03 575m code | FerrariChat
03 575m code
Discussion in 'Technical Q&A' started by dinos575m, Jun 13, 2021.
  1. dinos575m
    dinos575m Rookie
    Oct 28, 2019
    49
    Dean Pellegrino
    03 575m little problem with a 1602 code. anyone else have this issue??
    Any direction would help .
    Much thanks
    Dino
  2. tazandjan
    39,170
    Battery low on charge so either she needs charging or, most likely, needs replacing.
    The direct supply from the battery has reached the minimum value for the ECU operation.
  3. dinos575m
    dinos575m Rookie
    Oct 28, 2019
    49
    Dean Pellegrino
    Thanks for the response. battery at 12.99 volts and charging at 14.2 volts
    always on a trickle charger.
    Dino
  4. Qavion
    Qavion F1 World Champ
    14,290
    Ian Riddell
    Is only one ECU showing the fault?
    Have you tried clearing it to see if comes back?
    Do you have a (cigar lighter) plug in voltmeter to monitor the voltages when driving? (less than $10 on e-Bay)
