07294 "chairs & flairs", but no chairs! | Page 2 | FerrariChat
Discussion in '206/246' started by Bluebottle, Oct 5, 2019.
  1. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,348
    Iain
    There were two version of the Campagnolo wheel - one with the Dino script and one without. I'm sure Matthias will confirm about the way the door cards were fitted as his Compendium states on page 233 "the E series door panels are attached to the inner door with five body screws and the usual brackets and clips." Those trim screws are fitted as per the attached picture -
    TonyL likes this.
  2. Ken Ivey
    Ken Ivey Formula Junior
    257
    Portland, OR, USA
    Ken Ivey
    Ejtel246,
    With regard to the hesitation to point out faults, for a while, if a car showed up in the chat room, it was literally picked apart. There are people here that know every bolt, type of material and correct piece on a 246. However, it wasn’t very productive or welcoming. So, people are hesitant to pick at originality or quality. On the other hand, if you’re looking at a car, and want to know what needs to be corrected, this is the place. Helpful is much different from critical.
    Ken
    TonyL and Eltel246 like this.
  3. racerboy9
    racerboy9 F1 Rookie
    2,673
    I've looked at a ton of Dino door pictures and it seems many had three trim screws at the bottom forward half of the door card all in about the same location and with similar spacing. Several low mileage cars had them including the 2,900 mile Dino found with a Daytona and Bora. I have to assume at some point the factory decided to add those for some reason.
  4. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    In 1995 I bought a set of Campagnolos from Shaughnessy without the Dino script, they were dated correctly and he also claimed they were OEM and that not all OEM have the script.
  5. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,502
    Germany
    Matthias
    thats correct....
  6. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
