1 KEY NO PIN NO FOBS No Start. HELP.. | Page 3 | FerrariChat
Discussion in '348/355' started by dman550, Sep 3, 2014.
  1. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    I like the system personally and don't see the big deal, albeit mine works and the spares do also and the car starts by doing the key sequence with the pin
    The issue IMO is getting to that point if the object car is not fully functional. The OP can't even join this debate on disarming it until he figures out how to get the car started
    I hope he follows this thread and updates on how he does it. I don't think I have seen a post from someone starting at the point he is at to conclusion.
    Did Bruce sell his system from the car he's parting out?
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes.
  3. Badabing!
    Badabing! Formula Junior
    Mar 30, 2014
    731
    NYC
    Dave and Brian,
    When you tried this experiment, did you remove the key from the ignition?
    The reason I ask is I have a Porsche of similar vintage as the F355 (993) with a Bosch ecu and immobilizer and it functions similarly. However when you shut down, if I recall, if the key is not removed, the immobilizer does not arm.
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Yes. I got in the car, started as normal. I then shut it down, removed the key and sat there (in the car) for just over 2 minutes. Then I started the car again with no need to dis arm the immobilizer.
  5. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    Did you guys find any useful info in the doc I posted?
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I've seen that before. Not really that useful except it has some P/N's referenced.
  7. WATSON
    24,089
    WI
    I did!!!! Thanks!
  8. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Yes Eric.
    If I was the OP at this point I would try the neutralization solution outlined in that.
    Nothing to lose.
  9. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I'd love it if he would try that. I'm afraid to do it with my car because if I screw up the immobilizer I'm done!
  10. tr512
    tr512 Formula 3
    Apr 12, 2007
    1,600
    canada burnaby bc
    Michael
    Dave
    I live in Canada we dont need to lock our doors....smile
  11. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    I was thinking the same thing. It says it's for a Ford probe immobilizer defeat. I'd be afraid to try it on a working system just for fun, but if I was in the OPs situation I'd go for it and let us know how it goes.
  12. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Could a guy just take a day off work, set a case of beer in the passenger seat, a note pad, and start to try to find the pin with the key? With a 4 digit pin and no zeros it should only be 6000 ish different number combinations.
    1111
    1112
    1113
    You might be a touch insane by the 9000s, but could save a grand on that retrieval bill.
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    And probably smoke the ignition mechanism :D
  14. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    The procedure itself for one number is onerous, I have done it a few times. The zeros do count and the zero is 10 key turns.
    Theoretically it is doable. Practically...yikes
    1) Insert the ignition key and wait at least 20 seconds with the ignition
    key in off.
    2) Turn the key from off to on and back to off as quickly as possible
    (less than 2 seconds for all PIN numbers) 3 times (count to 3 out
    loud) for the first PIN number “3”.
    3) Count to 5 out loud (a good compromise between more than 2 and
    less than 20 seconds) before starting the second PIN number.
    4) Turn the key off-on-off 2 times for the second PIN number “2”.
    5) Count to 5.
    6) Turn the key off-on-off 10 times for the third PIN number “0”.
    7) Count to 5.
    8) Turn the key off-on-off four times for the fourth and last PIN
    number “4”.
    9) At this point the PIN is entered. After 5 seconds or so, turn the key
    back to on and after 2 seconds or a bit more with the key in the on
    position, the alarm light emitting diode (LED) will go off and you
    can start the car. Starting the car confirms you can correctly enter
    the PIN, the first step in reprogramming the Alarm ECU to accept
    new remote alarm fobs. Keep trying if you do not succeed the first
    time, remembering to wait more than 20 seconds before the next
    attempt.
  15. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,372
    Southern New Jersey Shore
    Phil
    The key flip is essentially setting a bit or sending a pulse, writing the software to simulate this action is straightforward. But what wires do you need to patch the laptop into to have the car "think" you're flipping the key...?
  16. 97 Spider
    97 Spider Formula 3
    Dec 15, 2012
    2,241
    Texas
    Brian
    Yikes, I don't have my PIN so I've never tried it. I didn't know there were zeros, That adds 4000 combinations. Better make it two cases of beer. :)
  17. drbob101
    drbob101 F1 Rookie
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Now I like that Phil. You could positap the ignition leads, simulate a key turn and write the code to have the computer find the pin?
  18. Eric C
    11,136
    St. Louis, MO
    Eric
    Since we’re throwing out secrets for everyone to see.
    I would jump the starter side of the immobilizer relay first. The F355 share the same immobilizer as the 993TT’s and this is how they disable the immobilizer. They have even tested it on a F355 and it worked.
  19. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Only for cars wired to disable the starter, that would not work on mine.
  20. Eric C
    11,136
    St. Louis, MO
    Eric
    So with yours, does the immobilizer disable the ignition or fuel? If you can figure that out, you would probably just need to jump the ignition or fuel side of the immobilizer relay. Just guessing.
    If I knew where that relay was, I'd try it out this weekend. I should probably download the wiring schematics.
  21. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    There is a pin going into the ECU that tells the ECU to disable the power to the ignition and pump circuits. Would anybody want to try to wiggle that pin?
  22. plugzit
    plugzit F1 Veteran
    7,813
    Redondo Beach, CA
    Bruce Bogart
    I'm very impressed. You guys are figuring it out!
    I'm doubly impressed because nobody has called anybody and idiot yet.
    Buncha smart people solving a problem. Very cool indeed. Following this thread closely, I'm just not smart enough to contribute anything but encouragement.
  23. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    I suspect that is correct but don't really know for sure. It's something I'm willing to dig into when the snow flys.
  24. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,637
    SoCal LA/OC/New Mexico
    Tim Dee
    #74 SoCal1, Sep 4, 2014
    Theres a chip in the ECU that can be programmed also from what I "understand" thats universal to the bosch system of that era BMW Porsche Ferrari etc
    Or has anyone tried a VAG drive box ?
  25. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,372
    Phil
    #75 PhilB, Sep 4, 2014
    I can line up the technical resources but I need more info about the use case:
    Does anyone know if the system goes into failsafe and totally shuts down if too many unsucessful attempts are made? If my application blasts a couple thousands attempts I don't want it to disable the system altogether.
    Once the app issues the correct sequence, and actually even when an incorrect sequence is entered, does the system respond with an acknowledgement?
    Assume the signal is 12volts?
    Does it have to patch into the ignition wires or could the OBD port be used as the interface?
    Most of this could probably be reverse engineered, but, having just got my 355 a couple months ago in no way will it be the test mule for this. ;)
