348 - 1 Bank Running Rich, Stalls Occasionally When Hot | FerrariChat
348 1 Bank Running Rich, Stalls Occasionally When Hot
Discussion in '348/355' started by Koenig1, Mar 31, 2022.
  1. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    So, that stated, I have no o2 lights, etc. Plugs show 1 bank very rich, other bank a touch lean. I need ideas on what to check, try, verify! Plugs have been changed out. The crank sensors were changed last year. The O2 sensors have more than a few years on them, but no idiot lights. Don't really have access to an exhaust reader, but just looking for suggestions. Car starts well, pulls well, and the irritant is the occasional stall when coming to a light when hot. Also, may have to touch the pedal to get it to fire after a stall???
    All suggestions appreciated!
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    MAF, FPR, Cam sensor, fuel pumps, ignitors or coils, lost of possibilities from likely to less likely. I'd try balancing the intakes first, its in the manual, people monkey with those set screws on the TB, set them to the same vacuum both sides.
  3. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Also if the maf set screw caps are off people monkey with those. That will definitely lean or rich a motor.
    Sent using FerrariChat.com mobile app
  4. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    Hear what you're saying about the mafs'.... this is different. Mafs were set up a few years ago, something else is responsible... and only when running hot! It will arrive at a stoplight, 9x out of 10, proper idle. It's the 10th one that literally stalls while rolling to a stop. To start up on that failure, one must add a little pedal, and it will fire right up!?!?
  5. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Try turning your air screws out half return and see if that fixes it. If it if it does you have to balance your intakes properly
  6. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    9,609
    Atlanta, GA
    Steve D.
    All the plugs on the bank "equally" rich?
    sjd
  7. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    Yes, all plugs on passenger Bank are rich!!!
    steved033 likes this.
  8. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,166
    CT
    John Kreskovsky
    Bad coolant temp sensor?
    Qavion likes this.
  9. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    Coolant temps are normal.... maybe worth replacing, I question, wouldn't coolant temps sensor affect both banks? Another thought, maybe if I reverse the O2 sensor feeds.... looking if enrichment follows to other bank...? If so, replace offending O2 sensor, even though no idiot light, or something else?? Thanks for the thoughts guys, keep them coming!
  10. Qavion
    Qavion F1 World Champ
    13,891
    Ian Riddell
    There is one coolant temp sensor per bank on the 348
  11. johnk...
    Jun 11, 2004
    11,166
    CT
    John Kreskovsky
    If one CTS is bad the bank it is connected to may not go into close loop mode and would run rich. I had this happen with my 355 causing it to fail emission due to high HC. No CEL, but checking the codes showed CTS error, 1112.
  12. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    #12 Koenig1, Apr 1, 2022
    very interesting on these coolant temp sensors.... Is there anyone who can point to which coolant sensor runs with the passenger side bank(LHdrive car). I'll change that out just to satisfy any possible chance it's screwing me, lol! Anyone know the part #'s that I can search a fiche? maybe even ohm specs???
  13. Qavion
    13,891
    Ian Riddell
  14. Qavion
    13,891
    Ian Riddell
    Apart from the 2 coolant temperature sensors and the sender for the instrument cluster temperature gauge, I see a temperature "switch" in the 2.5 & 2.7 parts manuals (Item 45).
    Anyone know what this does?
  15. plugzit
    plugzit F1 Veteran
    7,752
    Redondo Beach, CA
    Bruce Bogart
    Bad maf on rich side.
  16. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    Thanks guys.... Qavion, is #45 the sensor they name "thermometric switch" ? Yes, would like to know what that does. You mentioned there should be a sensor for each bank, as well as a sender for the gauges... is that correct. If so, are there 2 sensors of either #43 or #45??? Plugsit... I'm thinking I'll switch mafs to other sides and re-initialize the setup, and see if the driver's bank enrichens.... at least that will spell maf or not. thanks
  17. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Two sensors one for each side same part number the washers or copper. Remove the fuel filter and you can get to them reaching inside. Can't miss them the baby blue.
  18. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Try turning the air screws out on the rich bank throttle body a quarter turn and see if that fixes your stalling. It's a coolant sensor goes bad there is a check engine code for those if I recall correctly.
  19. Qavion
    13,891
    Ian Riddell
    There are two of 43. There is only one (each) of the other two types.
  20. johnk...
    Jun 11, 2004
    11,166
    CT
    John Kreskovsky
    if you replace it, go to NAPA
    Yes, there's a code and the CEL should come on. But in my case there was no CEL on. Just the code stored in the ECU.
  21. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    Update... well, not really... Today, rechecking everything.... took it out for a drive.... ran great! No stalling/hesitation???? You know, sometimes I hate this car!!! Well, I guess today it's on my good side! It was 90*F, humid as hell, and decides it will run just great....! Maybe a loose connector earlier??? I'll wait till the next ride.... thanks for all your suggestions, appreciate it.
  22. johnk...
    Jun 11, 2004
    11,166
    CT
    John Kreskovsky
    Keep the temp sensors in mind if it happens again. Mine was an intermittent failure. You can test them by putting them in boiling water and watch as the resistance changes. Should be 1000s of ohm when cold and then drop to a couple hundred when hot. Mine work that way on 2 tests, then on the 3rd test the resistance started to drop as it should but suddenly when to infinite. As it cooled down it went back to normal. If it jumps to infinite the ECU thinks the engine in cold and it goes into open loop mode (rich).
  23. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    Will do, thanks to all again...
  24. m.stojanovic
    m.stojanovic F1 Rookie
    3,173
    Serbia - Niš
    Miroljub Stojanovic
    #45 "thermometric switch" is a thermo-switch which comes on if engine temp reaches 125C and lights up the high temperature warning light.
    Here's the resistance chart of the CTS (Bosch 0 280 130 026):
    BONNEFOND, Koenig1 and Qavion like this.
  25. Koenig1
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    Great info, thanks Miro.
