09 scud battery install? | FerrariChat
Discussion in '360/430' started by jrodrig688, Jun 25, 2013.
  1. jrodrig688
    jrodrig688 Formula Junior
    Dec 3, 2012
    397
    FL
    Jose Rodriguez
    09 scud
    I want to change/ install new battery. What's the protocol/steps?
    Do i need to turn battery switch off prior? Once new battery is in anything else needs to be done to regain original settings?
    Thanks in advance
  2. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    obtain radio code
    unlock car
    drop windows
    open hood
    kill the battery with cut-off switch in the trunk
    change battery
    unlock battery cut-off switch
    click remote three times
    key on ignition for 30 seconds with accessories on
    enter radio code
  3. jrodrig688
    Dec 3, 2012
    397
    FL
    Jose Rodriguez
    Excellent. Thank you
  4. fc2
    fc2 F1 Veteran Owner
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    this is why I love this forum...
  5. tonyswfla
    tonyswfla Formula Junior
    Dec 2, 2007
    823
    Florida
    what battery did you use?
  6. jrodrig688
    Dec 3, 2012
    397
    FL
    Jose Rodriguez
    I used factory battery. Optima
    Bought it at autozone.
  7. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    I would highly recommend removing the negative cable first. That way if you accidentally touch something metal with your wrench while removing the positive cable nothing bad can happen. Touching ground while removing the negative cable has no consequences. I remember removing a battery terminal on my 1969 Triumph Herald. The nut on the positive clamp came loose a little too easy and the wrench (spanner in that case) hit the body. Let me tell you, that spanner got really hot in a hurry.
    Reverse order for install -- positive first.
    Also depending on what make of battery you get you need to ensure that the drain/vent tube needs to be reinstalled.
    Alan
  8. tonyswfla
    Dec 2, 2007
    823
    Florida
    was it a red top?
    34-78 part #?
    THX
  9. up4speed
    up4speed F1 Rookie Silver Subscribed
    Feb 16, 2012
    3,693
    Long Island, NY
    Chris
    Very good advice.
  10. ttn27
    ttn27 Formula 3
    Sep 30, 2010
    1,131
    TX
    TN
    I was told that an Interstate battery does not fit in the scud battery compartment and that only the Optima fits. I was quoted $350 for an Optima battery by the dealership. What is the price of your Optima?
  11. Green
    Green Karting
    Apr 13, 2008
    152
    Houston, TX
    around $200 from autozone
  12. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Can you attache a 9V battery to retain the codes?
  13. English Rebel
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    If you use a 9v battery you have to connect it before cutting the power and I'm not sure it would be happy being fed 12v. I wouldn't take the risk as there's only one code -- for the radio and it's easy to do.
    Alan
  14. shad99
    shad99 Formula Junior
    Dec 12, 2013
    300
    Japatul Valley, CA
    Andy
    Why not with the new battery? Parallel the new battery with the old battery using wire with alligator clips, disconnect old battery, then connect new battery, then disconnect paralleling wires. This way the car never loses power. Used this method on my BMW and it works just fine.
    Cheers, Andy
  15. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    An even better idea, simple and excellent!
