101*1292 Restoration | FerrariChat
Discussion in 'Maserati' started by GT ROCK, Aug 14, 2015.
  1. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #1 GT ROCK, Aug 14, 2015
    FORMERLY 3500 GT PROJECT
    Work has now started on the frame, the car came to me with the left hand sill cut off and separate new fabricated one which seems to be very well made.
    Yesterday we blasted the exposed frame on the left hand side, this was then etch primed and today we fitted the sill supplied, work is now continuing. I made a floor repair section with the correct fluting which will now be butt welded to the remarkably sound remaining floor.
    The other side has been heavily patched over and I suspect this will require a complete panel.
  2. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #2 GT ROCK, Aug 21, 2015
    The nearside sill area is almost complete now and we are about to replace the right hand one.
    The engine block has now been bored and honed.
    I came to clean the threads in the block for the head studs and it seems that the thread is different. The thread on the stud base is M14 x 2 and the block thread seems finer than this, can anyone tell me the likely thread profile in the block?
  3. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    Forget the thread question, It turned out the studs are correct and threads were exceptionally clogged
  4. F.Engineering
    F.Engineering Formula Junior
    343
    ITALY
    Fabio
    Keith,
    M 3500 GT is a my dream classic car ....
    Your is a carburetor version or injection?
    I will never buy one .... patience ...
    You have a good work! :)
  5. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    carburettor version......my dream car also, but some dreams include nightmares
  6. F.Engineering
    343
    ITALY
    Fabio
    Ahhh ... Also I would like to have the carburetors version with three great weber ....!!!
    good work!
    I have an engine AM 107 n° 2222 4.2 litres of Qp dated 1968
  7. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #7 GT ROCK, Sep 18, 2015
  8. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #8 GT ROCK, Sep 18, 2015
  9. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #9 GT ROCK, Sep 18, 2015
    The axle is nearing completion, I have fitted new wheel bearings, wheel cylinders, adjusters and shoes, looking for new u bolts then I can fit the leaf springs all ready to pop into the freshly painted car in the distant future.
  10. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #10 GT ROCK, Oct 24, 2015
  11. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #11 GT ROCK, Oct 24, 2015
  12. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #12 GT ROCK, Nov 7, 2015
  13. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #13 GT ROCK, Nov 7, 2015
    The machine shop recommended removing these plugs to facilitate cleaning of the crank oilways, not sure if this was a good idea as the thread is a mysterious size.
    I managed to re-plug them successfully after a few scary moments
  14. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #14 GT ROCK, Nov 7, 2015
  15. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #15 GT ROCK, Apr 25, 2016
  16. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #16 GT ROCK, Apr 25, 2016
  17. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #17 GT ROCK, Apr 25, 2016
    Repair sections were let into each wheel arch and the valance edges were replaced all around the body, this pic shows a wheel arch repair before linishing.
  18. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #18 GT ROCK, Apr 25, 2016
  19. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #19 GT ROCK, Apr 25, 2016
  20. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #20 GT ROCK, Apr 25, 2016
    Meanwhile I have pushed on with the engine work.
    The crank was balanced and installed, new oil pump parts were fitted along with new flywheel and clutch, eventually the bottom end was complete and it was a treat to install the sump and turn the whole lump the right way up and put it into the patiently awaiting trolley specially made for this purpose.
    It is my intention to get the engine running and tested before installation in the car.
    When my reconditioned starter returned home I was able to check the oil pressure in the bottom end. First step was to block the feed to the as yet non fitted cylinder head and to fit a pressure gauge to the gallery.
    After priming I turned the motor by hand and the gauge climbed to 10psi, a quick spin with the starter and I had 80 PSI, so all looks well down below.
    I have documented all of the work done on this car in a separate file to be kept as part of its history for future guardians, I am up to 60 pages so far.
    The engine work involved many steps and I have only skipped through them on the forum but here are a few pics to show some of the work done.
  21. MK1044
    MK1044 Two Time F1 World Champ
    Nov 6, 2011
    21,147
    NYC USA
    Carmine
    Great job. Keep the photos coming.
  22. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    250
    Connecticut
    John Jeffries
    Wow. Thanks for sharing with us. John.
  23. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #23 GT ROCK, Sep 14, 2016
  24. GT ROCK
    GT ROCK Karting
    Jul 24, 2015
    95
    Keith
    #24 GT ROCK, Sep 14, 2016
  25. 71Satisfaction
    71Satisfaction Formula 3
    Jul 15, 2012
    1,223
    New York and Norway
    Art
    Thanks for sharing!
    Beautiful - what is the exterior color called - and what color will the interior be??
    Cheers,
    - Art
