How do you remove the instrument panel and gauges in a 328? | FerrariChat
Discussion in '308/328' started by GrigioGuy, Jan 9, 2007.
  1. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,182
    E ' ' '/ F
    Snike Fingersmith
    How do you remove the instrument panel and gauges in a 328? As far as I can tell it's a press fit, but doesn't seem to want to move. Suggestions?
  2. GTHill
    GTHill F1 World Champ
    Jul 1, 2006
    14,054
    Double Wide
    GT Hill
    Time to roll that odometer back? Better late than never...
    Kidding of course. :)
    Gene
  3. BigTex
    79,386
    Houston, Texas
    Bubba
    The 4 corner lamps hide the mounting screws for the plate...they are a "snap" fit socket, meaning the prongs will 'snap' off when you mess with them..
    Then the gauges are mounted via carrier strap to the face plate.....IIRC.
    That's what I've heard, anyway..
    Magnetic screwdriver on the screws or they'll drop into the dash.....
    Wrap the lights with two sided tape to build them up and jam them back in!
  4. buckminster
    buckminster Formula Junior
    Aug 18, 2005
    989
    On the water, SWFL
    Nicholas Raftis
    In addition to the above, you may want to remove the steering wheel for ease of removal and re-assembly.
  5. BigTex
    79,386
    Houston, Texas
    Bubba
    ...or at least pad the column to avoid scratching it.....good point!
  6. GrigioGuy
    Nov 26, 2001
    33,182
    E ' ' '/ F
    Snike Fingersmith
    The steering wheel is already out, but the suggestion is welcome.
    The lens cover came off the tach easily enough, but not the other instruments.
    Looks like someone's already been in there once based on the scratches on the faceplate.
    Thanks Speedy/Bubba/BigTex for the suggestion on the light sockets, will check this evening.
  7. BigTex
    79,386
    Houston, Texas
    Bubba
    That's to pull the whole plate...then the gauges come out easier......
    Mine's scratched too! We should engine turn 'em, like the old Trans Ams! LOL!
    *ahem*
    Or at least send it out for refinishing.....you are pulling yours to change color?
  8. GrigioGuy
    Nov 26, 2001
    33,182
    E ' ' '/ F
    Snike Fingersmith
    Yep. Actually, I want to see what a new panel in bright aluminum will cost, or I might just get this one powercoated -- I'm pretty sure I can get a "bare aluminum" powercoat color.
    Just my ongoing effort to turn my car into a 77 GTB :D
  9. BigTex
    79,386
    Houston, Texas
    Bubba
    You'll need to install leaking cam seals and some rust bubbles, then.......:rolleyes:
  10. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    bubba is right, beware,those plastic light lenses are very fragile, I used a grabber like an olive or ice tongs type of grabber from the bar with three prongs to get as even a pressure on pulling them as possible while pulling them straight out and wiggling ( the lenses that is)
  11. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    Read somewhere (on this site) you can wrap dental floss around the base of the lamps and pull them out. Thats what I did. Took a few tries but all 4 lamps came out and I didn't break any of the little tabs.
  12. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    #12 Pizzaman Chris, Jan 9, 2007
    I don't know if this helps, but here is a picture when i pulled mine. :)
    You can see the 2 screws on the bottom and then there's 2 more up top corner.
    Good luck.
  13. GrigioGuy
    Nov 26, 2001
    33,182
    E ' ' '/ F
    Snike Fingersmith
    #13 GrigioGuy, Feb 4, 2007
  14. 4RE42
    4RE42 Formula Junior
    Nov 16, 2006
    345
    Salem, OR
    Michael & Melinda
    Thank you for taking the time to take the pics and post them. Good - helpful information. mb
  15. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,814
    Cerritos, CA.
    Is the 308's the same as the 328's instrument panel as far as removing it?
  16. Impactco
    Impactco Formula 3
    Jan 29, 2006
    1,615
    I pulled my 308 panel a few months ago to put in brighter bulbs and it looked identical.
