05 F430 Needs Water pump and control arm... does it though? | FerrariChat
Discussion in '360/430' started by searayray, Feb 3, 2011.
  1. searayray
    searayray Rookie
    Jan 19, 2011
    10
    Hey guys. I just had an F430 PPI'd. Ferrari came back with a really healthy list of things that it needs. Mostly fluids and items that are usually handled during maintenance. The car is solid with a brand new clutch and no engine or trans issues. Open campaigns handled, etc. There are some major things that I'm concerned about.
    The seller disagrees with Ferrari and having dealt with high end dealerships before (Porsche) I am familiar with quoting to replace EVERYTHING instead of replacing what's necessary. At the end of the day...the cost to handle the things is about 15 large.
    The seller has offered to handle some things...and disagrees that it needs everything listed. Let me know what you think about these prices. Are they reasonable. I accept that I may have to get this things done...but I'll likely get a second opinion.
    Replace water pump and misc gasket - 10hrs labor - $4231 parts, $1050 labor. Their exact language is 'starting to leak.' Dealer's mechanic pulled panels and disagrees with this diagnostic. Is this price reasonable. Is this something that I could keep my eye on and replace down the road if needed...or just get it done?
    Power steering pump - 3.6 hrs, $711 parts, $378 labor. Their language - 'power steering pump is wet.'
    Lower control arm and busings - 7hrs labor, $6127 parts, $735 labor. This all started with them noticing that 'front lower ball joint dust boots are torn', the alignment off center, and 'front suspension is creaky at times.' I'd like to get a second opinion on this too.
    Oil dipstick gasket (leaking) - $227 parts, $21 labor. Can I handle this as a DIY?
    Here's other details about the car that I've ruled out as not totally necessary. Let me know if I am way off base:
    pollen filter (DIY)
    Front pads @ 20%. Will the car warn me. Should I get these done now? How much longer on these pads with soft driving?
    TPMS will not calibrate. I was thinking of getting the sensors replaced when we do the brakes.
    I love this forum and I want to make sure that my first Fcar comes to me as clean as possible. Let me know your thoughts, guys.
  2. Rifledriver
    37,089
    I am not going to bother to look up all the prices but it looks as though the car was inspected by a mechanic who lives by the old saying "When I see moisture I see money".
    There is a big difference between a leak and damp. And he wants to replace a control arm because a boot is torn and will cause it to wear faster? Why not just wait until it IS worn out THEN replace it. By the way, the boots are replaceable seperately for a tiny fraction of the cost and 6 grand in parts will replace a whole set of arms.
    Bottom line is you went into a shop with very aggressive selling. You might need some of it but they are looking for a home run here.
    Find someone a little less prostitute like who will look out for their interests AND yours in the hopes of having a long term customer rather than one who "Charges like we'll never see him again".
  3. blackbolt22
    blackbolt22 F1 Veteran
    5,808
    Boca Raton, FL
    Mr. Anderson
    I wish more people in all areas of business thought the way you do Brian.
    So many places try to stick it you as hard as possible on every little thing.
  4. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    Pay for another PPI.
    If the car has CCB, replace those pads immediately. If not, replace them anyway. Pads for the non-CCB F430 are cheap.
    TPMS sensors are cheap.
    I can't see $15k on labor and parts, what a rip-off.
    Power steering pump testing is quite easy, if it's wet doesn't mean new pump.
    Most Ferraris on the road have a wacky alignment, the owners just don't know. I put my cars on the alignment rack when I buy them, and no car has been within acceptable specs. Alignment for the F430 is quite easy, I do it all the time.
    Good luck with your search.
  5. searayray
    searayray Rookie
    Jan 19, 2011
    10
    This shop is a Ferrari dealership. I think we all agree that 15k is a bit much. My main concerns are the water pump, power steering and front end stuff. Anyone have decent prices for those repairs. I may just ask the dealer to discount the car based on the repairs that he won't handle.
    I'm not being cheap but I'm wondering what potential disasters could happen by not doing the two pumps and front end repairs right away. If I keep my eyes on the fluids I should be good...right?
  6. kaamacat
    kaamacat Formula 3
    Jun 13, 2004
    1,623
    Cumming GA
    BobR
    How many miles are on this car if I might ask?
  7. Piper
    Piper Two Time F1 World Champ
    Jun 6, 2010
    25,415
    Northern Virginia
    Bob
    OMG !!! $5000 to replace a water pump. That's amazing.
  8. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    I'd recommend you try get 5k off the seller, go to a decent but respected independent, have him replace the torn boot on the front, get it aligned, replace the pads and go drive. The rest doesn't sound like it needs doing at all and if/when it does I suspect you'll have change out of 5k when it does.
    Leaky oil dipstick gasket? $227 parts + labour? I suspect we're talking about a rubber ring within the screw down cap........
    £10 Sterling here.............
    http://www.eurospares.co.uk/partsListing.asp?M=1&Mo=643&A=1&B=36903&S=&ID4=1509497
  9. Rifledriver
    37,089
    That will be impossible to say until the car is inspected by someone reputable. Too many of those things are a judgement call and I would need to see them to give you an intelligent or useful answer.
  10. ELP_JC
    ELP_JC Formula 3
    Dec 13, 2008
    1,264
    I'm going thru a PPI on Monday at FNE; hope I don't get a list like that. He he.
    Problem for us first time buyers is we don't know anything about these cars. And add not having a dealer closer than 400 miles and those results make any of us nervous. My car has CCB, and dealer told me I should never have to worry about them driving the car mildly (like I will), so hope the wear is less than 90%, like he predicted on this 8.8K-mile, '06 spider. My other concern is the clutch (6MT), which I also hope is around 90%. But I also want checked the PS, water pump, suspension, alignment, and max SD3 engine values (rpm, coolant temp, oil temp, etc), to make sure engine was never mechanically overrevved, overheated, etc.
    Owner told me I was wasting my $1K (car has to be transported to a dealer), but since he's the second owner, it's money well spent IMO. We'll see.
    Good luck man, and please keep us posted on your decision.
  11. windsock
    windsock Formula 3
    1,151
    While almost all of the recommendation do seem to be out of line price wise we have not seen the actually verbage but hearing it second had. I hope this was worded in a way to give you a heads up as to areas that are showing some concerns and you should be aware of the POTENTIAL repairs needed. We very often make observation for items showing concerns but it is worded as a moist or seeping unit that should be monitored rather then a leaking unit that needs replacement. P/S pumps and water pumps on these units will seep. It is not uncommon for the 430 water pump to have a spot of coolant or dried residue at one of the two weap holes. Providing it is not actively leaking or leaving a puddle on the undertray. Monitor and advise if things change.
    Hopefully the technician was looking out for your best interest and perhaps the Service Advisor got a little carried away. I would recommend speaking directly with a technician if possible, we enourage it here, and have him show you areas in need or of concern.
    Good luck in your search for a car.
  12. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I'm not qualified to comment on most things but a couple of itmes and can talk about from first hand experience with an 05. The suspension tends to creak. I had bushings replaced under warranty but some creaking still happens occasionally. I don't let it bother me.
    There is a warning light when the front pads get to 10%. I can tell you first hand it works. A set of pads installed is about 1K at my dealer.
    It is likely it was delivered with the alignment out, mine was and I've heard of others. Just more of Ferrari's fantastice quality control!
    I've had mine since new and it now has 19K miles. Very, very few problems.
    Dave
  13. Rifledriver
    37,089
    Last time I was there they had 2 alignment racks for the entire production facility. One of them was being used for storing boxes, the other was not in use at the time.
    Do you know how fast you would need to work to get a days production aligned on one rack?
    Bottom line is most never see an alignment rack. They align one occasionally and the rest get set the same way.
  14. hardtop
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I'm surprised they haven't added a "proper alignment" option for about 5K.
    Dave
