400 hub conversion | FerrariChat
400 hub conversion
Discussion in '365 GT4 2+2/400/412' started by 3wings, Apr 30, 2010.
  1. 3wings
    3wings Karting
    Apr 7, 2008
    139
    South Africa
    #1 3wings, Apr 30, 2010
    Okay, I never said I was perfect and down here in South Africa you sometimes just have to make compromises. So I finally gave up on the 415 rims and 'old' TRX technology and designed a little gizmo to convert the 5x108 PCD to a more 'user-friendly' 5x120.
    The spacer width, which in this case is 38.85mm, works for a 15" rim, it would be slightly more for a 16, but I've gone for a 225x65x15 tyre which is within 1.25% of the original rolling radius and I can live with that.
    Herecy of course for the concourse junkies out there, but extremely practical for daily use and I can always remove the spacers and replace the TRX's when authenticity requires.
    I paid about $480 for the CNC machining and milling work which worked out a whole lot cheaper than importing 328 replicas from the UK.
    Now that they know how to do the job, the engineering shop would be happy to produce more if required. Air freight to the US from SA is remarkably cheap in these economically stressed times.
    Let me know if we can offer any help.
    best for now.,
  2. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    736
    Lake Stevens Washington
    Howard Musolf
    I'm up for a set. I'm at the point of making a wheel decision. Can you quote a price including air freight to Seattle Washington USA?
    Regards,
    Howard Musolf
    1982 400i Cabriolet
    Maserati Spider
    2 many brass era cars.
  3. 3wings
    3wings Karting
    Apr 7, 2008
    139
    South Africa
    Howard.
    You need to confirm that you have original and unmodified 400 brake discs and calipers all round and that your wheel bolts are Ferrari standard 14.15mm metric fine.
    If you decide, as I have done, to go for a 5x120 PCD then you have an enormous variety of after-market, as well as OEM BMW rims/mags to choose from.
    The critical factor is the offset, you can read more about this on the following link:http://www.carbibles.com/tyre_bible_pg4.html.
    Once you know this measurement then I will be able to quote you more accurately because this will determine not only the finished thickness, but the raw size of the block from which the spacer is machined.
    Don't let all this technical stuff frighten you however, the material cost will not be too different from mine and the labour will be the same.
    Once you've decided on a rim, be it 15, 16, 17 inch or more and have chosen a make and design, just let me know. Chances are that we can either take an accurate measurement of that model here in SA or find the critical dimensions on the web.
    I'm amazed by the relative affordability of quality tyres in the US from places like tire-rack or discounttiresonline compared with prices here in SA. We have nothing here of any merit under US$200/tyre. You guys don't realise just how lucky you are...
  4. ArtS
    ArtS F1 World Champ
    Nov 11, 2003
    13,253
    Central NJ
    Someone needs to photoshop some 22" bling wheels onto a 400... :D
    Regards,
    Art S.
  5. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,072
    E ' ' '/ F
    Ayagoa Kabooma
    Are these compatible with 308/concave 328 hubs? I think there might be some market there if they worked.
  6. 3wings
    3wings Karting
    Apr 7, 2008
    139
    South Africa
    I know that some of the 16" 308qv and the 328 rims currently available in the UK have the same PCD as the 400, namely 5x108, and they are virtually identical in looks.
    Alex Aleventhal, who has discussed this on another thread, had spacers made up to compensate for the difference in offset. He recently sold them on eBay.
    What I've done is to borrow his idea (thanks Alex) and create an adaptor-spacer that serves both purposes.
    The big plus is that it opens up the possibility of replacing the expensive and out-dated 415 TRX's, with 15, 16 or 17" rims and all the latest technology tyres that are currently on the market. With top name brands, suitable for high speed, all season driving at around $120 -$150 a pop, that can't be too much of a bad thing, especially given the advances in tyre safety, durability, run-flats etc, etc.
    There might be those who choose bling mags, its a personal thing, I'm not one of them and have opted for subtle period rims that blend well with the car's classic lines.
    The point is that these adaptors offer choice and enhanced safety with the added bonus that the 415's can be stored in the garage until needed for those all-important concourse days.
  7. tazandjan
    39,151
    Late model Ferrari wheels are 5x108 mm and 5x114 mm. I have not gone back as far as the 400 and 308/328 in my list. If somebody passes me good information, I will add the 400 to the list.
    Taz
    Terry Phillips
    Ferrari OEM Wheel Sizes
    5 X 114 mm Bolt Pattern
    612
    Five Spoke F 18”, R 19”, 5 X 114 mm
    Front 8J X 18 ET 43.5 mm , R 10J X 19 ET 51.1 mm
    Five Spoke Modulars 19”, 5 X 114 mm
    Front 8J X 19 ET 43.5 mm, Rear 10J X 19 ET 51.1 mm
    Challenge Monolithic 20”, 5 X 114 mm
    Front 8J X 20 ET 43.5 mm, Rear 10J X 20 ET 51.1 mm
    599/HGTE
    Five Spoke F 19”, R 20”, 5 X 114 mm
    Front 8J X 19 ET 43.5 mm, Rear 11J X 20 ET 63.8 mm
    Front 8J X 20 ET 43.5 mm, Rear 11J X 20 ET 63.8 mm
    HGTE Five Spoke 20”, 5 X 114 mm
    Front 8.5J X 20 ET 40 mm, Rear 11J X 20 ET 63.8 mm
    California
    Pentagram Forged 19”, 5 X 114 mm
    Front 8J X 19 ET 44 mm, Rear 10J X 19 ET 52.5 mm
    V Spoke Forged 20”, 5 X 114 mm
    Front 8J X 20 ET 44 mm, Rear 10J X 20 ET 52.5 mm
    458
    Front 8.5J X 20 ET 46.5mm, Rear 10.5J X 20 ET 58.5 mm
    5 X 108 mm Bolt Pattern
    348
    Five Spoke 17” Early, 5 X 108 mm
    Front 7.5J X 17 ET 49 mm, Rear 9J X 17 ET 68 mm
    Five Spoke 17” Late, 5 X 108 mm
    Front 7.5J X 17 ET 49 mm, Rear 9J X 17 ET 43.05 mm
    355
    Five Spoke 18”, 5 X 108 mm
    Front 7.5J X 18 ET 32 mm, Rear 10J X 18 ET 77.9 mm
    456 GT/456M
    Five Spoke 17”, 5 X 108 mm
    Front 8.5J X 17 ET 50 mm, Rear 10J X 17 ET 24.6mm
    360
    Five Spoke and Modular 18”, 5 X 108 mm
    Front 7.5J X 18 ET 31.5 mm, Rear 10J X 18 ET 39 mm
    360 Challenge Stradale
    Challenge Monolithic 19”, 5 X 108 mm
    Front 7.5J X 19 ET 31.5 mm, Rear 10J X 19 ET 39 mm
    550/575M/575 Superamerica
    550/575M Five Spoke/Modular 18”, 5 X 108 mm
    Front 8.5J X 18 ET 43.65 mm, Rear 10.5J X 18 ET 32 mm
    575M/575 Superamerica Five Spoke Modular 19”, 5 X 108 mm
    Front 8.5J X 19 ET 43.65 mm, Rear 10.5J X 19 ET 32 mm
    f430
    Five (Ten) Spoke and Challenge Monolithic 19”, 5 X 108 mm
    Scuderia/16M
    10 Spoke, Five Spoke 19”, 5 X 108 mm
    Front 8J X 19 ET 31.5 mm, Rear 10J X 19 ET 39 mm
  8. 3wings
    3wings Karting
    Apr 7, 2008
    139
    South Africa
    Hi Terry.
    That's a very interesting list. The one thing that stands out to me is the positive offset (inset) or ET on all those wheels, almost a staggering 88mm on the 355 !!!
    What an amazing advance in wheel design technology that can pull the wheel so tight into the car by putting the rim mounting plate 88mm roadside of centre !
    By way of comparison, the 400i has a negative offset (outset) of 2mm.
    Don't ask me why they didn't make it dead centre (neutral) but I guess nothing that Ferrari did was ever that simple !
  9. tazandjan
    39,151
    Mike- Sounds like the 400i would be:
    Five Spoke 415 mm, 5 X 108 mm
    180TR X 415 mm, ET -2 mm
    That look correct to everybody?
    Taz
    Terry Phillips
