard starts. He test drove it, pulled the computer codes, cleared them, tested them again, checked settings, verified the electrical feeds to the starter, pulled and bench-tested the starter, did a good deal of on-line and/or on-phone research for clues, plus a bunch of other boring stuff I'm sure I never heard about..... So there was quite a lot of non-packing related labor involved, I'm sure of it. This guy has done right by me with all my Audi S-cars, my Lotus Esprit and now the 348. He's not cheap, but he's incredibly meticulous and I like that. Always have ;)
    Sorry I got snippy. :)
  24. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    I didn't think you were snippy, but thought I may have offended you. It's all good :)
    I'm sure a quality independent or dealer would check and repair other things needed along with the flywheel, so it's understandable. :)
