Hi, Both seats on my scag won't slide forward for the rear passenger to get in and out. Would appreciate any ideas. Thanks, Alex
Blown fuse for the seats? Dig out your user manual and check the fuse box in the boot. Does the electric adjustment work? If not check fuses F30 and F56. Both are 30A fuses.
Disconnect your battery and then reconnect (per manual). See if they work after you do that. Sometimes that will cure the issue. If not, there could be a loose or bad connection to the seat back lever.
