1-4 CEL resolution... YEAH!! | FerrariChat
Discussion in '348/355' started by Jagbuff, Jan 29, 2007.
  1. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    My TS has been nagged by an intermittent problem where bank 1-4 would stop running after the car had been turned off for 10-15 mins post full warm up. I would get the CEL if I drove it and cancelling CEL errors etc.. would not always bring it back to running properly. Sometimes it would "fix" itself overnight, very difficult to isolate the problem. I tried everything, switching the MAF, the O2, ECUs, Cat ECU... finally cracked the code this week end.
    I decided to check spark (old fashion troubleshooting instead of relying on ECU) and crack a fuel line to see if the pressure was ok, plenty of spark but no fuel. Checked fuses and relay, fuses ok, relay clicked. Checked Fuel pump voltage - 0 volts... ECU is obviously sending signal because relay is clicking... remove relay and replace with Aux Fan relay (no spare). Bank 1-4 is alive and runs fine!
    Bottom line is that the fuel pump relay is at fault, is works OK but must be getting old (using it now on the Aux Fan) and must have enough internal resistance/corrosion that it does not always close the circuit. I think, this causes a cascading effect with the O2 and MAF trying to compensate... and resulting in CELs.
    I guess the old way is still the right way.. is there spark and fuel? then work your way to the ECU errors codes
    Franck
  2. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    Nice fix (and good to know). Interesting problem, that one.
