1 st GEAR | FerrariChat
1 st GEAR
Discussion in 'Technical Q&A' started by pitch, Mar 19, 2006.
  1. pitch
    pitch Rookie
    Feb 15, 2006
    7
    Guys, I just had my clutch, ring gear,& fly wheel replaced at Board Walk Ferrari and now after i warms it up , it will not go into first gear. anyone know whats-up?
  2. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    It could be the clutch is not quite disengaging all the way and needs adjustment if it's an older car with a cable. How low does it feel like it is grabbing when you let the pedal out? What model is it?
    DAve
  3. pitch
    pitch Rookie
    Feb 15, 2006
    7
    thanks for the reply, it happens , or is hard to get in to 1st gear after it is warmed up...strange... and its also tuff going into 2nd gear, as well...but sometimes(rarely) it goes right in to 1st........i hope its not the transmission, but, BoardWalk says that if it was the transmission, it would not go into 1st at all...hopefully there right....what do you think...its a 99 360..with 18500 miles
  4. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,334
    maurice T
    Experiencing the exact same problem with my GT4 as well.New clutch as well.I brought the car back to the mechanic and he is currently working on it.I will let you know what I find
  5. jjstecher
    jjstecher Formula Junior
    Jan 21, 2002
    962
    Rochester Minnesota
    John Stecher
    Did they bleed the clutch properly? I actually just had this happen to me a few weekends ago replacing a clutch and flywheel on a friends 350Z. If the clutch is not properly bled then it will not disengage the whole way causing it to not go into gear.
    Another thing to check is that they adjusted your clutch pedal correctly once the new clutch was installed. If they had adjusted it in the past as your old clutch wore aware you might not have enough travel in the pedal to disengage it as well.
  6. tstafford
    tstafford Formula Junior
    Mar 4, 2006
    754
    Nashville
    Tim
    Curious - how long was it from the time you picked the car up to when you first noticed the issue?
    I wonder how a Ferrari dealer could do such a repair and not test it out completely.
  7. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Pitch,
    Please fill in your profile, at least with the year & model of your car. Otherwise you'll get a lot of non-applicable advice.
  8. Rifledriver
    37,105
    They screwed up.
    Bring it back
  9. cavlino
    cavlino Formula 3
    Mar 6, 2002
    1,740
    Ottawa, Canada
    Carm Scaffidi
    Sounds like good advice to me, bring it back and tell them to test drive it after they think they have fixed it correctly.
