355 spider hood fluid top up .... how ?? | FerrariChat
Discussion in 'Technical Q&A' started by spiderscott, Jul 28, 2005.
  1. spiderscott
    spiderscott Formula 3
    1,661
    Ratarossa HQ UK
    Ratarossa
    Hi all
    My hood on the 355 is currently stuck halfway up, ive taken a look at my fluid and it is below minimum so I need to top it up...... not easy !!
    Can anyone tell me how to do this ??
    I have the ferrari fluid, and have taken the screw out the side of the power mech but cannot get any fluid to actually go into the unit, it just spurts back out .... am I missing something ?? Is there some special tool i need to get this fluid in ?
    Cheers
    Scott
  2. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    #2 Ferrari_tech, Jul 28, 2005
    To top up the oil level, tilt both seats forward and remove the protection cover that sits in the centre of the rear bulkhead. This will reveal the hydraulic assembley, remove item "B" by removing the two allen bolts, this will reveal a 13mm spanner size bolt, remove the bolt and using a syringe top up to the correct level.
  3. spiderscott
    1,661
    Ratarossa HQ UK
    Ratarossa
    Hi Malcolm
    That explains it, I was trying to put the fluid in (1) .....Dohhhhhhhhh.
    Thanks very much for your kind help
    Scott
  4. Sfumato
    Sfumato F1 World Champ
    Nov 1, 2003
    10,194
    Llanfairpwllgwyngyll, Anglesey, Wales
    Angus Podgorney
    Now you know why they charge 140/hr?? Techs only see small fraction of that though.
    Check your headlight fluid too... ;)
  5. f365gtc4
    f365gtc4 Rookie
    Sep 30, 2005
    1
    Jacksonville Florida
    New member, the info is greatly appreciated as closest dealer is 2.5 hours away and not the most straight forward.
  6. delaney
    delaney Formula Junior
    Nov 8, 2003
    717
    Montgomery TX
    PETER DELANEY
    There's a special fluid to do the top up .... marketed by Mercedes .... called Hydraulic ZH-M. Normal hydraulic fluid can screw up the seals I'm told. True/false ..don't know but probably not worth taking the chance.
    Regards,
    Pete
