360 Spyder,.....This light came on 2 minutes from my house. The car is parked now. Any idea's? Image Unavailable, Please Login
Looks like oil temp. Seems unlikely that it could be that high right away, especially when coolant temp is normal. Check for a sensor/wire problem.
I guess I would see what the gages are saying. Looks like water temp is OK at 210* but the oil pressure is at maybe 30# while the RPM is at 2100. This seems a little low but I am not familiar with the 360's normal running oil pressure. I would think it should be somewhere at 40-50# at 2100 rpm. The oil temp if true is a problem if you consider the oil pressure to low. Let it cool down and do an oil change and a new filter. Cut the old filter up and see if it was blocked. Check the oil temp sending unit and verify if it is good. Make sure there is no blockage of the oil cooler. If Usually if you have a bad gage it won't move but if you have a bad sending unit it will peg the gage. My thoughts.
The car is still in the garage. I have not started it yet. The Rain in the North East has been bad and I've been too busy. Thank you for asking and I hope to get the answer this week.
true, when they do typically read at zero, but others when oil in there, or shorted, will peg the needle .....i don't know about this model in particular, but that'd be the place to start IMO
I had an oil temp gauge that would fluctuate (high, low and in between.) A new thermistor corrected the problem.
I didn't get the car into the shop yet but I checked the oil and it was good. I drove the car (very close to home) for around 10-12 minutes to get the oil temp up. It looked pretty good. Here is the latest picture. I'll still get it checked out but it seems weird that all looks normal. The Check engine light is now on. Do these temps look normal to you? Image Unavailable, Please Login
What is the code in the CEL. Did you put a scanner on to see the code. My bet is the oil temp set the light. Also it still looks like the oil pressure is low I think but can someone let us know what is normal OP at 2100rpm.
