360 LED back up lights | FerrariChat
Discussion in '360/430' started by RayJohns, Sep 5, 2006.
  1. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    On my 360 - as with many - the little round white lens on my reverse lights were cracked. Initially I thought this was due to the previous owner not having a challenge grill. However, after reading some threads on Ferrari chat, I decided it was due to the reverse bulb heating up the lens (I believe I saw a post where this occured on a 550, so that tends to let out the engine heat idea). My friend Tony was the one who pointed out that many cars have this part of the lens cracked and/or bowed out.
    Anyway, if it were in fact from the exhaust heat, it seems that the entire lens would have problems, not just the little inner white reverse light part. After all, in order for heat to affect just that area, it would have to travel past a lot more plastic back there and somehow arrive just in the middle. Doesn't make sense. Also, after putting my hand near the lens while the reverse lights were on, I was surprised to feel quite a bit of heat in a very short amount of time. So my guess is that when the reverse lights are on, that heat slowly cracks the lens over time - even to the point where the lens can bubble out a bit.
    Anyway, to make a long story short, I ordered replacement tail lights (even though my reverse lens weren't that bad off) and installed them today. I also ordered some 1156 replacement LED bulbs. Here is a link to the type I used:
    http://www.luxeonstar.com/item.php?id=1815&link_str=178&partno=TLE12W
    Specifically, I ordered them here (scroll about half way down until you find the 1156 LX3 Luxeon LED bulb). They arrived quickly and look very nice:
    http://www.superbrightleds.com/cgi-bin/store/commerce.cgi?product=CAR
    After installation, I checked the reverse lights - they are very bright. I am going to test them tonight when I take a drive, but it appears they are about as bright as a normal 1156 bulb. The only difference is no heat (and hopefully this means no more cracked lenses); the color is a very cool super bright LED white. It makes the reverse lights look sort of space age :)
    Anyway, I thought I would pass along the modification in case anyone else was in the mood to try it. If the reverse light lenses crack again, then I'll have to start back at square one - but I'm pretty sure the cracking is due to how close the reverse bulb is to the lens, not the lack of a challenge grill and/or addition of a tubi exhaust, etc.
    I'll try to take a couple of photos later tonight and upload them when I have a chance.
    Ray
  2. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    Thanks for sharing this info. I was thinking of doing the same mod. Why did you choose the Luxeon model with only 1 LED instead of other bulbs with multiple LEDs, which were also available on your second link? Which ones are brighter do you know?
  3. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Ray,
    You have way too much time on your hands!
    How did you now come up with LED T/L bulbs?
    Man, you better go back to building models. It's cheaper in the long run!
    What about the multiple LED issues? Any reason for the single element?
    What about for the remaining T/L lenses?
    How did it look in the dark? The T/L lens, that is.
    BTW, that company has festoon bulbs that may provide more light w/in the cabin in the overhead unit! Let's check that out too.
  4. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    according to the website that sells them, they say the Luxeon bulb is hands down the brightest LED bulb on the market. Anyway, I just came back from driving the car and I have to say the LED reverse lights (even with that 3W LED) isn't all that bright. It's enough to see with, but not nearly as bright as the normal bulb. However, I don't do a lot of backing up, so it's not really a problem.
    I'm going to drive out to an area with no street lights so I can see just how much light it casts in the absolute dark. I'll report back once I have a chance to do that. Probably won't be for a while.
    For now, it's okay though. For the amount of night backing up I do, I think it will be okay. And if push comes to shove, I can always tap the brake lights to shine a little more [red] light if needed.
    Ray
  5. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    You might be onto something! :) See the post above.. the LED reverse lights are workable, but not as bright as I would like. Nonetheless, they do look very cool with the ultra white light :) I think for the amount of backing up I do at night, I would rather have lenses that aren't cracked :)
    Ray
  6. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    I was hoping the LED bulbs, especially the multiple LED bulbs, will be brighter. So I'll hold off on this mod until they come up with a LED bulb that's much brighter than filament bulb. Thanks for your feedback.
  7. ferrarilou
    ferrarilou Formula Junior
    Apr 13, 2004
    513
    US
    Lou Menditto
    On mine, I merely converted to a lower wattage bulb. I'm pretty sure I used a 1003 bulb.
    Lou
  8. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    How's the light output?
    Ray
  9. ferrarilou
    Apr 13, 2004
    513
    US
    Lou Menditto
    The bulb is slightly dimmer, but only slightly. Plus, the bulbs are dirt cheap so this experiment was going to cost me less than a coffee at McDonald's :)
    I'm pretty happy with it. I installed them when I put in the new lens units, that was in April of this year.
    Lou
  10. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    #10 RayJohns, Oct 30, 2006
    Here are some pictures I took of the 1156 LX3 Luxeon LED reverse lights. The Luxeon LED bulbs are very bright, but they don't cast as much light as a normal 1156 bulb does. The benefit is no heat whatsoever and also a pretty cool looking blueish tint to the reverse lights.
    It's enough to live with as long as you aren't driving backwards too far in very dim areas. For day to day use, it's plenty fine and you can always tap the brake pedal to throw a bit more light (albeit red light) if really needed. Usually I'm driving forward, so it's not a big deal either way.
    Here are a couple of photos in case anyone wanted to see how it appears.
    Ray
  11. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Ray,
    You had expressed some reservations after doing this with respect to light output.
    So, are you now overall pleased with the results?
    BTW, are you ever going to get license plates on that car?
  12. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    I would like the light output to be greater - there is no doubt about that. But it's okay for the most part. Since I don't use reverse very often at night and/or in very dark areas, it's not really a major concern. There is light output of course, but it doesn't light up everything the way the normal 1156 bulbs do. The main reason I did it was because I didn't want the white part of the tail light lens to crack again.
    All in all I'm happy with it and it's fine, but yeah, if it were 3 times as bright, that would be nicer :)
    Ray
  13. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,737
    Txass
    Bill
    I find it interesting that the back-up lights crack because they are used so seldom and for such a brief time. I believe it may be due to the rapid heating of the plastic lens when it is in a nominal or cool state, as you mentioned Ray. Heating the plastic quickly followed by a subsequent cooling probably causes the cracking. If this is common, I'm surprised Ferrari hasn't addressed this with the appropriate materials in replacement lenses.
  14. Skidkid
    Skidkid F1 Veteran
    9,520
    Campbell, CA
    John Zornes
    Wouldn't it make more sense like this:
    You start the car but haven't turned on the lights yet. It is a cool night so the lenses are cold. You put the car in reverse causing rapid heating. Heating = expansion but the outer lense doesn't expand because it hasn't been heated. The centers crack.
  15. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    the bulb for the reverse light sits very close to the lens. When you get your 360, have someone put it into reverse, then run back and feel the heat coming through the white parts of the lens area - it doesn't take much of that to cause problems is my guess :) The LED's don't give off any heat of course.
    Ray
  16. brokenarrow
    Sep 25, 2006
    3,737
    Txass
    Bill
    Ray,
    When activated, I think they give the car a more modern appearance with the blue-light affect. I would rarely drive the car at night anyway, but am still puzzled why Ferrari hasn't addressed it with better materials or suggested different bulbs. Strange...
  17. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    Ray,
    I see on that site that they have higher output 1156 replacements.
    Why did you not try one of a higher rating? Fit?
  18. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    not sure which bulbs you are referring to Greg. The ones I ordered were supposed to be the brightest of all the LED bulbs they sell. Maybe there is something else... I could try it. Which bulbs specifically are you looking at?
    Ray
  19. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    1156-W24
    1156-W30
    Any viability here?
    Just wondering if you missed these when you found the ones you purchased?
    I like how they look at night on your car and I'd try them if there are higher outputs unless I am not reading the listing correctly.
  20. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    If you read the page, here is what is says about the ones I installed:
    "1156-LX3 Luxeon LED bulb
    Super Bright 3 Watt LED 12VDC replacement bulb
    15mm Single Intensity Bayonet Base
    Super Wide 130 Degree Viewing Angle
    --> Brightest LED Tail Light bulb on the market <--
    BRIGHTER THAN MOST STOCK TAIL LAMP BULBS!
    Select White, Red or Amber LED "
    Generally those cluster of normal LED's are a flop. Even 24 or 30 of them don't put out all that much light. The reason I got the LX3 is because I have a single LED flash light that is super super bright. I figure the LX3 is the same idea. It's darn bright for an LED.
    Ray
  21. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    thanks.. yeah, I like how they look also :)
    Ray
  22. brokenarrow
    Sep 25, 2006
    3,737
    Txass
    Bill
    Ray,
    You're scaring me with that new avatar,..it has that stalker presence to it.
  23. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    TonyC made him wear it!
  24. brokenarrow
    Sep 25, 2006
    3,737
    Txass
    Bill
    Uh,..that may be too much information. Where's the black gag-ball?
    Kidding...
  25. RayJohns
    RayJohns F1 Veteran
    7,925
    West Coast
    Ray
    #25 RayJohns, Nov 1, 2006
    FYI Greg, don't piss off someone that owns a ski mask...
    it was a costume for halloween... I wasn't going to dress up, but at the last minute I changed my mind.. plus I already had the ski mask handy. My job was to provide security for the evening and make sure no body bothered the girls while trick or treating... so I figured it was a good look :)
    A couple of people didn't want to give me candy because I was older than 10, but I made them an offer they couldn't refuse...
    Ray
