refinish plenum on 308 QV | FerrariChat
Discussion in 'Technical Q&A' started by 308 milano, Sep 21, 2007.
  1. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,326
    Montana
    Kim
    Hello Everyone! I was looking for some advise as I am not the greatest mechanic in the world. I would like to remove and refinish the plenum on my 84 308 gtb qv. and have copied some prior posts on how its done, but I would also like to refinish the throttle assembly,so, is removing the throttle linkage from the housing a good idea given my ability? can I just unbolt these pieces and then reassemble them exactly how they were? or will I end up with things all out of adjustment. Also can anyone tell me the color of red ,or a paint code that I can use to match the factory color of these pieces. Thanks for all your help!
  2. tatcat
    tatcat F1 World Champ Owner Silver Subscribed
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    mask it off an paint in place. taking it apart just for paint is asking for trouble. like little washers hiding under there just waiting to drop down inside the manifold. if you did a search then you read about the problems you could run into. "if it ain't broke don't fix it". i did mine in place and it looks fine. i think i posted a pic in a former thread on the subject.
  3. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    I saw on prior posts that its a good idea to loosen the nuts on the plenum, then slip a piece of paper between the plenun and the ports as to avoid anything falling down the intake before removing the plenum. I also wanted to replace the cooling hoses while it was off.
  4. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I recently cleaned-up the plenum and throttle body on my 328. Not the same color scheme as the 308 but.... I took off all the throttle linkage but I did not remove the throttle plate and shaft. If you carefully document everything before starting you should be able to put it back together without anything being out of adjustment.
    If you're not fully confident about the job I would try doing it with the parts in place first and see how you like the results. Or just remove the throttle body. Murphy's law and all that.....
  5. miketuason
    miketuason F1 World Champ Owner Silver Subscribed
    Feb 24, 2006
    15,806
    Cerritos, CA.
    Is the plenum for the 308 QV powder coated?
    and if it's not, is it a good Idea to powder coat it?
  6. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I don't know if the 308 or 328 is powder coated. I think the red portion on the 328 is powder coating.
    The silver portion on my plenum was painted kind of a silver/gray from the factory. I removed the paint with abrasive blasting and then sprayed-on, clear, high-temp. paint. Same with the trottle body.
  7. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Goodmorning Guys! I thought it was powder coated red but given how its lifting in some places and chipped I think its just paint, add to that the previous owners attempt touch it up with paint and a small brush my plenum looks like hell! At first I was just going to remove the piece,strip it ,and have it powder coated, but now Im not so sure that its such a good idea because powder coating might mess with the travel or the way the throttle linkage sets on the assembly
  8. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    eulk 328, Your engine bay looks great!!! How do you guys get the engine that clean? Im afraid if I spray degreaser on mine then hit it with a pressure washer it may never start again ha! ha! Actually, in the year I have owned the car I have never used any type of pressure washer, just a bucket of warm water and a sponge and dried it with a towel. am I being a little to paranoid about hurting something? Can I pretend that its my suburban and just "go for it" keeping in mind not to directly spray electronics? I know these questions sound dumb, but I hate learning lessons the hard way! In Montana its not like I can just transport the car downtown to the Ferrari Mechanic and say "this is what I did" I have to trailer the car to Seattle or Salt Lake City.
  9. Eric308gtsiqv
    Eric308gtsiqv Formula 3
    Nov 26, 2001
    1,956
    Orange Park, Florida
    Eric Eiland
    Here are some past threads on the subject (some are from the "archives", so there may not be any pics):
    http://www.ferrarichat.com/forum/showthread.php?t=16536&highlight=308+plenum
    http://www.ferrarichat.com/discus/messages/256120/4741.html
    http://www.ferrarichat.com/discus/messages/256120/8709.html?1018146687
    http://www.ferrarichat.com/forum/showthread.php?t=26660&highlight=308+plenum
    Removal of the throttle assembly is fairly easy and straightforward from my recollection. Be very careful when removing / lifting the plenum from the intakes as there are spacers there which the bolts go through between the plenum and intake, and they can very easily fall into the intake if not careful.
    Regular paint stripper works well for stripping the old paint off the plenum. Use a wire brush and rag to get into the crevices.
  10. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Man that is a nice bay! How did you get the aluminum looking so clean?!
  11. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Well, it is easy to have it so clean. I took a lot of parts off and cleaned them :) The engine has not been run since. Once I drive it again it may not look so pretty in a couple of months.
    I spray my engine with a garden hose after using degreaser. You just have to be a little bit careful and have a can of WD-40. Spray things down with the WD-40 when you are done, especially the coils, plug wires and distributors. Then start the car and go for a drive to dry off any remaining water. You should be okay. A pressure washer may be a bit powerful to use in this engine bay.
    If you get any water into an electrical connector by mistake just take it apart and spray WD-40 into both connectors.
    Joe, I removed the valve covers, intake manifolds, plenum and throttle body and then abrasive blasted them. Then I sprayed them with high-temp clear paint.
  12. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Hey Guys! Got the throttle assembly and the plenum off the car last night, probably should wait two weeks to reassemble in order to allow enough time for the skin to return on the back of my right hand!! Man, having one of those spacers fall down the port would not be good!! but the paper trick between the plenum and the port worked great. Anyone have any tricks to keeping the rubber gaskets and spacers in place during assembly? Is it better to stick them down on the ports with just a bit of gasket seal or to the plenum? Also, is there any tricks to changing the 40mm cooling hose under the plenum so I dont completely flood the top of the engine with coolant? or do you just grit your teeth, put a pan on your garage floor and go for it, working as fast as you can? Last, there is a small cooling hose that runs from the water jacket under the plenum to the expansion tank that I also would like to change but it feels like its made out of a cross between rubber and plastic held in place with hose clamps at both ends. Is this some sort of ultra high temp hose, or can I just replace it with the proper size of regular cooling hose from the napa parts store? Thanks For All The Help!
  13. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    There are pins on the bottom of my intake manifold that kept the rubber gaskets on the plenum. Then I used some vaseline to keep the metal spacers on the studs.
    Open your radiator drain plug or loosen one of the lower coolant hoses to drop the level of your coolant throughout the system. Then you should not have much spill onto the block. Why not just change all the coolant unless it has been done recently?
    The little hose is hard from old age and heat. Mine was normal rubber. I replaced it with a silicone hose. It sounds like maybe you should consider changing all your coolant hoses instead of one by one or when one springs a leak. How are your fuel hoses? They may need it too. There are a lot of hoses on these cars and all kinds of different sizes! A real pain to change some of them but once you do it you should be good for 10 years and you'll have the peace of mind that comes with knowing none of them are going to burst.
  14. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Erich, Thanks for all your help! I had a compression and leak down test performed before I bought the car and they came back okay the leak down test would tell me all those plastic fuel lines were okay wouldnt it? All the fluids were changed the week before I purchased the car last Oct. by the previous owner (I have the reciept showing this was done) I was planing to change all the cooling and emission hoses and have already purchased quite a few of them. I guess I just wanted to start at the plenum and work outward as its been wearing on me for quite some time, I guess Ive been a little afraid of unbolting parts off of a Ferrari Engine given my limited engine experience. So if I drain about a half gallon of coolant from the petcock on the radiator, how do I refill it and get the air out of the system? I cant refill it through the expansion tank can I? Do I fill it through the radiator, start the car and burp it through the expansion tank? Thanks! Kim
  15. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Erich, Sorry for the stupid questions, I just went out to the garage to drain some of the coolant and discovered the radiator does not have a filler cap,and probably no pet cock, if it does it its not very user friendly ha ha! Sorry for wasting your time.I have come to a few conclusions however, #1 that every Ferrari mechanic is in some sort of support group for substance abuse or torrent syndrome, and #2 Italians have the smallest hands on the planet!
  16. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    No problem Kim.
    The compression and leak down test have nothing to do with the fuel lines/fuel system. If you have fuel injection I would not worry about any of the plastic lines that feed the injectors but all the other rubber fuel lines I would change.
    If you will be changing all the coolant hoses then you will pretty much lose all your coolant so you will be doing a coolant change anyway. Not a bad thing. I change coolant every two years and brake fluid every year.
    The expansion tank is where you re-fill the system on any car with an expansion tank. Make sure your heater controls (probably levers on your car) are set to max. heat. Not the heater fan but the controls that allow maximum hot water to flow in the little radiator in the cockpit. This helps avoid air pockets in the little radiator and hoses feeding it. There should be a bleed screw somewhere on the top of your radiator. Open this with the engine running and close it when only water (no more air) comes out. You may have to do this a few times. The 328 has a bleed screw on the thermostat housing also. Maybe not on the 308. I would drive around the block a number of times with the expansion tank cap off until you reach full temp. (fans come on). Drive easily and you will not overheat or spill coolant out of the tank. Add more coolant as you go along to keep it at the correct level. Eventually you should get all the air out. Mid-engined cars take a little more time and effort in this respect.
    What can I say about taking things off/apart? It's the only way to get experience. Document.. take notes, make drawings and take photos. If you don't drive your car in winter then this is a perfect winter project. Go slowly, take your time. Never forget.... the more things you take off the more things you will find wrong or the more things you will want to change "while you're at it." My cambelts and bearings change turned into a huge project for me. One year later and I'm close to being finished! Granted, I didn't do much work in the winter. In retrospect that is exactly when I should have done more work. Now with the beautiful Autumn weather I'm laying on the floor in my garage instead of driving :-(
  17. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    What kind of paint did you use? I am wondering if we can get it here. I've never seen high-temp clear.
  18. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    The spray paint is called Dupli-Color Tuning Supertherm "clear 500 degrees C heat-resistant" made by Motip Dupli GmbH
    On the can it says it's a special silicone-based heat resistant paint. After spraying you're supposed to expose the part to 160 degree centigrade heat to harden the paint.
    I would doubt if they have it in the U.S but I would think there must be some equivalent.
  19. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    We have Dupli-color here, but I've never heard of that product. I'll head to the hardware store and see if they can order it. Thanks for the help!
  20. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    If they don't stock it maybe they can special order it for you. I think I paid about 10 Euro (around $13.00) for a medium size can (400ml). I can't comment on its performance because I haven't run my engine yet but generally speaking Germans make pretty good paints, chemicals, greases etc.
    Good luck
  21. 308 milano
    Jan 15, 2007
    5,326
    Montana
    Kim
    Erich, Just wanted to say "thanks Again" for all your good advice and help! As soon as I get all the cooling and emission hoses changed and the plenum reassembled Ill take your advice and change the fuel lines. I thought that a leak down test was to check to see if any of the fuel lines were loosing pressure and when they told me everything was okay I just assumed the whole fuel system was okay. I sure hope I dont learn any hard lessons on the way to understanding how ferrari works! Thanks Again!
  22. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    You're welcome Kim. I think I misunderstood you initially. I thought you were referring to a leakdown test where they check how well the valves and piston rings are sealing. It seems the check they did was to see how long the fuel accumulator on your car will hold fuel pressure after you turn the engine off. It should hold pressure for a certain amount of time. Otherwise you can have problems re-starting the engine if it's hot. In any event, this test will certainly NOT tell you if all your fuel hoses are okay.
    See if you can get a parts manual for your car. Either on paper or CD (ebay?). It helps a lot when trying to figure things out.
    Erich
