355 - 02 extenders (straight type) | FerrariChat
355 02 extenders (straight type)
Discussion in '348/355' started by rizzo308, May 31, 2021.
  1. rizzo308
    rizzo308 F1 Rookie Silver Subscribed
    Sep 12, 2004
    2,780
    Perth, Australia
    riggio
    Hey guys,
    After fitting hi flow cats to my friends car we have the CEL. Looking to purchase a set extenders. I see the 90% type online, is there a straight type available. TIA
  2. Qavion
    Qavion F1 World Champ Silver Subscribed
    Feb 20, 2015
    14,268
    Ian Riddell
    Is there a reason why you want the straight type? Sometimes the straight ones have clearance issues. The sensor wiring rubs against the car frame.
  3. drbob101
    drbob101 F1 Rookie Owner Silver Subscribed
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
  4. rizzo308
    Sep 12, 2004
    2,780
    Perth, Australia
    riggio
    The dealer tech requested straight type. Thanks guys. Ordered and shipped.
  5. emac
    emac Formula Junior Silver Subscribed
    Sep 14, 2014
    851
    upstate SC
    ernest
    The big Daddy ones Bob linked to worked great for me.
  6. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    964
    I have OEM headers, Fabspeed bypass pipes, and Nouvalari Sport muffler.
    Big Daddies straight extensions did not work for me. Then, I ordered the 90' extenders. and they did not work. Next, I stacked them, and that did not work. Finally, I stuffed the angled units with stainless steel wool: that worked for about 100 miles, and then CEL came back. I have only heard of a few success stories, and most report that the CEL will (eventually) come back.
    Has anyone tried these:
    https://www.magnumtuning.com/en/detail/ez-cel-fix-oxygen-sensor-simulator/ferrari/355
    It "seems" like they would actually solve the problem.......for good......
  7. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    So let me get this straight, you remove the ability of the engine management system to perform its job based on sending "simulated" feedback data which has nothing to do with the actual real live engine performance? All in pursuit of keeping the CEL away? I don't have a better answer, but I dunno seems not the greatest approach. Perhaps a tune that works like an ideal mapping would be better? Regardless, I've come to peace with just having cats on the car.
    Qavion likes this.
  8. Carmellini
    Jul 16, 2019
    964
    With CAT delete, there is no valuable information sent from the downstream O2 sensors to engine management, so it is irrelevant and inconsequential. I have removed my CEL, but regularly do a check with OBD scanner. If I knew I could add a simulator that would keep the CEL off, I would spring for it.
  9. Qavion
    Feb 20, 2015
    14,268
    Ian Riddell
