348 ts gas pedal cabble ??????? | FerrariChat
Discussion in 'Technical Q&A' started by Dcup, Jan 8, 2005.
  1. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    alrighty then............... just came from the garage, went to start up my car [348] dont know if gas pedal cable broke or came loose ? there s no tention on the pedal does not work the accelerator, thoughts >>>>>>>>>>>
  2. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    come on guys, some feed back.........
  3. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Easy there Johny boy help will come around. Look at the back of the plenum on your engine. The cable gets attached to the back of the connection shaft for the throttle body control arms. Theres is a groove that the cable can slip out of. If it has come out just slip it back in. You will see it just above the oil filter. You can open the throttle with one hand while you put the cable back in with the other. Then make sure that the adjustment screw is tighted enough to hold it in place. Don't over tighten it, just make sure there isn't very much play. The other thing you can do is look on the back of the accelerator to see if maybe it came loose there.
  4. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #4 Miltonian, Jan 8, 2005
    Throttle cable on the engine end looks like this. Cable must go through the slot on piece #17. Right above the oil filter.
    The front end of the cable is attached to the pedal linkage under the center dash. Real easy to get to it. It's possible that it has come detached, or it's possible that the cable snapped inside the bowden tube.
    Cables can be built from scratch or purchased from Ferrari. I believe I have also seen the 348 throttle cable for sale via Italian Car Parts.
    Edit: Confirmed, 348 accel cable lists for $120 on ICP site. If it's snapped, you could always pull it out and make a little sleeve to solder it back together as a temporary fix.
  5. FNU_LNU
    FNU_LNU Karting
    May 22, 2004
    196
    New England
    AM
    When I was working on my pedals my cable came off where is it 17 on the diagram. Hooked her back up no probs.
  6. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    ok guys, if it came loose from the pedal how do you access the cable from that point. my guess is the cable connects to the bottom of the pedal ?
  7. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    #7 Miltonian, Jan 8, 2005
    To access the pedal end of the cable:
    1) Remove the two phillips screws on the shift lever gate.
    2) Pull the black panel around the shifter slightly back.
    3) Wiggle out the console panel that holds the heater controls and oil temp/fuel gauges. Careful, don't manhandle anything, they come right out.
    4) Look down under the center dash, just to the right of your gas pedal. The linkage attaches to the pedal, the cable attaches to the linkage. You can see the cable until it goes into the bowden tube.
    It looks like this (real easy, took me less than 2 minutes).
  8. Dcup
    Dcup F1 Veteran
    Jan 3, 2005
    8,645
    Between 2 Implants
    Claude Balls
    YOU GUYS ARE THE BEST !!!!!!!!!!!!!!!!!!!!!!!!!!
    CABLE CAME LOOSE FROM THE ENGINE END, RE ATTACHED AND RAN GREAT !!
    AS FAR AS MY ECU'S I SWITCHED THEM AROUND, TOOK HER OUT FOR A SPIN, RAN HER AT 110 MPH AND NO LIGHTS CAME ON SO I LL JUST WAIT TO SEE WHAT HAPPENS LATER. ANY WAY THANKS SOOOOOOOO MUCH AND AGAIN, YOU GUYS ARE FABULOSO !!!!!!!!!!!!!!!!!!!!!!!!
    JOHN.
  9. ernie
    Nov 19, 2001
    22,614
    The Brickyard
    The Bad Guy
    Glad to hear you got it figured out.
