348 - 1 Bank Running Rich, Stalls Occasionally When Hot | Page 2 | FerrariChat
348 1 Bank Running Rich, Stalls Occasionally When Hot
Discussion in '348/355' started by Koenig1, Mar 31, 2022.
  1. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    I would guess at your O2 sensor being faulty. They can be intermittent as well. They will also start to react very slowly. If, as you said, they are years old, just replace both of them as a matter of course. Your MAF may well be at fault, but the O2 sensor is a more likely culprit. Your coolant temp sensor shouldn't cause it run so rich as to stall the engine, but you could swap the two sensors and see if your problem moves to the other side. You could do the same with your O2 sensors.
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    If the car is warm not cold, when you idle the idle will be real wonky if the 02 is bad. Or so it happened on mine.
    Sent using FerrariChat.com mobile app
  3. Gizzi
    Gizzi F1 Veteran
    Dec 3, 2011
    5,217
    Brisbane, Australia
    Gezim
    True, because it’ll be super rich or super lean, depending on the type of failure the sensor is experiencing (usually rich) and could cause the engine to stall on idle down.
  4. Koenig1
    Koenig1 Formula Junior
    Aug 25, 2016
    328
    Ottawa ON
    Sandy
    OK, thanks again guys. I took it out again for a good ride on Sunday, ran great, idle smooth, etc! I'll keep an eye on things. It was loaded on my trailer yesterday, for the trip home FL > Canada, so it won't see another workout until next week! Who knows with these cars getting older, same as my tired body.... just never know when you wake up each morning what's going to be sore.. LOL!
  5. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    Classic fuel pressure regulator failure symptoms. If cylinder 1 or 5 (closest to the firewall) is the flooded and/or blackened plug, then that is your failure point. Basically, the FPR leaks fuel back into the intake manifold just above those intake runners and floods the cylinder. Raw fuel burns in the cats and you get both a missing and slow down light for that bank.
    plugzit, Gizzi and Qavion like this.
