07 F430 F1 Engine stalling? | FerrariChat
Discussion in '360/430' started by Jati, Feb 28, 2008.
  1. Jati
    Jati Formula Junior
    Dec 3, 2004
    299
    Florida & NC
    Joe G.
    Hi all,
    I just took delivery of my 07 F430 Spider F1......
    While the transport driver was backing it off of the truck, the engine stalled multiple times. I thought this may have been caused by it just being cold.
    Once the car was thoroughly warmed-up, while driving home, the engine stalled again...This time I was in first gear awaiting a turn light...
    BTW, The car only has delivery miles.
    Any ideas of cause, or experiences with this?
    TIA, Joe
  2. sws4re
    sws4re Formula Junior
    Jan 28, 2006
    281
    Olathe Ks
    Scott Sweat
    Was the battery low or seem week when he restarted it? I have seen this happen when a battery is low. If the car was warmed up at idle that is not enough to charge the battery. How far did you drive and at what rpm before it died on you? Remember this car needs to be pluged into a battery tender when not in use. I had a 430 in my shop the other day and it only took 3 days for the battery to go down.
  3. MordaloMVD
    MordaloMVD F1 Rookie
    Sep 7, 2005
    4,222
    WA
    Michael von Ditter
    The Ferrari batteries are garbage, replace it fast.
  4. nopiston
    nopiston Formula Junior
    Apr 1, 2004
    273
    Orange County, CA
    Randy
    Also, is it almost out of gas? The rest are correct though: they'll run like crap when they've got a bad battery.
  5. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    The batteries are perfectly fine in the 430 and they def dont need a charger. I had my 05 430 for 2 yrs and sometimes left it for 2 months when traveling and it always started fine and the same goes for my 07 430... You def have an issue so get to a dealer ASAP. i doubt its your battery.... I believe the gas theory moreso.
  6. Stackhouse
    Stackhouse F1 Rookie
    Feb 14, 2004
    4,734
    IN YOUR TRUNK
    CT.. AKA Pimp Daddy
    Are you suggesting an "Aftermarket" Battery? ;) ..... wont Ferrari Void your warranty? LOL LOL
  7. marksp
    marksp Formula Junior
    Jul 10, 2006
    737
    Redmond, WA
    My 1st F430 had a similar issue. It was determined to require a slight adjustment of the clutch. The F1 system thought it had disengaged the gearbox, but there was just enough drag to pull the motor down at very low engine RPM's. Quick, very minor adjustment.
  8. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,163
    Wash DC area
    Robert
    Might also be the fuel. How long has the fuel been sitting in the tank???
    Robert
  9. RufMD
    RufMD F1 Rookie
    Jan 31, 2004
    3,246
    Jas
    Congrats on the car Joe, you'll get the little niggles worked out...pics ? :)
  10. robert biscan
    robert biscan F1 Veteran
    5,080
    Nashville and Palm b
    robert s biscan
    I'm going for this theory. I would put the car on a trickle charge to rule that out.
  11. BCS
    BCS Karting
    Aug 28, 2007
    176
    NJ/NY
    Bill
    trade it in for a manual. JK! That definitely doesn't sound right...take it in asap.
